Pin 2.7 powers as soon as i connect power to the board
Posted: Sat Mar 19, 2016 12:07 am
by Aflac
So I get everything hooked up and power it on and instantly my heatbed started heating, I had it hooked up to pin 2.7. so I shut down the machine and check my config, the only reference to pin 2.7 that i could find was in my heatbed temperature control section. so i rewire things and hook my hotend up to that pin and redid the config to match and the heatbed is fine on 2.5 but the hotend starts heating as soon as i power on the board. anyone have any ideas?
Re: Pin 2.7 powers as soon as i connect power to the board
Posted: Sat Mar 19, 2016 12:13 am
by Aflac
I attached my config file if anyone wants to look at it, i converted it to a txt so the forum would let me upload it.
Posted: Sat Mar 19, 2016 9:02 pm
by KAS
Sounds like the big mosfet (AOT240L) failed closed and that will automatically turn on when powered up.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Posted: Sun Mar 20, 2016 1:26 pm
by Aflac
is this an easily fixable thing, or should i just not use that connection?
Posted: Sun Mar 20, 2016 7:40 pm
by KAS
It's like a $2 part with three solder points. Quick and easy to replace, or you can just work around it. Just be careful because the smaller mosfets cant handle the same amperage.
http://www.digikey.com/product-detail/e ... ND/2769834
Posted: Sun Mar 20, 2016 8:58 pm
by WZ9V
It's an easy repair in theory but the board design allows it to absorb a lot of heat so it can be a real bear removing the old FET and getting a good joint on the new one.
Posted: Mon Mar 21, 2016 10:33 am
by KAS
WZ9V wrote:It's an easy repair in theory but the board design allows it to absorb a lot of heat so it can be a real bear removing the old FET and getting a good joint on the new one.
board design?, okay. The mosfet has a little heat transfer pad but nothing crazy. If you can solder the wires on the Onyx PCB, you can replace the mosfet.
Worst case? cut the pins with flush cutters and remove each pin separately.
