You can get these latest releases from Christian's github.
Duet Web Control v1.11
RepRapFirmware v1.09y-ch
DuetIAP no version #
If you've been using the IAP to update firmware then you can do the complete update without USB, bossac or removing the CF card! Here's how, it's as easy as 1, 2, 3:
From Settings->General in DWC:
1) upload the DWC zip file. Note, Mac OS X automatically unzips after downloading so you may have to recompress the root folder.
2) upload the IAP
3) upload RRF
There are a few feature differences between ch and dc42 firmwares (comparing the latest versions).
- ch has G-code interleaving, which means you can run G-codes from any input source at the same time like PanelDue, Serial USB, code quay, file and macro. There is a G-codequeue that insures codes like M106 are executed in time. These features are useful for cooling bridges, etc.
- the current ch has the most recent fixes for the disconnect issues that affected many users.
- otherwise, the overall functionality is basically the same.
