Liquid mixing apparatus
Posted: Sun Mar 20, 2016 1:42 pm
Hey gents. I'm starting to look into building a fairly simple drink mixing machine. It's entirely a hobby proposition. If it works out I may give it to a friend that operates a restaurant serving thousands of mimosas every day
My idea is fairly simple. A pair of "high" volume, rough measure feeds and a pair of "low" volume, precise measure feeds into a combining chamber. A slow agitator in the combining chamber. A second dispensing chamber that the combined liquid is drained into after mixing. Then a tap on the dispensing chamber for serving.
The four feeds should be sourced from vats with liquid level measurement. I can imagine the measurement valves and sensors being controlled by an AVR for real time accuracy. This controller would be interfaced with an ARM board running full OS that provides measurement data based on recipe input.
Possible additional goodies would be a refrigeration source for the dispensing vat. Realistically I'd like to build the AVR controlled measurement components first as a proof of concept.
Does anyone have any advice for sensor and valve hardware? I'm sure there are standard small-volume plumbing components I could adapt for this. I'm debating taking apart my k-cup machine to see how it's built.
Thoughts?
Thoughts?
