Protip: Don't forget to adjust your thermistor values
bob64
Post by bob64 »
Use this for the e3d v6 hotend thermistor:
M305 P1 T100000 B4388 R4700 H30 L0
Was wondering why the extruder was having a hard time pushing filament... turns out the sensor temperature was reading higher then it was.
As for the bed:
M305 P0 T100000 B4286 R4700 H30 L0
This optimizes it slightly for the lower bed temps.
Rostock Max V2 with mods:
Duet v.8.5.0
bot
Re: Protip: Don't forget to adjust your thermistor values
Post by bot »
I experience the exact same thing.
*not actually a robot
3D-Print
Post by 3D-Print »
What is the best and inexpensive way to measure real temp?
bob64
Post by bob64 »
Get a thermocouple from ebay or something. Either way, if you've got a similar thermistor, the settings above should work.
Duet v.8.5.0
Great_Thark
Post by Great_Thark »
In theory E3D V6 should be the same settings as stock hotend. They have same thermistor according to specs.
Return to “Duet”
