theverant wrote:Hi all,
I'm interested in hearing about new users of the Rostock Max. I'm looking at buying one and have been on the fence for a while now. Figure I should go straight to the source - both positive & negative experiences welcome.
In particular I'd love to hear about:
1. How are your prints coming out?
2. How fast are you printing? (Perimeters/infill)
3. How difficult was it to make it to your first print? (both build experience and software perimeters)
4. How much tweaking are you needing to do to? (hardware & software)
Cheers.
I'm still messing around with my settings, but I'm very pleased with it so far.
Short version on print quality, is I'm still having some minor issues with dribble from the Bowden based extruder, but the layer alignment is as good as I've seen.
Dimensions look to be about as accurate as any hobby printer.
I was unable to get my extruder to suck/prime and significant distance at speed without the filament buckling at the entrance to the Bowden tube, I've since printed a plastic guide that sit's over the securing nut, and prevents the buckling, so I now have to spend some time tweaking the settings.
Calibration is poorly explained in the manual, and it would be a lot easier with a dial gauge, it basically involves aligning the 3 endstops, which unfortunately comes down to measure adjust home, measure adjust.....
I'm a programmer, so the firmware thing has never really been an issue, the default settings are close, but they require some tweaks, most notable motor direction, and Z height, though I have also turned down the digipot settings slightly. I also commented out some spam that's printed to the console by the firmware, that was added to debug the delta movement code.
One subtle issue is that issues present differently on delta style printers than on conventional printers, so when debugging a print issue experience doesn't always help.
I've built 4 printers now, and the RostockMax was easily the most complete "kit", documentation is OK. It took me perhaps 15 hours to complete. The only significant issue I had was blowing a fuse on the Rambo board. Having said that it is like all the other hobby printers, it's work to assemble and it isn't point and click printing, if you've ever built a printer before you know pretty much what you'll have to deal with.
If you've never built a printer before there is the whole understanding what good looks like for the first layer battle to fight, getting good adhesion with appropriate layer height. One of the not very newbie friendly parts is having to set the ZOffset in the firmware, once it's set you rarely touch it, but any minor change requires modifying and re downloading the firmware, it's less than 40 seconds total, but some people don't seem to like editing it. I run my MendelMax the same way, so it's not much of an issue for me.
As for speeds, I'm still messing with settings, I'm not being particularly agressive right now, 30-50mm/s for perimeters and 70mm/s for sparse infill (though I use hexagonal infill which has to be printed more slowly), that's about the same as I print on my MendelMax most of the time.
I've run 0.2mm layer heights for most of the prints, and calibration objects upto 0.3mm and down to 0.15mm (you could certainly go lower, though calibration starts to be an issue), there is a lot of pressure required to extrude from the SeeMeCNC hotend and I have to run my plastic perhaps 10 degrees hotter than I am used to.
