More troubleshooting on the new build
Posted: Fri Apr 08, 2016 12:24 am
Hi guys,
I'm trying to figure out how to improve my prints. Here is a picture.
The lines on this layer are regularly uneven. Thick line (shown by solid line) then thin line, then thick, etc. The second issue is that the lines leave gaps near the perimeter (oval).
Questions:
What is the proper term for these lines on the top and bottom solid layers? Are these considered some form of infill?
What ideas should I consider for the alternating thick-thin lines.
What ideas for the gaps?
I think there is slight overextrusion still occurring. I was conservative when I was following the E-steps Fine Tuning guide. I don' t think I dialed it back enough, I had reduced it from 92.65 to 89.89 during the tuning. I decided at that point to go with it for a bit and retune later.
Please go ahead and offer any guidance, even for problems I may not have spotted.
(edit) Details I should have included initially:
Thanks again for any help. Its funny to start into something where even the terminology is foreign to me. I'm trying to learn the proper terms so that I can ask more intelligent questions without miscommunicating.
Questions:
- Midnight Black SeeMeCNC ABS 1.75 with actual measurement of 1.67 mm
Heated bed to 70C with Fablam surface
Extruder temp 228C (stock hotend). I performed the cylinder pull apart test and settled back on 228. 235 didn't improve things and I got a few more pops. 225 made the pull apart easy. I was happy with the strength during the PEEK and Layer Fan prints in the assembly manual, so I went back to 228.
This is the bottom surface, so we're looking at the first layer.
I have not performed the gross extrusion tests to 100mm. This is part of the reason I decided to stop with the e-steps fine tuning. I will install belt tensioners this weekend, retension everything and recalibrate. I will start gain on the extruder calibration as well and start with the 100mm test first. (However, I get the tiniest of ridges on the top and bottom surfaces, and "think" I see gaps in the infil when set to 95% - so I think its at least close.)
I calibrated according to the Assembly Manual, but used a dial indicator when running the Tower Cal script. I got the 3 towers within 1/1000 of an inch (shrug - I prefer metric but I had an SAE dial), then adjusted the horizontal radius until the center was also within 1/1000th. However, Z-axis height remains something I can't really figure out how to dial in as close. I still use the paper pull technique.
I have stuck with Mattercontrol and the Matterslice engine. I have purchased Simplify 3D, but haven't started using it (but its available as an option.) I thought troubleshooting might be better done before I start switching up the software.
