Replicape with beaglebone black!
Is there anybody on here with any bit of experiencing using this setup for a delta controller? I thought this would be the key too best print quality, but i was shot down from my high horse real fast. I have the replicape flashed with the latest Kamikaze firmware, but im having the hardest time configuring this for my rostock. It already has the config files to use a kossel mini which is the closet, and only delta printer it fully supports right now, but i cant even get the printer to move in any direction. As soon as i have it boot up in ocotoprint the motors releases a high pitched sound and then do nothing. I thought it was my wiring but in every possible combination it does the same thing. Im at a lost end here ,and not sure where else too look. The support online for deltas is so minimal, idk where to begin with searching for the right list of connfig files. When it was running reddeem, it was a lot easier to set up, and ever port over marlin based code to this, now that everything is run through ocotprint i dont know how to find what im looking for. Any body have any input?
