E3D Cyclops using ABS + HIPS
Posted: Sun Apr 10, 2016 5:54 pm
Have a particular interest printing in ABS for its resilient physical and heat properties, as well as the various finishing options available.
Do a lot with hobby rocketry where the capabilities of ABS are interesting: http://www.bpasa.com/
Started 3D printing with a stock Rostock MAX Nov. 2015 and found that same material support required a lot of cutting and sanding to remove support, and then the supported surfaces were very rough.
Top two pictures are a carrier/cover for a small (Keyfob sized) 808 #16 video camera. Intended to be mounted on the outside of a rocket for cool onboard flight video. Many of these videos are posted on my rocketry website link above. The 808 #16 is a good value at about $40 without SD card, capable of 720p 30fps video.
I have used carefully applied yellow masking tape to successfully hold these cameras to the side of rockets up to 350mph, and buildups of fiberglass past 1100mph. Hoping to print ABS shells that let me do this as another option.
Bottom pic is a spinning flying saucer that I later flew, after a lot of cutting and sanding to remove all the underlying support.
