Here is what helped me with ABS SeeMeCNC Arctic White 1.63mm
- Print 4-5 skirt layers to ensure nozzle primed
- Move skirt 0.3mm away from body to provide a air shield/slow cooling (couldn't have touching - delicate animal finger parts broke when i tried to remove)
- raise bed temp to 90C
- start bed temp drop to 50C after first 3-5 layers
- Aquenet hairspray applied very thickly (liquid sheet allowed to dry until tacky [1-2hr] away from printer, if you put on domed onyx bed too soon it will flow off corners and try to get at your printer components.... then heat up to complete dry. (recalibrate z0 when you do this) So far I am on like my 10th print on same bed with no signs of needing to re-apply one layer hair spray yet
- reduce infill from 80% to 25% when possible
[img]http://i.imgur.com/swt5RTVl.jpg?1[/img]
As you can see I've run into another problem:
https://www.simplify3d.com/support/prin ... s-and-zits
Any suggestions on retraction settings to try? I've tried a few retractions/extrusion settings but haven't found good ones yet. I seem to leak too much on motion. Tried lower print head temp 5C as well which helped a little. (225C now)
The biggest problems seem to be when it has to cross large open distances as illustrated below:
[img]http://i.imgur.com/H7ISn1R.jpg[/img]
