Steve's Extruder Video - Gears & Bearings
JohnStack
Post by JohnStack »
We watched the Steve's Extruder Head build video. Pretty fun!
In the video, Steve walked away for a bit to get a 11mm socket to press the bearing in. (Either that or he had a quick beer break and the socket was just out of view.)
My wife (in Quality at a major aircraft engine manufacturer) asked whether or not it would be better to use a blow-dryer to heat the gears up a little before pressing the bearing in.
This might do two things:
Avoid accidents, warpage and dents
As the part cools, it might be better seated
Question - before assembly:
Would gentle heating help or hurt?
http://dropc.am/p/KhiI1a
tom10122
Re: Steve's Extruder Video - Gears & Bearings
Post by tom10122 »
I wouldn't , It could warp the gear. You should have no problems pressing the gears in with a vice.ABS expands enough to not crack.
johnoly99
Post by johnoly99 »
I wouldn't worry too much about heating the gears slightly. They are actually made from acetal, so they soften with heat easily, just make sure that its flat as it cools
cbuddha
Post by cbuddha »
What about the opposite, freeze the bearing. Would that be bad for the lube? - Old techie trick freeze a noisy clicking harddrive to get data off it.
