RostockMAXR2/Rambo alternate thermistor pins
BlindDevil
Post by BlindDevil »
On my Rambo board
My T0 seems to be broken and constantly reads 266. T2 works ok.
Can I use T1 or T3 and change the configuration?
Re: RostockMAXR2/Rambo alternate thermistor pins
Post by Xenocrates »
Yes you can. It's not hard. Either change the sensor assignment in config.h, or the pins in pins.h. I think the form is Temp_pins_0. Check what you take out before making permanent changes.
BlindDevil wrote:On my Rambo board
In a Google search box type in the following site:forum.seemecnc.com thermistor pin
This will bring up threads from this forum detailing what needs changed, where it needs changed , etc.
Good luck with this!
