Rambo board pin to control SSR
Posted: Sun Apr 24, 2016 9:52 am
by duvdev
Hello
I have a heatlamp to heat the air temo when printing ABS ans so...
I want to assign a pin from the board to the SSR that when in start to print i will a commang in the gcode to get that pin to high so the ssr will turn on the lamp and add a code to the end gcode to turn it of.
Is there a free pin for mr to use? and how can I use it?
thanks
Re: Rambo board pin to control SSR
Posted: Sun Apr 24, 2016 11:12 am
by Xenocrates
There are free pins to use. My suggestion is to use the case light. Discussion on finding it and using it can be found here:
http://forum.seemecnc.com/viewtopic.php ... ght#p80955
Posted: Sun Apr 24, 2016 11:49 am
by duvdev
thanks but I am using .91 software
Posted: Mon Apr 25, 2016 3:40 am
by teoman
There is GCODE to switch the pins on and off. You just have to find the pin.
