Layer fan reduces to 9% during print
Posted: Mon Apr 25, 2016 7:41 am
by Penged
I just got my layer fan up and running ( homemeade berd air setup) and when I checked on my print the layer fan had somehow reduced down to 9%. Any thoughts?
Re: Layer fan reduces to 9% during print
Posted: Mon Apr 25, 2016 7:55 am
by Jimustanguitar
Most slicers will let you specify a minimum and maximum fan speed. I'd look there first.
Posted: Mon Apr 25, 2016 8:07 am
by Penged
I think I found it. There is a setting in MC that reduces the speed for the first two layers. That brings me to a different question. How do i incorporate the fan speed into the file without having to adjust it maually?
Posted: Mon Apr 25, 2016 2:45 pm
Penged wrote:I think I found it. There is a setting in MC that reduces the speed for the first two layers. That brings me to a different question. How do i incorporate the fan speed into the file without having to adjust it maually?
See M106: Fan On located at
http://reprap.org/wiki/G-code
This will show you all the parameters you can use with M106 and the command could be inserted in your start or stop scripts or within the STL gcode itself.
Also see here:
http://forum.seemecnc.com/viewtopic.php?f=54&t=2523
