I received my FSR's this week and am trying to print mhackney's mounts for them. But U cannot (by far) fit the plunger into the mount. I did some measuring and found that the inner diameter of the mount is too small (17,56mm instead of the 18,59 it measures in the STL), The outer diameter of this circle is too big (22,49mm instead of 22,28 in the STL). Also the total width of the mount is too big (40,62mm instead of the 40,26mm in the STL). I am confused as to how this can be: some too small and some to large discrepancies measured in the same direction. Only thing that comes to my mind is that the width of the walls are wider than they should be. Can that be a result of over extrusion?
I do recognize a little over extrusion in the top surface of the part. But at the FSR bed level the surface looks just fine. Looking at the back of the mount, in the first few layers there seems to be under extrusion. Ofcourse all without touching the flow dial.
Spoiler:
Spoiler:
Any ideas?
