Heat bed gets too hot.
Posted: Thu Apr 28, 2016 11:03 pm
by Qdeathstar
I am having an issue where if I preheat my head and leave it running for a while (to calibrate) and then I go to print, it will never cool to the target temp.
Eg, for 60c it goes up to 63c and just hangs out there. I have to turn off the bed, wait for it to cool, then print. Kind of annoying.
Re: Heat bed gets too hot.
Posted: Fri Apr 29, 2016 12:50 am
by bob64
If you connect repeiter host to the printer. does it show it's sending full power to the bed?
Posted: Fri Apr 29, 2016 8:26 am
by Jimustanguitar
Is this just on the first layers of a print? It's not uncommon for the 180-230C of the print head to throw off the reading of the 40-80C bed for the first layer.
Posted: Fri Apr 29, 2016 12:26 pm
by Qdeathstar
The print won't start. If I have on preheat for too long the temp never falls to 60 and the print doesn't start unless I cancel it, turn off the heatbed and Saint for it to cool below 60.
It could be the hotend though, because it usually happens when I'm calibrating and my head is close to the bead.
Posted: Fri Apr 29, 2016 8:00 pm
by KAS
What slicer? Some programs have the option to ignore over heated temps and start the print anyways.
Posted: Sat Apr 30, 2016 12:00 am
by Qdeathstar
Right now I'm using matter control, just to get everything dialed in. I have simplify3D that I really like and will use later on.
