Strange sizing in x and y directions
Posted: Mon May 02, 2016 2:08 am
I cannot seem to get my x and y dimensions in printed parts to come out symmetrical. When I print a 50 mm calibration cube or a 100mm calibration cube, my X measurement will be within .05 mm of the expected dimension of the cube most of the way across. When I measure in the y dimension in the center of the cube, it will be ~0.4 mm smaller than the expected measurement. What is more odd is that left side of the cube is consistently longer in y direction than the right side of the cube. The variation is by around 0.4 mm as well. This means the y-axis a third of the way in may measure 49.8mm, the center might measure 49.6mm, and it might measure 49.4mm a third of the way from the right. Meanwhile the X-axis will measure pretty close to 50mm all the way across. The difference doesn't appear to scale for a 100mm cube. It stays approximately the same.
For a long time, I thought it was the cheap T-square that I used to level my towers or some other build error on my part. I finally got a digital level that tells me that all of my towers are less than 0.2 degrees off of vertical. I'm inclined to think this is acceptable, but perhaps it is not.
Still scratching my head, I printed an object from thingiverse (http://www.thingiverse.com/thing:240962) thinking perhaps my individual delta radius could fix the flaws. It turned out my x tower was a full 3mm farther away from the object than my y and z towers. I adjusted this in the EEPROM by changing my Delta A radius to 3. After that, the object printing an equal distance from all 3 towers. Unfortunately, I got the exact same offset in the x and y planes.
Does anyone have a clue what could be causing this discrepancy?
Thanks
Thanks
