wear resistant nozzles and Glow filament
Posted: Fri May 06, 2016 8:28 pm
by ken cummings
I'd like to do a lot more glow filament printing. Are there any wear resistant nozzles, anything from plated brass to tungsten allow nozzles that can be swapped into an Orion printer? Is anyone having problems with the strontium Aluminide loaded filament produced by Prototype supply as sold by Toy Builder Labs? If ProtoType isn't making it anymore is anyone else making this higher power stuff?
Re: wear resistant nozzles and Glow filament
Posted: Fri May 06, 2016 9:01 pm
by IMBoring25
The E3D hot ends have hardened steel hot ends available for extreme wear resistance and stainless ones for more wear resistance than brass and low contamination.
Posted: Sat May 07, 2016 9:23 am
by teoman
Does glow in the dark filament wear the nozzles fastjer?
I thought it was the more abrasive ones like carbon fiber ones.
Posted: Sat May 07, 2016 9:41 am
by IMBoring25
Glow filament is reported to be more abrasive, yes.
Posted: Sun May 08, 2016 1:41 am
by marcom
Couple of references:
http://www.thenerdmachine.com/3d-printi ... ur-nozzle/
https://twitter.com/josefprusa/status/7 ... 3002813440
So, yes it is more abrasive. The E3D has a hardened nozzle option but don't think there is one for the stock Seemecnc hot end. Would be nice tho.
Posted: Sun May 08, 2016 7:25 am
by Windshadow
I was thinking of turning one up on my Shaublin lathe from Phosphor_bronze
https://en.wikipedia.org/wiki/Phosphor_bronze
it should be a little better for heat transfer than the Stainless steel options on offer
https://en.wikipedia.org/wiki/Beryllium_copper
would be best but I don't have any on hand and it a PITA to machine in mt home machine shop with its hazmat problems while being machined
it is such an obvious material to try i expect lots of the real experts here with industrial shop access have already tried it perhaps they could say how it worked out?
Posted: Sun May 08, 2016 8:20 am
by Andre B
And people freak out over the little bit of lead in brass.
I would look into something like C63000 nickel aluminum bronze.
One thing that would need to be researched is how the properties of these copper alloys change at the temps we are using them at.
But I think if the design is done right the lower conductivity of steel and stainless should not be a problem.
Posted: Sun May 08, 2016 8:57 am
by Windshadow
good idea about the Aluminum bronze I will add to the list if do the experiment.
I machine lead all the time (and I have been melting down lead scrap and casting things from it for about 60 years (do so only in a very well ventilated workspace) first for toy solders and then for the last 58 years bullets of various sizes and design (when i workup a new design of bullet i turn the first experiments out of lead and then if the design works well I machine the mould blocks from durbar so i can cast them in large numbers. this winter for example i cast over 2500 .45 260 grain (7000 grains to a pound so yes that is more than 90 lbs of lead) slugs to shoot in my hobby sport of cowboy action shooting
http://www.sassnet.com/index.php
I also work on repairing antique mercury barometers (when i was young a trip to the dentist meant getting a little bit of mercury to play with... we used to rub it into pennies to make them look like dimes.
When a local school broke a mercury barometer in the chem lab the whole school was shut down for hazmat company to remove the "extremely hazardous liquid" I rescued the parts of the very nice lab standard barometer repaired it with a new glass tube and refilled from a carboy of mercury that i keep for just this event... sold it for a vey tidy sum.
(by the time i was 11 i was using my good patient reward from the dentist to make my own fulminate of mercury so i could make my own cap gun caps (that were much louder than standard ones from the shop)
Beryllium dust control is not something i am set up for in my shop and its not worth the risk of getting the dust allergy breathing problems that finishing a part made of Beryllium-copper can cause
Posted: Mon May 09, 2016 12:06 am
by ken cummings
I noodled around on Google for a common description of the hardness of this material. Strontium Aluminate gets as hard a silica sand, Mohs' Scale 7. Might as well put sand through your machine. I read that someone in Europe is working on a tungsten-Nickle alloy that conducts heat as well as brass. Now to look up finely ground carbon fiber. Printing will have to wait until I resolve why my MatterControl Touch has locked up.
