Black and White filament...
Posted: Wed May 25, 2016 5:39 pm
What do you guys make of this?
[img]http://hennekens.info/rostock/BW_Filament.jpg[/img]
My black PLA gets all white in the hot-end. Can this be caused just by the stretching while pulling it out? Think some piece is left as a clogg. This is happening constantly lately. After I stick in the filament and prime the hotend I can extrude without a problem. Even 10cm at once. But when I start printing it just clogs withing seconds. At first I thought it was because of the too small gap between bed and nozzle, since I had to experience the correct first layer height and minus z-probe heights settings after giving it fsr's. But I am pretty sure that's dialed in correct now. The PTFE was a bit bend at the hot end so I replaced it. Then I replaced the heatbreak because it suffered a lot of cloggs already and I tend to use the torch (which was never a problem before). Then I replaced the nozzle because during priming the filament come out if it a bit curly. So, Practically a new hotend, but still experiencing this. I even recently calibrated the thermistor and it operates within 2 degrees of my thermocouple. I usually print at 190 degrees, but the same goes when printing 200 or 220...
I am really out of ideas and want to get printing again.
