Page 1 of 3
HE280 Hot End and Probe board on RMAX v2
Posted: Mon Jun 27, 2016 12:35 pm
by bvandiepenbos
Finally got my hands on the new hot end and probe board to test out on the MAX v2
Made aluminum effector platform to mount it with ball cup arms.
Just downloaded newest Repetier fw and getting ready to flash it to machine.
Still figuring out the wiring...
Re: HE280 Hot End and Probe board on RMAX v2
Posted: Mon Jun 27, 2016 1:19 pm
by davec3275
Is this the new one from the Eris?
Posted: Mon Jun 27, 2016 2:20 pm
by U.S. Water Rockets
Forget the wiring.... I want to know when you're going to sell that effector platform and those sexy ball cup carbon fiber end tips!!!
Posted: Mon Jun 27, 2016 2:58 pm
by bvandiepenbos
davec3275 wrote:Is this the new one from the Eris?
yes, it is from the Eris.
I hear it will be standard on the RMAX v3 kits to be available in a few months.
And the hot end + probe board as a retrofit kit for older machines.
Posted: Mon Jun 27, 2016 3:04 pm
by davec3275
Sweet!! Maybe now I can finally use my RMax v2 properly.
bvandiepenbos wrote:davec3275 wrote:Is this the new one from the Eris?
Posted: Mon Jun 27, 2016 3:41 pm
by bvandiepenbos
U.S. Water Rockets wrote:Forget the wiring.... I want to know when you're going to sell that effector platform and those sexy ball cup carbon fiber end tips!!!
I have a few of the aluminum platforms available now that I milled on my CNC. I expect to have a batch of (50) from my local water-jet guy in a few weeks.
http://www.tricklaser.com/Aluminum-plat ... ALU-BJ.htm
Beta testing of the rod ends is complete, they work great! I am very close to pulling the trigger on the injection mold for those ends, just need to check over the design details before committing to the hard tooling investment. They will be injection molded Delrin.
I designed our new ball-cup rod end to be a drop-in replacement for the Traxxas ends used now on our CF arms. They will be available separately for people that already have our CF arms to convert to ball-cup by simply unscrewing the Traxxas and gluing the ball-cup rod ends in place.
They will become standard on our new CF arm sets, as will the springs... no more rubber lash straps.
The balls are 3/8", the same size as the SeeMeCNC ball joints, so you can use them with the stock RMAX white plastic bar-bells.
You can literally pop the stock arms off and pop our Carbon Fiber Ball-joint Arms in place.
I am working on metal ball alternatives also, but I have not figured out a satisfactory solution that is accurate and reasonably priced. So, to begin with we will be using the white plastic bar-bells. ...they are pretty good, but I think they flex a bit, I really would like a stiffer metal alternative.
Posted: Mon Jun 27, 2016 3:49 pm
An RMAX V3 kit in a few months? OUT
STANDIING!
Posted: Mon Jun 27, 2016 4:30 pm
What about the different arm lengths of the different SeeMeCNC arms?
Also, the white dumbells actually were a big improvement in print quality over the old U-joints. When I installed them, I got a dramatic improvement in fine details in my prints. I'm not sure how much those flex, but I'm pretty sure the SeeMeCNC arms are not as rigid as carbon fiber, so that might be really good for most users.
I'm looking forward to your new products!
Posted: Mon Jun 27, 2016 5:29 pm
They're injection molded glass-filled nylon. There's no realistic reason to replace them other than for asthetics(sp).
Posted: Tue Jun 28, 2016 10:21 am
by Tincho85
Nice effector Brian!
One question, can this new probe board be used with the E3D V6 or others hotends?
Posted: Tue Jun 28, 2016 6:10 pm
by dmgdispenser
Tincho85 wrote:Nice effector Brian!
nice, i'm also interested in finding out if that probeboard is usable with other hot ends, e3d v6 and others. thanks =)
Posted: Fri Jul 01, 2016 1:29 am
by bvandiepenbos
I think you could use it with other hot ends if probe pcb board was mounted at top of hot end, possibly under the bowden fitting?
The hole in pcb is only 7mm diameter, so the bowden collet should just fit through.
May be better to use another set of short standoffs on top of 3 holding groove mount, mount board to those.
Posted: Fri Jul 01, 2016 2:50 am
by travelphotog
There has been testing done with the E3d V6 and the probe board (a bird tells me) and it works just fine. With the board mounted above the hot end it looks close to the Yellow Jacket and there is talk about doing connections from it also. But as of now the narrow hole in the board it a limiting factor for wiring and such. But it does function from what I have been told. Time will tell when the units are out for testing I guess.
Posted: Fri Jul 01, 2016 2:48 pm
by Xenocrates
In theory, it should be able to be used like the HE280 is, as the heatbreak of the E3D will fit through the board. However, at that point you would need to wire it to the board, as there is otherwise not enough space for it. Of course, I'm just going by CAD models, not by experimentation. I think the Volcano would fit better, as there is a little more room for the wiring to droop that way.
Posted: Thu Jul 07, 2016 1:43 am
by d1rron
That's awesome that it will (probably) work well with the E3d V6, but what about the Prometheus V2!? I'd be interested in the board if it were compatible.
Posted: Sun Jul 24, 2016 5:45 pm
by CodonExe
bvandiepenbos wrote:U.S. Water Rockets wrote:Forget the wiring.... I want to know when you're going to sell that effector platform and those sexy ball cup carbon fiber end tips!!!
Very nice! I have been watching your site for the ball-cup ends.
Posted: Sun Jul 24, 2016 10:50 pm
by bvandiepenbos
CodonExe wrote:bvandiepenbos wrote:U.S. Water Rockets wrote:Forget the wiring.... I want to know when you're going to sell that effector platform and those sexy ball cup carbon fiber end tips!!!
Thanks.
The ball cup ends are getting closer to release. Still working out details with the injection molding company.
Posted: Sat Aug 06, 2016 9:45 pm
by Jetguy
Still extremely interested the in instant you think you have the injection molded ball arms ready. I need a custom set of 340mm long arms ASAP.
Posted: Wed Aug 31, 2016 8:36 pm
by bvandiepenbos
Injection mold is being built now.
I expect to have first batch of molded rod ends in 3 weeks.
Posted: Wed Aug 31, 2016 9:18 pm
by kraegar
Brian - if you need a hand with the wiring, or firmware, I can help you out. Send me a message and I'd be happy to.
As for using it with a v6, yes you can. I have it mounted above mine, using one of the top screws on my 713maker hotend mount to hold it in place, the bowden is routed through the middle.
Challenges with mount it like that is that, especially if you have a flying extruder, it's easy to cause effector tilt. Even a little tilt is a BIG deal with the accelerometer, and will throw off your calibration big time. Cable drag, or the bowden dragging on the center, can be enough to throw it off.
Once you sort all of that, as long as it's oriented right and cabled right, and solidly mounted, it works great. Calibration to an accuracy of +/- 0.01mm per probe point.
The firmware from seemecnc replaces G30 so you can't probe arbitrary points, it just does a 4 point calibration routine (equivilent to the "standard" calibration). If you want to be able to probe arbitrary points, I can post the bits I added to g30 in order to do so. I use it with the Delta Least Squares calibration website, and can print a 210mm circle completely flat, it calibrates down to a 0.02 deviation in 3 runs.
Posted: Wed Aug 31, 2016 9:21 pm
by kraegar
Here's a pic of it above my E3D v6, when I had my extruder in a "flying" config - I've since switched away from that, but haven't changed how I mount the probe. Just a cheap nylon spacer to provide some clearance for my hotend wires.
http://imgur.com/x0B7wfy
Posted: Wed Aug 31, 2016 9:42 pm
by kraegar
Oh, I also find I get better accuracy calibrating with both the hotend and bed at printing temps. However, you have to be sure the hotend is completely clear of all filament, and the bed is spotless, too. Any melted filament will cause your doduble-tap probe to fail with too great of a variation between checks.
Posted: Wed Aug 31, 2016 10:00 pm
by TwoTone
Sorry to piggy back onto this. When you added the probe board and uploaded the new firmware, were there any changes needed in the setting?
When I was looking at the firmware here:
https://github.com/seemecnc/Firmware/tr ... 20Firmware
I noticed it mentioned inverted motors.
So I was wondering what setting changes are needed to use the probe board on the V2.
Thanks.
Posted: Wed Aug 31, 2016 10:06 pm
by kraegar
Hopefully Brian doesn't mind me tagging in here. Since I've been updating regularly for a while now, to keep up with the changes as they release them, here's what I change for my particular setup (rostock max v2, e3d v6, e3d titan) - your changes may vary.
Configuration.h:
42: #define MOTHERBOARD 301 //RAMBO AJA
50: #define PRINTER 2 //Rostock Max v2 AJA
118: #define EXT0_TEMPSENSOR_TYPE 8 //changed to 8 for e3d v6 from default 97 AJA
123: #define EXT0_INVERSE 0 //changed to 0 from default 1 for titan AJA
258: #define MAXTEMP 290 // this is the max allowable temp the hotend can be set at, any higher will trigger safety's // Changed to 290 from default 245 for e3d v6 AJA
To add probing any arbitrary point, I use the following for "case 30" (the bulk of the changes other than a closing brace are at the top) in commands.cpp:
case 30: // G30 single probe set Z0
#if DISTORTION_CORRECTION
float oldFeedrate = Printer::feedrate;
Printer::measureDistortion();
Printer::feedrate = oldFeedrate;
#else
float sum = 0, sum1 = 0,last,oldFeedrate = Printer::feedrate, offsetmm = 0; //add ofsetmm = 0 AJA
bool oldAutolevel = Printer::isAutolevelActive();
if((com->hasS() && com->S == -1) && (com->hasX() && com->hasY())){
Printer::homeAxis(true,true,true);
GCode::executeFString(Com::tZProbeStartScript);
Printer::setAutolevelActive(false);
Printer::moveTo(com->X,com->Y,IGNORE_COORDINATE,IGNORE_COORDINATE,EEPROM::zProbeXYSpeed());
sum1 = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); //First tap Y tower
sum = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); //Second tap Y tower
if ((sum1 - sum) > .1 || (sum1 - sum) < - 0.1){
Com::printErrorFLN(Com::tZProbeFailed); //output to terminal Z probe failure
sum = -1; // fail flag to stop probe
}else{
offsetmm = sum - Z_PROBE_BED_DISTANCE;
Com::printFLN(PSTR("Probed offset in mm "),offsetmm);
}else{
//Back to normal seemecnc g30 AJA
do{
if(com->hasS() && com->S == 2){ // only reset eeprom if saving new value
Printer::zLength = Z_MAX_LENGTH; // set Z height to firmware default
EEPROM::storeDataIntoEEPROM(); // store default before calibration
EEPROM::readDataFromEEPROM(); // would not take effect unless read!
Printer::moveTo(0,0,IGNORE_COORDINATE,IGNORE_COORDINATE,EEPROM::zProbeXYSpeed());
sum1 = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); // First tap
sum = Printer::runZProbe(true,false,Z_PROBE_REPETITIONS,false); // Second tap
if ((sum1 - sum) > .1 || (sum1 - sum) < - 0.1){ //tap reports distance, if more or less than .1mm, it will re-run
sum = -1;
}while(sum < 1);
if(com->hasS() && com->S)
#if MAX_HARDWARE_ENDSTOP_Z
#if DRIVE_SYSTEM==DELTA
//Printer::updateCurrentPosition();
Printer::zLength += sum - Printer::currentPosition[Z_AXIS];
Printer::updateDerivedParameter();
//Printer::homeAxis(true,true,true);
#else
Printer::currentPositionSteps[Z_AXIS] = sum * Printer::axisStepsPerMM[Z_AXIS];
Printer::zLength = Printer::runZMaxProbe() + sum-ENDSTOP_Z_BACK_ON_HOME;
#endif
Com::printInfoFLN(Com::tZProbeZReset);
Com::printFLN(Com::tZProbePrinterHeight,Printer::zLength);
#else
Com::printFLN(PSTR("Adjusted z origin"));
#endif
Printer::setAutolevelActive(oldAutolevel);
Printer::updateCurrentPosition(true);
printCurrentPosition(PSTR("G30 "));
GCode::executeFString(Com::tZProbeEndScript);
#endif
} //close my if AJA
break;
Those are the only changes I need to make before I upload my firmware and start calibrating / printing.
Edit: to probe an arbitrary point, then, you have to send a G30 S-1 X0 Y0.... the S-1 is what triggers my bits to run, otherwise it's just the standard seemecnc implemented bits. I did that so I didn't break any instructions they provide. Here's my 10 probe points to use with the Delta Least Squares page here:
http://escher3d.com/pages/wizards/wizarddelta.php (use a printable radius of 142.68, you want the tower probe hitting nearly straight down, or it's going to be way off).
G30 S-1 X0.0 Y142.68
G30 S-1 X123.56 Y71.34
G30 S-1 X123.56 Y-71.34
G30 S-1 X0.0 Y-142.68
G30 S-1 X-123.56 Y-71.34
G30 S-1 X-123.56 Y71.34
G30 S-1 X0.0 Y71.34
G30 S-1 X61.78 Y-35.67
G30 S-1 X-61.78 Y-35.67
G30 S-1 X0.0 Y0.0
Posted: Wed Aug 31, 2016 10:36 pm
by kraegar
And one more, sorry Brian!
Here's a video of the hotend probe hitting X0 Y0, and a custom point (G30 S-1 X123.56 Y71.34)
https://youtu.be/tRhgYBRGdhQ
