Bondtech QR current settings?
Qdeathstar
Post by Qdeathstar »
Hello, I am trying to get my bondtech extruder going.
I press the extrude button, but all i get is CLICK CLICK CLICK.
I assume this is probably low stepper current? What should the settings be in RAMBO?
Qdeathstar
Re: Bondtech QR current settings?
Just in case,
I have it wired like this:
QR Grey - SeeMeCNC black
QR Red- SeeMeCNC green
QR Green - SeeMeCNC red
QR yellow - SeeMeCNC white
Qdeathstar
RAMBo Pin Kysan Stepper QR Stepper Stock wire
1 Red Gray Red
2 Green Red Green
3 Blue Green Black
4 Yellow Yellow White
I thought i used that but i guess i still got it wrong ... REJIGGERING NEEDED
Qdeathstar
Hi.
I got the stepper driver moving but:
1. It is moving very slow. I get 100mm of filament pushed through, but it takes about 15 seconds to do that?
2. It is moving in the wrong direction. Do i have to hook up my rostock to my computer (need a long usb cable :/) or is there an easier method via EEPROM?
Thanks
Eric
Post by Eric »
On speed, check your Extruder Steps per MM setting. It needs to match reality, whatever that is for this extruder/motor/microstepping setup. And if the steps per mm changed significantly, then likely the other extruder settings need adjusting as well (start feedrate, max feedrate, and acceleration).
Direction can be reversed either in firmware or by swapping the wires for one motor coil (change wires ABCD to either BACD or ABDC).
Qdeathstar
ANyone with a QR care to share those settings ?
They should be on the Bondtech website. You can reverse the direction of the stepper by just flipping the connector around. No need to move wires.
You can also reverse direction in firmware.
Eric
Post by Eric »
geneb wrote:You can reverse the direction of the stepper by just flipping the connector around. No need to move wires.
True, that works because it's a triple reverse. Once each for each reversed coil, and again for swapping the coils. Of course, that means moving all four wires when you use a keyed connector that prevents flipping.
Qdeathstar
Geneb,
all i can see is this:
Recommended motor current setting: 1.2A
E-steps setting: 492.45 steps/mm
So your question is answered.
Qdeathstar
I was also wondering about max extrusion speed/acceleration
Also, the qr is noticeabley louder than the stock extruder, is that expected? I relocated it to the top plate to get it out of the heat chamber so maybe that's why. On retraction it sound like someone is taking a 2x4 to my machine.
Tincho85
Post by Tincho85 »
I dont think it shpuld make any noise at all.
That might be the vibration. Add some cork or rubber washers between the mount and the motor. Or remove it from the mount and extrude some plastic, just to test.
I don't have a bond tech. But my geared extruder did make some noise when printing. Now that it's on a flying extruder setup is absolutely silent.
Martín S.
