USB to Printer stopped connecting (Rostock Max v2, OSX)
Posted: Fri Jul 15, 2016 12:21 pm
by benjaminhill
It use to work: I printed the fan shroud successfully.
But today, it won't connect from my laptop to the printer.
So I remove the printer profile, created a new one, get to the "Attempting to Connect" step, and it stops there.
Rambo board has a single green LED, not sure if there is any other diagnostics to make sure it is ok.
I've tried a cold reboot of everything.
OSX: MatterControl Build 1.5.0.6722
Re: USB to Printer stopped connecting (Rostock Max v2, OSX)
Posted: Sat Jul 16, 2016 6:14 am
by AlanZ
Have you tried using another USB port on your computer? Is the computer seeing the device at all?
Posted: Mon Jul 18, 2016 6:29 pm
by RandomFactor
I've had this problem. Sometimes, after restarting your mac, the usb port the printer is plugged into gets mapped to a different com port. Edit the printer profile and select the available port, (not at my mac right now so I can't give sample port path). I get this 2 out of 3 times I restart my mac. I don't seem to have that problem when I just sleep it.
