I'd like to implement a redundant thermistor. Good idea or bad idea?
Posted: Sat Jul 16, 2016 6:40 am
So last night I was heating up my hot end (Prometheus V2) for a print. I looked at my computer for a couple of minutes, turned around, and saw plastic (PLA) oozing out of my hot end like water. I immediately cut power and pointed the little table fan I have next to my printer at the hot end and turned it on since the hot end fan was off after I cut power to the printer. After inspecting, I saw that one of my thermistor wires had broken and the heater ran away. My reported temp was something like 12°C. This kind of freaked me out, since sometimes I let my printer do it's thing overnight.
So I was thinking, would it feasible to attach a second thermistor and program the Arduino to cut power to the hot end if it reaches a certain temp? Or perhaps use the same thermistor and program the Arduino to cut power to the hot end if the thermistor reports below a certain temperature value? At room temp my thermistor reports about 25°C. So I thought that perhaps I could make it cut hot end power if the temperature reported is below, say, 18°C?
I eventually want to build an enclosure and include a fire suppression system, simply because I know that also covers other possible causes of a fire. But I know the thermistors have delicate wires, and if there were to be a fire, it seems like it'd be the most probable culprit. I've played around with programming Arduinos here and there, but I don't want to just take a stab at it and end up having my printer walk off into the night or become sentient or something. Lol So how difficult would this be to implement in either configuration? If it's not too difficult, it might even be a decent safety feature to implement -- a fail-safe in case of thermistor failure.
I've already ordered a new thermistor and heater cartridge for the hot end. The heater still works, but I don't know if it was damaged in any way and it looks a little haggard. I also ordered a second hot end so I could more easily swap between nozzle sizes.
Anyway, thoughts? Lol
