So I've now got two Prometheus V2 hot ends with two different nozzles so that I can easily swap between them on my Metal Max. I installed my 0.4mm hotend earlier in place of the 0.6mm, and the 3 layer fans sit lower than the 0.4mm nozzle
  (the 0.4mm configuration has a smaller melt zone and the nozzle sits a bit higher). I'm trying to figure out an easy solution for also swapping between layer fan heights. Is there an adjustable fan mount or something out there?
I'm also using a 713maker hotend mount.
If it helps, here is an album that shows everything in case I didn't clearly describe my platform/hotend/mount situation.
http://imgur.com/a/qw1Jn"I rather believe that time is a companion who goes with us on the journey and reminds us to cherish every moment because they'll never come again. What we leave behind is not as important as how we've lived. After all... we're only mortal."-JLP
