First Print
Posted: Mon Jul 25, 2016 7:26 am
by TwoTone
Re: First Print
Posted: Mon Jul 25, 2016 8:18 am
What material did you print the part in? That will change the advice, slightly.
Re: First Print
Posted: Mon Jul 25, 2016 8:36 am
by TwoTone
ABS with the stock settings in the user guide.
Re: First Print
Posted: Mon Jul 25, 2016 11:01 am
by KAS
For the first picture, It's the model design. View the slicer output and see if that very edge is floating in air. Printing with supports might help it, but that usually makes the surface look worse.
The rest of it looks like slight over extruding. Overall it looks good.
Re: First Print
Posted: Mon Jul 25, 2016 11:20 am
Agree. You could lower the temp, or go with slightly thinner layers to make the overhang a little cleaner. The blobs look like slight over extrusion.
Great looking first print. I wish mine came out that nice when I first got started :)
Re: First Print
Posted: Mon Jul 25, 2016 12:21 pm
I agree with Jim, your first print looks great compared to mine. Some tweaking with your slicer should help to fix the print.
Re: First Print
Posted: Mon Jul 25, 2016 2:56 pm
by TwoTone
Thanks for the complements, credit goes to the user guide. We'll try your suggestions on the layer fan shroud and see how that turns out.
