Used Rostockmax v2 want to upgrade arm questions
Posted: Wed Jul 27, 2016 12:24 pm
by deadpool66
Hi,
I picked up a used Rostock on craigslist with a clogged hotend. I fixed it up and ran a few prints and everything was good until I came down stairs and one of the arms had popped off the rod got past the washer somehow.
My question is how can I tell if I have the old or new cheapskates? I know the arms are not the ball cup versions.
Re: Used Rostockmax v2 want to upgrade arm questions
Posted: Wed Jul 27, 2016 12:38 pm
by rubiks24
post up a picture and we be glad to identify it for you.
Posted: Wed Jul 27, 2016 12:40 pm
Even without a picture you are most likely using the old arms and the old cheapskates.
You can purchase the new cheapskates and the latest ball end arms at Seemecnc.com
Happy Printing!
Posted: Wed Jul 27, 2016 12:47 pm
by Xenocrates
If they are flat, they are the old ones. If they are clear (assuming they aren't painted), those are the new ones. If it has 3 wheels, it's a trick truck.
Posted: Wed Jul 27, 2016 1:55 pm
by Jimustanguitar
Posted: Wed Jul 27, 2016 3:55 pm
by deadpool66
Posted: Wed Jul 27, 2016 5:17 pm
by Tincho85
Hi, be aware that if you have the u-joint platform/carriages, the Repetier firmware from the GitHub page will not work as a direct update.
Some values regarding the delta geometry needs to be modified.
Posted: Wed Jul 27, 2016 11:26 pm
by deadpool66
Looks like my cheapskates are right do I need to anything special if I wanna use the new arms.
Going to order what I need to tomorrow.
Thanks for the quick help!
Posted: Wed Jul 27, 2016 11:30 pm
by Xenocrates
Nope. Just the Ball cup delta arm kit, and some time adjusting firmware values.
Posted: Thu Jul 28, 2016 10:21 am
by deadpool66
One last question which firmware values do I change. Do I do this from the computer or can I change them from the lcd menu.
Sorry if this sounds ignorant I have only been 3d printing for a few months and although this is my second machine I did not do the initial building or firmware installation.
Posted: Thu Jul 28, 2016 4:19 pm
Once you've got the new arms installed, grab the current user manual for the v2 and follow the instructions. You'll be fine.
