Firmware updates
Firmware updates
I purchased and set up my Max V2 around July 10th. From looking at the github account I see they are constantly tweaking the firmware and making small improvements. Is it worth reflashing and updating from time to time, or are there announcements when major changes are made to the firmware?
Re: Firmware updates
https://github.com/seemecnc/Repetier-091-ROSTOCKMAX
Doesn't look like there have been firmware changes since you built your machine last month.
I was looking here, https://github.com/seemecnc/Firmware, and noticed in the configuration.h that it shows the firmware as v92.2. I wasn't sure if this was different from the other repo labeled v91.
Supposedly, all of the SeeMeCNC printers will be using that location for firmware, instead of having individually tailored firmware. On that note, It looks like this recent update was to lower the current to the extruder motor for the ERIS printer.
I am using 92.9
Was there much of a difference from 91 to 92
