Page 1 of 2
First look at the new EZR Struder!
Posted: Wed Aug 03, 2016 8:14 am
by Jimustanguitar
I was lucky enough to get my paws on one of the brand new EZR Struders, and I thought you guys would want to have a sneak peek at it, too!
http://www.youtube.com/watch?v=cWQb-NzpYU8
If I missed any angles that you want to get a better look at, just let me know and I'll post some pictures.
Re: First look at the new EZR Struder!
Posted: Wed Aug 03, 2016 8:15 am
by Jimustanguitar
Anybody know why I can't embed it correctly? It seems pickier than usual this time.
Posted: Wed Aug 03, 2016 8:16 am
Dammit Jim, you beat me to posting your video.
Thanks for taking the time to make it!
Posted: Wed Aug 03, 2016 10:00 am
What happened to the video? The link no longer works.
Posted: Wed Aug 03, 2016 11:38 am
by jjjohnson
Hey guys, here is the assembly guide for the EZR Struder. This will give you and idea of the assembly process and how simple it is.
http://seemecnc.dozuki.com/Guide/EZR+Struder/42
Posted: Wed Aug 03, 2016 12:25 pm
by Tincho85
This is just pure evil, still no video!
Come on Jim, upload it again.
Posted: Wed Aug 03, 2016 12:32 pm
by Mac The Knife
Tincho85 wrote:This is just pure evil, still no video!
Try the link,,,,
https://youtu.be/cWQb-NzpYU8
by Jimustanguitar
It's there now. We had an edit to make, and it took 3 hours to upload and process again.
Posted: Wed Aug 03, 2016 12:35 pm
by Tincho85
Sweet, thanks! I did try the link but I guess it was just not proper timing hehe
Watching it right now.
Posted: Wed Aug 03, 2016 1:01 pm
by Jimustanguitar
Still not sure what's going on with the embedded player. It's working on other boards and on Facebook just fine...
Posted: Wed Aug 03, 2016 2:29 pm
by KAS
Posted: Wed Aug 03, 2016 8:11 pm
by U.S. Water Rockets
That looks promising. I messed around with some semi flexible filament a while ago, and I had to make a custom bit of PTFE tube that went right to the edge of the hobbled gear, because the stock EZStruder was forcing it every which way but down the Bowden.
Posted: Thu Aug 04, 2016 2:11 am
by 626Pilot
Great!!! But - will it accommodate the same width of drive gear as the old EZStruder? I'm using one
from TriDPrinting (12.5mm OD) that goes with their geared stepper's 8mm shaft. You really need a geared stepper for hot ends like the Cyclops. I'd love it if I could swap this in and get that fully supported filament path!
Posted: Thu Aug 04, 2016 8:40 am
by PartDaddy
The PTC fitting is by John Guest. It is called a "half cartridge" fitting. John Guest is a great company and has been around for a very long time.
As for the hobbed drive gear, yes, exactly the same. John Oly will post these for sale this week! Look for them on our website.
Thanks to the Maker Hive for just doing a review video, nice !!
Posted: Fri Aug 05, 2016 3:57 pm
by Jimustanguitar
I'll probably be hooking that bad boy up over the weekend. Any specifics that you want me to take a closer look at?
I brought the new extruder to The Hive last night, and everybody that inspected it closely was pleased with it and eager to hear about how it works.
by Glacian22
Looks nice! I particularly like the completely constrained filament path and linear spring mechanism!
Posted: Fri Aug 05, 2016 4:58 pm
by Jimustanguitar
Me too. We'll see if I can print flexibles like the guys were able to do the other day.
https://www.facebook.com/seemecnc/photo ... 74/?type=3
Posted: Fri Aug 05, 2016 7:55 pm
by Qdeathstar
Hi jim,
How much did it cost you?
Posted: Fri Aug 05, 2016 10:24 pm
by Mac The Knife
Qdeathstar wrote:Hi jim,
Maybe not him. but for you....
https://www.seemecnc.com/collections/pa ... ezrstruder
Posted: Sat Aug 06, 2016 7:27 am
by PartDaddy
Posted: Sat Aug 06, 2016 6:18 pm
by AlanZ
I just ordered two of them. One for my Eris, hopefully will make loading much easier, and avoid some feed problems I have been having. If that works out well, the other will go on my Max 2 which has a longer than stock Bowden tube because I mounted the extruder outside of my enclosure. Looks like a nice upgrade, and hope it comes stock on new units.
Posted: Sat Aug 06, 2016 6:23 pm
by AlanZ
Is the stock configuration of the Bowden tube on the Eris long enough to fully seat into the new EZStruder, or do I need a longer tube?
Posted: Sat Aug 06, 2016 6:25 pm
by Mac The Knife
After replacing the tube in mine, I would say yes if you feed the tube through the wire sleeve.
Posted: Sat Aug 06, 2016 9:18 pm
by AlanZ
Mac, I don't quite understand your answer. Does the existing Eris tube need to be rerouted and exit the sleeve in a different place to add some slack?
Posted: Sat Aug 06, 2016 9:25 pm
by Qdeathstar
oh... he didn't say he got it for free in the review.... $35 isn't bad..
