Prints randomly turn out bumpy with weird skips on contour
Posted: Mon Aug 15, 2016 7:06 pm
It is a little hard to describe what is happening other than randomly the prints will have a layer (or multiple layers!) that will not be consistent with their previous ones, and I know this is not a slicing related issue as the model looks smooth in the slicer. I am not sure if there is any "slip/stick" in the delta arms ball joints and is causing this or if this is related to something TOTALLY different. The other issue is that it will occur randomly, so one print will go fine... next one... not as well. Hopefully the images will help explain this phenomenon!
https://goo.gl/photos/Cy1wfprwJNinhEvp7
https://goo.gl/photos/tzPoWSVfYiXysXtG9
Here are the settings:
Model sliced in Cura
RostockV2 with E3DV6 hot end with .8 nozzle
.72 layers
printed in Taulman T-glase
15MM/S print speed
240C nozzle
Thanks
Maker Dude
.72 layers
15MM/S print speed
240C nozzle
Thanks
Maker Dude
