Happy to have just finished building my Rostock Max v2, my first 3D printer
I'm currently printing my fan shrouds, but I've run into an odd issue with my LCD. Part way through my first print, the LCD went blank. Not off, it is still backlit, but nothing shows up, not even the two lines of blocks. The print continued without issue, so it only seems to be the screen itself that's affected. I checked the forums and thought I must have blown a fuse on the RAMBo, but when I turn the machine off, then back on, the LCD operates normally. It has gone blank several times, and it seems pretty random. I've had a print go through completely without it cutting off, and other times it went blank shortly after starting up the machine.
The only thing it seems to possibly tie to is the fan on the power supply itself (not the fan attached to the side plate). It seems to go blank when that fan comes on, and once that happens the LCD won't display until the machine is power cycled.
I checked my connections and nothing seemed to be obviously loose or out of place.
Any idea what's going on? Could this still be a fuse issue?
EDIT: I just discovered that disconnecting and reconnecting within MatterControl gets the screen to work again if it's blank. Still not sure why
