Hello From Maine!
Posted: Mon Aug 22, 2016 7:41 am
I just ordered the Rostock Max and I am looking forward to putting it together. I also ordered an E3D V6 hotend which I will put on the machine at some point after the initial build. I used my current printer to print the fan shrouds out of ABS yesterday.
I had a Printrbot Simple that I put together as a kit and sold to a friend of mine. Building and setting up the Prinrbot helped me finish a home built machine that uses an OrdBot Hadron frame. I run that printer with a Smoothie Board now, a printrbot extruder, an E3D V6 hotend, I have an LCD on it, and a custom glass bed that uses a silicone mat heater that heats up fast and runs on 12V. I have a small CNC table top mill I use to make aluminum parts when needed and I designed a plasma table which I use a Hypertherm 45 on to cut steel. It is an X-Y machine with a manual Z setting. I really enjoy working with machines. I run Mach3 on my CNC and my Plasma table and I am using Cura on my printer I run now, I have used Repettier and I am looking forward to using MatterControl on this new printer.
I designed an RJ45 cable lock, that I print, and sell to the company I work for since we were not able to find one on the open market that worked for our application in our retail stores. So this new printer will be a business write off.
Enough of all this about me- I look forward to talking with you all!!!!!!!
