Tower Angles to bed
Posted: Mon Aug 22, 2016 3:08 pm
				In an attempt to make my Max V2 build more accurate I recently bought a digital angle measurement tool (dunno the English term  ) I am measuring the tower angles against the printbed (vertical alignments) and are measuring X=89.8  / Y=90.2  /  Z=89.9 degrees. That is not as bad as I supposed it was but I have no reference. Are these values I should live with or do I need to make improvement?
Can someone point me to an easy to follow method for correcting these angles, and to a method to check the horizontal alignment of the towers?
 ) I am measuring the tower angles against the printbed (vertical alignments) and are measuring X=89.8  / Y=90.2  /  Z=89.9 degrees. That is not as bad as I supposed it was but I have no reference. Are these values I should live with or do I need to make improvement? Can someone point me to an easy to follow method for correcting these angles, and to a method to check the horizontal alignment of the towers?
