Hi all
After upgrading arms, effector platform, hot-end and carriages I am having some calibration issues. I can get things going well enough to print good with small diameter items - but it goes bad when I move to larger items.
I think the problem is related to the DELTA_RADIUS and related settings, which I admit I don't understand very well. If I reset and start my calibrations steps from scratch (set Z-height, and then run the Tower Calibration macros in MatterControl) the X and Z towers are very close, but the Y tower is well over 5mm too high. I can correct this with the end-stop screw, but this variation seems way too high.
Is there a good article that can explain these settings in detail so I can troubleshoot?
Y Tower Calibration Issue
Rostock Max V2. E3D V6 Hotend. E3D Titan Extruder. TrickLaser Carbon Fiber 300mm Arms. TrickLaser MaxMetal Platform. TrickLaser Trick Trucks. TrickLaser Heat Spreader. TrickLaser LED Light Ring. MeanWell SP-500-24. Simplify3D.
Re: Y Tower Calibration Issue
Hey there,
I recently had a similar problem which in the end was due to my belts not being tensioned enough on the Z tower. This caused the belt to slip as the stepper tried to turn. Its a simple thing to try just in case.
This was where I asked for help, there are other suggestions in there you might want to try.
http://forum.seemecnc.com/viewtopic.php?f=77&t=10656
Matt
Matt
