E3D-V6 hotend tip
Posted: Sun Sep 04, 2016 2:29 pm
by TwoTone
Instead of using the thermister that came with the hotend, we're using one of these
http://www.ebay.com/itm/M3-Stud-Thermis ... SwxcRW8gNv screwed into the M3 screw hole you use to hold in the stock thermistor. Much cleaner setup in my opinion. The screw hole is a little deeper than the screw in thermistor, so we used Arctic Silver to fill that void.
Don't forget the make sure the EXT0_TEMPSENSOR_TYPE is set to 1.
Been working great so far.
Re: E3D-V6 hotend tip
Posted: Sun Sep 04, 2016 2:33 pm
Thanks for reminding us. This has been discussed a great deal on this forum but a reminder is always good!
Posted: Sun Sep 04, 2016 9:56 pm
by TwoTone
Thought I'd throw it out there since in researching some questions I had, still see recent posts with people using the stock one which we found a PIA.
Posted: Sun Sep 04, 2016 10:04 pm
by Xenocrates
It's a nice tip for the older V6's, but it won't work for the new V6's, as they use a cartridge thermistor like the PT100 or new thermocouple's. (Interesting that they' didn't increment the version for that big of a change, but hey). I agree for the V5 and V6's without a cartridge socket. I do think the cartridge is a major improvement though.
Posted: Sun Sep 04, 2016 11:27 pm
by TwoTone
I meant to email them and ask when that change happened. Our hotend isn't that old and it's the old style.
Posted: Mon Sep 05, 2016 1:24 am
by Xenocrates
about 2 months ago, if the blog post was released at the swap over point.
Posted: Tue Sep 06, 2016 2:37 am
by dc42
You can switch over to the cartridge thermistor, or PT100 sensor, or thermocouple, by purchasing the new heater block.
Posted: Tue Dec 06, 2016 1:24 am
by ExplodedZombie
I have been using one of the M3s I got off ebay that provided this table:
http://reprap.org/wiki/Thermistor#EPCOS ... 0G1104F.29
I should definitely be using sensor_type 1? I left it at 8 like E3d tutorial said...is that why my heat seems to be a little off pretty much always? My print results are a bit whack.
Posted: Tue Dec 06, 2016 2:21 pm
by Xenocrates
ExplodedZombie wrote:I have been using one of the M3s I got off ebay that provided this table:
Always use the correct profile for a given sensor. If you change the sensor, use the table provided for the new sensor. I have no idea if 1 is the correct one for that sensor. I don't believe it is though. Use one of the user tables with that profile in it when in doubt. Then confirm it with a thermocouple (These can be had in a number of forms. A popular one is finding a ~30$ multimeter that includes one). There are guides for adjusting the Beta values to match the actual part once you can profile it with a thermocouple on these forums if you search.
Posted: Thu Dec 08, 2016 7:14 pm
by ExplodedZombie
I looked it up and I do believe the Sensor_Type is 1. "confirmed" by reading a Delta Printer book I got off Amazon. I'm going to try it tonight and see if my results are more accurate than the previous setting of 5.
From the book:
" 1 is 100k thermistor - best choice for EPCOS 100k (4.7 pullup)"
I think that sounds right.
This sounded wrong to me:
"5 is for 100k thermistor - ATC Smitec 104GT-2 (Used in ParCan & J-Head (4.7k pullup)"
