problem on z axix
Posted: Sat Sep 17, 2016 11:01 am
by CAMY014
My eris delta 3d printer somehow works on the last couple of days but he can not build on z axix properly and i attached a picture to clearly show the problem. What is wrong and how to fixit, solutions please if you have them!! thank you indeed.
Re: problem on z axix
Posted: Mon Sep 19, 2016 10:03 am
by lightninjay
It appears as though your image did not post properly.
If you are having Z axis issues, assuming that it is a problem with layer alignment, check the tension of your belts and that the umbilical cable can not snag on any of the arms.
Once the image is posted, diagnosis of your problem will be much easier.
Posted: Tue Sep 20, 2016 12:30 am
by CAMY014
thank you!
