Cura +or KISSLICER Settings for LinuxCNC (EMC2)
Posted: Sat Jan 26, 2013 7:33 pm
by tom10122
When it comes to g-code I know nothing, I know basic settings about slic3r , kiss, cura ect. But I can't figure out what settings to use with linuxcnc to get the code to run. Ayone running it with EMC2?Can someone plz post a config?
Re: Cura +or KISSLICER Settings for LinuxCNC (EMC2)
Posted: Sat Jan 26, 2013 9:51 pm
tom10122 wrote:When it comes to g-code I know nothing, I know basic settings about slic3r , kiss, cura ect. But I can't figure out what settings to use with linuxcnc to get the code to run. Ayone running it with EMC2?Can someone plz post a config?
You'll probably have to write a program to post process the GCode.
You might get away with it in the latest KissSlicer if you're extruder axis is mapped to E, because the configuration requires you enter GCode fragments for all, of the unusual cases. But without a knowledge of GCode, it's not going to be easy.
Posted: Sat Jan 26, 2013 9:57 pm
by tom10122
Sadly, its mapped to A, can i just change that ?
