Uneven Print Thickness
Posted: Sun Oct 09, 2016 5:34 pm
Hello,
I seem to having some issues that I can't figure out with the Rostock Max v3 running prints off MatterControl 1.5.
While printing the first layer, it seems like the nozzle is too close to the glass towards the y/z-column, and too far from the glass towards the x-column.
https://postimg.org/image/uorrma083/
https://postimg.org/image/9qllo70df/
I've done some 13 point leveling calibrations but it doesn't seem to work.
One thing I did notice was that if I swapped around the delta arms, the errors would occur in the same place. However, if I rotated the hotend itself, the error would change location. My best print so far was done with the fan of the hotend pointing to the Z axis vs the X axis like in the first 2 photos.
https://postimg.org/image/dpit70p0j/
While this print is much better overall, there is noticable thinness towards the are between the X and Y columns and thickness between the X and Z columns.
I've tried releveling the glass bed but I noticed that even rotating the whole hotbed itself does not rotate the areas of thinness so I concluded that the bed itself was not the issue.
Can anyone help?
Thanks,
Can anyone help?
Thanks,
