Extra wiring?
Posted: Mon Oct 17, 2016 12:33 pm
by jlvter
Can someone tell me what this is for? Seems to be an extra included with my V3 kit.
Re: Extra wiring?
Posted: Mon Oct 17, 2016 12:58 pm
by pswindler
that is so you can power your raspberry pie from the rambo board. if you dont have a pi, then you dont need it
Re: Extra wiring?
Posted: Mon Oct 17, 2016 1:10 pm
by jlvter
Great, I was hoping it was for the pi. In step #12 in the guide an arrow points to a Micro USB for power. Where does it connect to Rambo?
Re: Extra wiring?
Posted: Mon Oct 17, 2016 1:22 pm
by pswindler
nope! they dont include that with the v3 kit, you connect the printer using the usb cable and the power using that cable and your good to go, i can take a picture when i get home if you want to see the connection points i have been using, but i am not sure if they are the best, but they work great for me.
Re: Extra wiring?
Posted: Mon Oct 17, 2016 3:20 pm
by jlvter
That would be great, thanks.
Re: Extra wiring?
Posted: Mon Oct 17, 2016 8:52 pm
by pswindler
the three terminal end goes here on the pie.
Re: Extra wiring?
Posted: Mon Oct 17, 2016 8:55 pm
by pswindler
the two terminal end goes here on the rambo, if there is a better place to connect i would like to know it, i found this just measuring for a 5v output with my voltmeter. you see there is a - and + marked below the connect, make sure those are mached to the pi!!!
Re: Extra wiring?
Posted: Mon Oct 17, 2016 8:56 pm
by pswindler
pick did not post
Re: Extra wiring?
Posted: Mon Oct 17, 2016 8:57 pm
by pswindler
closer look
Re: Extra wiring?
Posted: Mon Oct 17, 2016 9:57 pm
by jlvter
Beautiful! Thanks.
Re: Extra wiring?
Posted: Mon Oct 17, 2016 11:24 pm
by jlvter
@pswindler: Worked great. Got Octopi working tonight and am printing a test with the PLA profile that was in a thread posted by mhackney.
Thanks again.
Re: Extra wiring?
Posted: Wed Oct 26, 2016 7:58 am
by crocky
Still going alright?
I think I am going to power it from the Rambo too...
jjjohnson may have better pins to use if he is watching :)
Re: Extra wiring?
Posted: Wed Oct 26, 2016 11:57 am
by ido3dprintz
Fantastic! Thanks for this info
Re: Extra wiring?
Posted: Sun Nov 06, 2016 5:13 am
by joemod
FYI... not counting out that I misinterpreted something in the images...
Effectively I'm 100% positive I fried my Rambo. I know something went wrong when I saw a puff of smoke. Homing my printer now results is terrible step skipping on the belts.
I'm chalking this up to a learning experience. Just throwing this out there for others. If you see smoke, you wired it wrong and just stop there :shock: Order a new rambo and move on with life... :o
Re: Extra wiring?
Posted: Sun Nov 06, 2016 10:18 am
by Xenocrates
joemod wrote:FYI... not counting out that I misinterpreted something in the images...
It's impressive that it's still trying to home after something like that, even if it's doing badly. Have you found where the smoke came out of yet?
Re: Extra wiring?
Posted: Mon Nov 21, 2016 12:03 am
by joemod
I've gotten wrapped up in other projects. Once I get my printer operating again, I'll do a post mortem on the board and post what I find.
Re: Extra wiring?
Posted: Tue Nov 22, 2016 1:33 am
by joemod
I did a quick comparison of the old vs new Rambo boards. Nothing is visually different, as in char marks. Considering everything else works, LCD, controls, steppers; must just be the pins wired up to the limit switches.
New board is installed, and all is well again. Decided to power the RaspberryPI from the 5v aux pins next to the power connector on the Rambo. Working well so far.
I'm hanging onto the old one in hopes that I'll get inspired to debug it further.
Re: Extra wiring?
Posted: Mon Dec 05, 2016 6:17 am
by crocky
Just got mine finished and fired up on octoprint tonight and doing a test print remotely... All powered from the Rambo must remember to close octoprint before turning off the printer :)
