Z probe communication error
Posted: Fri Oct 21, 2016 7:27 pm
by NormL1
I have searched for this on the forums and haven't found an answer, so, if I am blind in both eyes, I apologize.
Whenever I try one of the calibration scripts, v3probing or the one on the forums by the same name, I get a z-axis communications error. I get the error at the same juncture every time. It will probe the surface near each axis without issue, re-center on top and then come down and probe the center and that is when the error comes.
I asked SeeMeCNC and they said it was a lose connection. I looked at the Z end stop switch and nothing lose, but, I re-seated them anyway. I looked at the Rambo board and the connections are solid. I traced the wires and they are not compromised. This error first appeared two weeks after the build and after numerous uses.
Any ideas where to look?
Re: Z probe communication error
Posted: Fri Oct 21, 2016 7:29 pm
The connector on the HE280 (the 8 pin connector with the push in wires) is the likely suspect.
Posted: Fri Oct 21, 2016 7:34 pm
by NormL1
Thanks, I will start some conductivity tests.
Posted: Fri Oct 21, 2016 7:37 pm
It is likely intermittent. The cable flex as the nozzle lowers could cause a momentary open circuit. You might just have to reseat everything and make sure the connector is well seated and test.
Posted: Fri Oct 21, 2016 7:41 pm
by NormL1
I did that immediately and still got the error, which is why I was going to switch to conductivity. Your point is valid though, so, maybe I need to forum search for strain relief
