Setting Hot End temp
Twac1
Post by Twac1 »
So how do you set your temp on your hot end? I've been trying different filaments and brands. And I'm able to get my ABS and PLA pretty close to printing well . If I turn my hot end on, and manually feed the filament, how fast should it come out for correct temp? How much pressure is too much?
morgandc
Re: Setting Hot End temp
Post by morgandc »
I was reading another post that talked about that a bit, but sounded like you gained that "touch" by experience. This link may help establish a good temp by the results rather than feel. http://forum.seemecnc.com/viewtopic.php?f=36&t=7361
Good luck!
Return to “Filament”
