Page 1 of 2
Upgrade from v2 to v3 , problems with homing and code compilation.
Posted: Sun Oct 23, 2016 4:08 pm
by gdgonzo
Hello All!
So I have upgraded my Rostock max v2 with a new head + calibration, along with new ball arms + sleds. The problem I have it two-fold. When I try and home the arms, they all start a very quick decent to the heated plate, unless I kill it before it reaches ( and it will reach ). I thought that this might be a problem with the firmware, I have already inverted the Y axis as is specified in a few places, but when I try and invert these:
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 0
( which I think would fix my problem ) , I can no longer compile the code, as I get this error:
ui_menu_conf_delta was not declared in this scope.
Arduino: 1.6.12 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/Configuration.h:56:0,
                 from sketch/Repetier.h:185,
                 from sketch/Commands.cpp:22:
sketch/pins.h:1946:12: warning: extra tokens at end of #ifdef directive
 #ifdef MINI-RAMBO
sketch/pins.h:2279:0: warning: "PS_ON_PIN" redefined
 #define PS_ON_PIN ORIG_PS_ON_PIN
sketch/pins.h:1979:0: note: this is the location of the previous definition
   #define PS_ON_PIN          -1
In file included from sketch/Repetier.h:185:0,
sketch/Configuration.h:87:0: warning: "FAN_BOARD_PIN" redefined
 #define FAN_BOARD_PIN 6  // ERIS Case Fan pin
sketch/pins.h:2217:0: note: this is the location of the previous definition
 #define FAN_BOARD_PIN -1
sketch/Configuration.h:629:0: warning: "PS_ON_PIN" redefined
sketch/pins.h:2279:0: note: this is the location of the previous definition
In file included from sketch/Commands.cpp:22:0:
sketch/Repetier.h:187:0: warning: "GCODE_BUFFER_SIZE" redefined
 #define GCODE_BUFFER_SIZE 1
sketch/Configuration.h:624:0: note: this is the location of the previous definition
 #define GCODE_BUFFER_SIZE 2
In file included from sketch/ui.h:222:0,
                 from sketch/Repetier.h:360,
sketch/uilang.h:1598:0: warning: "UI_TEXT_PRINT_POS" redefined
 #define UI_TEXT_PRINT_POS        "Percent Printed:"
sketch/uilang.h:103:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_POS        "Printing..."
sketch/uilang.h:1609:0: warning: "UI_TEXT_IDLE" redefined
 #define UI_TEXT_IDLE             "RostockMAX Ready"
sketch/uilang.h:105:0: note: this is the location of the previous definition
 #define UI_TEXT_IDLE             "Idle"
sketch/uilang.h:1615:0: warning: "UI_TEXT_BACK" redefined
 #define UI_TEXT_BACK             "Previous Screen " cUP
sketch/uilang.h:108:0: note: this is the location of the previous definition
 #define UI_TEXT_BACK             "Back " cUP
sketch/uilang.h:1616:0: warning: "UI_TEXT_QUICK_SETTINGS" redefined
 #define UI_TEXT_QUICK_SETTINGS   "Printer Settings"
sketch/uilang.h:109:0: note: this is the location of the previous definition
 #define UI_TEXT_QUICK_SETTINGS   "Quick Settings"
sketch/uilang.h:1617:0: warning: "UI_TEXT_CONFIGURATION" redefined
 #define UI_TEXT_CONFIGURATION    "Advanced Settings"
sketch/uilang.h:110:0: note: this is the location of the previous definition
 #define UI_TEXT_CONFIGURATION    "Configuration"
sketch/uilang.h:1621:0: warning: "UI_TEXT_SD_CARD" redefined
 #define UI_TEXT_SD_CARD          "SD Card Menu"
sketch/uilang.h:114:0: note: this is the location of the previous definition
 #define UI_TEXT_SD_CARD          "SD Card"
sketch/uilang.h:1623:0: warning: "UI_TEXT_HOME_ALL" redefined
 #define UI_TEXT_HOME_ALL         "Home Printer"
sketch/uilang.h:117:0: note: this is the location of the previous definition
 #define UI_TEXT_HOME_ALL         "Home All"
sketch/uilang.h:1624:0: warning: "UI_TEXT_AUTOLEVEL_FULL" redefined
 #define UI_TEXT_AUTOLEVEL_FULL    "Full Calibration"
sketch/uilang.h:249:0: note: this is the location of the previous definition
 #define UI_TEXT_AUTOLEVEL_FULL    "Full Auto Level"
sketch/uilang.h:1630:0: warning: "UI_TEXT_COOLDOWN" redefined
 #define UI_TEXT_COOLDOWN         "Shut Off ALL Heats"
sketch/uilang.h:124:0: note: this is the location of the previous definition
 #define UI_TEXT_COOLDOWN         "Cooldown"
sketch/uilang.h:1632:0: warning: "UI_TEXT_DISABLE_STEPPER" redefined
 #define UI_TEXT_DISABLE_STEPPER  "Disable Steppers"
sketch/uilang.h:126:0: note: this is the location of the previous definition
 #define UI_TEXT_DISABLE_STEPPER  "Disable stepper"
sketch/uilang.h:1638:0: warning: "UI_TEXT_Z_POS_FAST" redefined
 #define UI_TEXT_Z_POS_FAST       "Move Z Position"
sketch/uilang.h:132:0: note: this is the location of the previous definition
 #define UI_TEXT_Z_POS_FAST       "Z Pos. Fast"
sketch/uilang.h:1640:0: warning: "UI_TEXT_BED_TEMP" redefined
 #define UI_TEXT_BED_TEMP         "BED Temp:  %Eb" cDEG "C"
sketch/uilang.h:134:0: note: this is the location of the previous definition
 #define UI_TEXT_BED_TEMP         "Bed Temp: %Eb" cDEG "C"
sketch/uilang.h:1641:0: warning: "UI_TEXT_EXTR0_TEMP" redefined
 #define UI_TEXT_EXTR0_TEMP       "NOZ Temp:  %E0" cDEG "C"
sketch/uilang.h:135:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR0_TEMP       "Temp. 1 : %E0" cDEG "C"
sketch/uilang.h:1642:0: warning: "UI_TEXT_EXTR1_TEMP" redefined
 #define UI_TEXT_EXTR1_TEMP       "Temp. 1 :  %E1" cDEG "C"
sketch/uilang.h:136:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR1_TEMP       "Temp. 2 : %E1" cDEG "C"
sketch/uilang.h:1643:0: warning: "UI_TEXT_EXTR2_TEMP" redefined
 #define UI_TEXT_EXTR2_TEMP       "Temp. 2 :  %E2" cDEG "C"
sketch/uilang.h:137:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR2_TEMP       "Temp. 3 : %E2" cDEG "C"
sketch/uilang.h:1644:0: warning: "UI_TEXT_EXTR0_OFF" redefined
 #define UI_TEXT_EXTR0_OFF        "Shut Down Nozzle"
sketch/uilang.h:138:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR0_OFF        "Turn Extr. 1 Off"
sketch/uilang.h:1645:0: warning: "UI_TEXT_EXTR1_OFF" redefined
 #define UI_TEXT_EXTR1_OFF        "Extruder 1 Off"
sketch/uilang.h:139:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR1_OFF        "Turn Extr. 2 Off"
sketch/uilang.h:1646:0: warning: "UI_TEXT_EXTR2_OFF" redefined
 #define UI_TEXT_EXTR2_OFF        "Extruder 2 Off"
sketch/uilang.h:140:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR2_OFF        "Turn Extr. 3 Off"
sketch/uilang.h:1647:0: warning: "UI_TEXT_EXTR0_SELECT" redefined
 #define UI_TEXT_EXTR0_SELECT     "%X0 Select Extr. 0"
sketch/uilang.h:141:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR0_SELECT     "%X0 Select Extr. 1"
sketch/uilang.h:1648:0: warning: "UI_TEXT_EXTR1_SELECT" redefined
 #define UI_TEXT_EXTR1_SELECT     "%X1 Select Extr. 1"
sketch/uilang.h:142:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR1_SELECT     "%X1 Select Extr. 2"
sketch/uilang.h:1649:0: warning: "UI_TEXT_EXTR2_SELECT" redefined
 #define UI_TEXT_EXTR2_SELECT     "%X1 Select Extr. 2"
sketch/uilang.h:143:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR2_SELECT     "%X2 Select Extr. 3"
sketch/uilang.h:1655:0: warning: "UI_TEXT_MOVE_X" redefined
 #define UI_TEXT_MOVE_X           "Move X:%aX"
sketch/uilang.h:149:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_X           "Move X :%aX"
sketch/uilang.h:1656:0: warning: "UI_TEXT_MOVE_Y" redefined
 #define UI_TEXT_MOVE_Y           "Move Y:%aY"
sketch/uilang.h:150:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_Y           "Move Y :%aY"
sketch/uilang.h:1657:0: warning: "UI_TEXT_MOVE_Z" redefined
 #define UI_TEXT_MOVE_Z           "Move Z:%aZ"
sketch/uilang.h:151:0: note: this is the location of the previous definition
 #define UI_TEXT_MOVE_Z           "Move Z :%aZ"
sketch/uilang.h:1659:0: warning: "UI_TEXT_JERK" redefined
 #define UI_TEXT_JERK             "Jerk:%aj"
sketch/uilang.h:153:0: note: this is the location of the previous definition
 #define UI_TEXT_JERK             "Jerk   :%aj"
sketch/uilang.h:1660:0: warning: "UI_TEXT_ZJERK" redefined
 #define UI_TEXT_ZJERK            "Z-Jerk:%aJ"
sketch/uilang.h:154:0: note: this is the location of the previous definition
 #define UI_TEXT_ZJERK            "Z-Jerk :%aJ"
sketch/uilang.h:1663:0: warning: "UI_TEXT_LOAD_EEPROM" redefined
 #define UI_TEXT_LOAD_EEPROM      "Load from EEPROM"
sketch/uilang.h:157:0: note: this is the location of the previous definition
 #define UI_TEXT_LOAD_EEPROM      "Load f. EEPROM"
sketch/uilang.h:1671:0: warning: "UI_TEXT_OPS_RETRACT" redefined
 #define UI_TEXT_OPS_RETRACT      "Retract :%Or"
sketch/uilang.h:165:0: note: this is the location of the previous definition
sketch/uilang.h:1672:0: warning: "UI_TEXT_OPS_BACKSLASH" redefined
 #define UI_TEXT_OPS_BACKSLASH    "Backsl. :%Ob"
sketch/uilang.h:166:0: note: this is the location of the previous definition
sketch/uilang.h:1673:0: warning: "UI_TEXT_OPS_MINDIST" redefined
 #define UI_TEXT_OPS_MINDIST      "Min.dist:%Od"
sketch/uilang.h:167:0: note: this is the location of the previous definition
 #define UI_TEXT_OPS_MINDIST      "Min.dist  :%Od"
sketch/uilang.h:1676:0: warning: "UI_TEXT_PRINT_FILE" redefined
 #define UI_TEXT_PRINT_FILE       "Select SD File"
sketch/uilang.h:170:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_FILE       "Print file"
sketch/uilang.h:1704:0: warning: "UI_TEXT_FANSPEED" redefined
 #define UI_TEXT_FANSPEED          "Adjust Fan speed"
sketch/uilang.h:198:0: note: this is the location of the previous definition
 #define UI_TEXT_FANSPEED          "Fan speed"
sketch/uilang.h:1710:0: warning: "UI_TEXT_FAN_FULL" redefined
 #define UI_TEXT_FAN_FULL          "Set Fan 100%%%"
sketch/uilang.h:204:0: note: this is the location of the previous definition
 #define UI_TEXT_FAN_FULL          "Set Fan Full"
sketch/uilang.h:1749:0: warning: "UI_TEXT_SPEED_MULTIPLY" redefined
 #define UI_TEXT_SPEED_MULTIPLY    "Speed Rate:%om%%%"
sketch/uilang.h:243:0: note: this is the location of the previous definition
 #define UI_TEXT_SPEED_MULTIPLY    "Speed Mul.:%om%%%"
sketch/uilang.h:1750:0: warning: "UI_TEXT_FLOW_MULTIPLY" redefined
 #define UI_TEXT_FLOW_MULTIPLY     "Flow  Rate:%of%%%"
sketch/uilang.h:244:0: note: this is the location of the previous definition
 #define UI_TEXT_FLOW_MULTIPLY     "Flow Mul. :%of%%%"
sketch/uilang.h:1751:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_TEMP" redefined
 #define UI_TEXT_EXTR_WAIT_RETRACT_TEMP  "Wait Temp.%XT" cDEG "C"
sketch/uilang.h:266:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR_WAIT_RETRACT_TEMP "Wait Temp. %XT" cDEG "C"
sketch/uilang.h:1752:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_UNITS" redefined
 #define UI_TEXT_EXTR_WAIT_RETRACT_UNITS "Wait Units:%XUmm"
sketch/uilang.h:267:0: note: this is the location of the previous definition
 #define UI_TEXT_EXTR_WAIT_RETRACT_UNITS "Wait Units: %XU mm"
sketch/uilang.h:1762:0: warning: "UI_TEXT_PRINTER_READY" redefined
 #define UI_TEXT_PRINTER_READY             "Rostock MAX v3"
sketch/uilang.h:270:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINTER_READY    "Printer ready."
sketch/uilang.h:1771:0: warning: "UI_TEXT_PRINT_TIME" redefined
 #define UI_TEXT_PRINT_TIME     "Total Printing Time"
sketch/uilang.h:276:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_TIME     "Printing time"
sketch/uilang.h:1772:0: warning: "UI_TEXT_PRINT_FILAMENT" redefined
 #define UI_TEXT_PRINT_FILAMENT "Total Filament Used"
sketch/uilang.h:277:0: note: this is the location of the previous definition
 #define UI_TEXT_PRINT_FILAMENT "Filament printed"
sketch/uilang.h:1778:32: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
 #define UI_TEXT_PAGE_FWVERSION "FW Version: "REPETIER_VERSION""
sketch/uilang.h:1779:29: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
 #define UI_TEXT_PAGE_FWDATE "FW Date: "FIRMWARE_DATE""
sketch/uilang.h:1781:0: warning: "UI_TEXT_SET_MEASURED_ORIGIN" redefined
 #define UI_TEXT_SET_MEASURED_ORIGIN "Set Z Origin"
sketch/uilang.h:248:0: note: this is the location of the previous definition
 #define UI_TEXT_SET_MEASURED_ORIGIN "Set Z=0.0"
sketch/uilang.h:1784:0: warning: "UI_TEXT_CALIBRATING_ENDSTOPS" redefined
 #define UI_TEXT_CALIBRATING_ENDSTOPS       "Calibrating","Endstop Offsets","","Please Wait"
sketch/uilang.h:252:0: note: this is the location of the previous definition
 #define UI_TEXT_CALIBRATING_ENDSTOPS       "Calibrating:","Endstop Offsets","","Please Wait"
sketch/uilang.h:1785:0: warning: "UI_TEXT_CALIBRATING_HEIGHT" redefined
 #define UI_TEXT_CALIBRATING_HEIGHT       "Calibrating","Printer Z Height","","Please Wait"
sketch/uilang.h:253:0: note: this is the location of the previous definition
 #define UI_TEXT_CALIBRATING_HEIGHT       "Calibrating:","Printer Z Height","","Please Wait"
sketch/uilang.h:1786:0: warning: "UI_TEXT_CALIBRATING_RADIUS" redefined
 #define UI_TEXT_CALIBRATING_RADIUS       "Calibrating","Horizontal Radius","","Please Wait"
sketch/uilang.h:254:0: note: this is the location of the previous definition
 #define UI_TEXT_CALIBRATING_RADIUS       "Calibrating:","Horizontal Radius","","Please Wait"
sketch/uilang.h:1787:0: warning: "UI_TEXT_CALIBRATING_BED" redefined
 #define UI_TEXT_CALIBRATING_BED       "Calibrating","Bed Level Matrix","","Please Wait"
sketch/uilang.h:255:0: note: this is the location of the previous definition
 #define UI_TEXT_CALIBRATING_BED       "Calibrating:","Bed Level Matrix","","Please Wait"
In file included from sketch/ui.h:1325:0,
sketch/uilang.h:103:0: warning: "UI_TEXT_PRINT_POS" redefined
sketch/uilang.h:1598:0: note: this is the location of the previous definition
sketch/uilang.h:105:0: warning: "UI_TEXT_IDLE" redefined
sketch/uilang.h:1609:0: note: this is the location of the previous definition
sketch/uilang.h:108:0: warning: "UI_TEXT_BACK" redefined
sketch/uilang.h:1615:0: note: this is the location of the previous definition
sketch/uilang.h:109:0: warning: "UI_TEXT_QUICK_SETTINGS" redefined
sketch/uilang.h:1616:0: note: this is the location of the previous definition
sketch/uilang.h:110:0: warning: "UI_TEXT_CONFIGURATION" redefined
sketch/uilang.h:1617:0: note: this is the location of the previous definition
sketch/uilang.h:114:0: warning: "UI_TEXT_SD_CARD" redefined
sketch/uilang.h:1621:0: note: this is the location of the previous definition
sketch/uilang.h:117:0: warning: "UI_TEXT_HOME_ALL" redefined
sketch/uilang.h:1623:0: note: this is the location of the previous definition
sketch/uilang.h:124:0: warning: "UI_TEXT_COOLDOWN" redefined
sketch/uilang.h:1630:0: note: this is the location of the previous definition
sketch/uilang.h:126:0: warning: "UI_TEXT_DISABLE_STEPPER" redefined
sketch/uilang.h:1632:0: note: this is the location of the previous definition
sketch/uilang.h:132:0: warning: "UI_TEXT_Z_POS_FAST" redefined
sketch/uilang.h:1638:0: note: this is the location of the previous definition
sketch/uilang.h:134:0: warning: "UI_TEXT_BED_TEMP" redefined
sketch/uilang.h:1640:0: note: this is the location of the previous definition
sketch/uilang.h:135:0: warning: "UI_TEXT_EXTR0_TEMP" redefined
sketch/uilang.h:1641:0: note: this is the location of the previous definition
sketch/uilang.h:136:0: warning: "UI_TEXT_EXTR1_TEMP" redefined
sketch/uilang.h:1642:0: note: this is the location of the previous definition
sketch/uilang.h:137:0: warning: "UI_TEXT_EXTR2_TEMP" redefined
sketch/uilang.h:1643:0: note: this is the location of the previous definition
sketch/uilang.h:138:0: warning: "UI_TEXT_EXTR0_OFF" redefined
sketch/uilang.h:1644:0: note: this is the location of the previous definition
sketch/uilang.h:139:0: warning: "UI_TEXT_EXTR1_OFF" redefined
sketch/uilang.h:1645:0: note: this is the location of the previous definition
sketch/uilang.h:140:0: warning: "UI_TEXT_EXTR2_OFF" redefined
sketch/uilang.h:1646:0: note: this is the location of the previous definition
sketch/uilang.h:141:0: warning: "UI_TEXT_EXTR0_SELECT" redefined
sketch/uilang.h:1647:0: note: this is the location of the previous definition
sketch/uilang.h:142:0: warning: "UI_TEXT_EXTR1_SELECT" redefined
sketch/uilang.h:1648:0: note: this is the location of the previous definition
sketch/uilang.h:143:0: warning: "UI_TEXT_EXTR2_SELECT" redefined
sketch/uilang.h:1649:0: note: this is the location of the previous definition
sketch/uilang.h:149:0: warning: "UI_TEXT_MOVE_X" redefined
sketch/uilang.h:1655:0: note: this is the location of the previous definition
sketch/uilang.h:150:0: warning: "UI_TEXT_MOVE_Y" redefined
sketch/uilang.h:1656:0: note: this is the location of the previous definition
sketch/uilang.h:151:0: warning: "UI_TEXT_MOVE_Z" redefined
sketch/uilang.h:1657:0: note: this is the location of the previous definition
sketch/uilang.h:153:0: warning: "UI_TEXT_JERK" redefined
sketch/uilang.h:1659:0: note: this is the location of the previous definition
sketch/uilang.h:154:0: warning: "UI_TEXT_ZJERK" redefined
sketch/uilang.h:1660:0: note: this is the location of the previous definition
sketch/uilang.h:157:0: warning: "UI_TEXT_LOAD_EEPROM" redefined
sketch/uilang.h:1663:0: note: this is the location of the previous definition
sketch/uilang.h:165:0: warning: "UI_TEXT_OPS_RETRACT" redefined
sketch/uilang.h:1671:0: note: this is the location of the previous definition
sketch/uilang.h:166:0: warning: "UI_TEXT_OPS_BACKSLASH" redefined
sketch/uilang.h:1672:0: note: this is the location of the previous definition
sketch/uilang.h:167:0: warning: "UI_TEXT_OPS_MINDIST" redefined
sketch/uilang.h:1673:0: note: this is the location of the previous definition
sketch/uilang.h:170:0: warning: "UI_TEXT_PRINT_FILE" redefined
sketch/uilang.h:1676:0: note: this is the location of the previous definition
sketch/uilang.h:198:0: warning: "UI_TEXT_FANSPEED" redefined
sketch/uilang.h:1704:0: note: this is the location of the previous definition
sketch/uilang.h:204:0: warning: "UI_TEXT_FAN_FULL" redefined
sketch/uilang.h:1710:0: note: this is the location of the previous definition
sketch/uilang.h:243:0: warning: "UI_TEXT_SPEED_MULTIPLY" redefined
sketch/uilang.h:1749:0: note: this is the location of the previous definition
sketch/uilang.h:244:0: warning: "UI_TEXT_FLOW_MULTIPLY" redefined
sketch/uilang.h:1750:0: note: this is the location of the previous definition
sketch/uilang.h:248:0: warning: "UI_TEXT_SET_MEASURED_ORIGIN" redefined
sketch/uilang.h:1781:0: note: this is the location of the previous definition
sketch/uilang.h:249:0: warning: "UI_TEXT_AUTOLEVEL_FULL" redefined
sketch/uilang.h:1624:0: note: this is the location of the previous definition
sketch/uilang.h:252:0: warning: "UI_TEXT_CALIBRATING_ENDSTOPS" redefined
sketch/uilang.h:1784:0: note: this is the location of the previous definition
sketch/uilang.h:253:0: warning: "UI_TEXT_CALIBRATING_HEIGHT" redefined
sketch/uilang.h:1785:0: note: this is the location of the previous definition
sketch/uilang.h:254:0: warning: "UI_TEXT_CALIBRATING_RADIUS" redefined
sketch/uilang.h:1786:0: note: this is the location of the previous definition
sketch/uilang.h:255:0: warning: "UI_TEXT_CALIBRATING_BED" redefined
sketch/uilang.h:1787:0: note: this is the location of the previous definition
sketch/uilang.h:266:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_TEMP" redefined
sketch/uilang.h:1751:0: note: this is the location of the previous definition
sketch/uilang.h:267:0: warning: "UI_TEXT_EXTR_WAIT_RETRACT_UNITS" redefined
sketch/uilang.h:1752:0: note: this is the location of the previous definition
sketch/uilang.h:270:0: warning: "UI_TEXT_PRINTER_READY" redefined
sketch/uilang.h:1762:0: note: this is the location of the previous definition
sketch/uilang.h:276:0: warning: "UI_TEXT_PRINT_TIME" redefined
sketch/uilang.h:1771:0: note: this is the location of the previous definition
sketch/uilang.h:277:0: warning: "UI_TEXT_PRINT_FILAMENT" redefined
sketch/uilang.h:1772:0: note: this is the location of the previous definition
In file included from sketch/Repetier.h:360:0,
sketch/ui.h:239:16: warning: 'UIMenu_struct' has a field 'UIMenu_struct::entries' whose type uses the anonymous namespace
 typedef struct UIMenu_struct {
                 from sketch/Communication.cpp:22:
 #ifdef MINI-RAMBO
In file included from sketch/Communication.cpp:22:0:
sketch/Communication.cpp:25:29: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
 FSTRINGVALUE(Com::tFirmware,"FIRMWARE_NAME:Repetier_"REPETIER_VERSION" FIRMWARE_DATE:"FIRMWARE_DATE" MACHINE_TYPE:"UI_TEXT_PRINTER_READY" ")
sketch/Communication.cpp:25:70: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
sketch/Communication.cpp:25:100: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
                 from sketch/Eeprom.cpp:24:
 #ifdef MINI-RAMBO
In file included from sketch/Eeprom.cpp:24:0:
                 from sketch/Extruder.cpp:22:
 #ifdef MINI-RAMBO
In file included from sketch/Extruder.cpp:22:0:
                 from sketch/HAL.cpp:1:
 #ifdef MINI-RAMBO
In file included from sketch/HAL.cpp:1:0:
                 from sketch/Printer.cpp:19:
 #ifdef MINI-RAMBO
In file included from sketch/Printer.cpp:19:0:
sketch/Printer.cpp: In function 'Printer::setup()':
sketch/Printer.cpp:865:33: warning: iteration 3 invokes undefined behavior [-Waggressive-loop-optimizations]
         currentPosition[i] = 0.0;
sketch/Printer.cpp:862:5: note: containing loop
     for(uint8_t i = 0; i < E_AXIS_ARRAY; i++)
                 from /Users/roncioiu/Downloads/Firmware-master/Repetier Firmware/Repetier/Repetier.ino:144:
 #ifdef MINI-RAMBO
In file included from /Users/roncioiu/Downloads/Firmware-master/Repetier Firmware/Repetier/Repetier.ino:144:0:
                 from sketch/SDCard.cpp:22:
 #ifdef MINI-RAMBO
In file included from sketch/SDCard.cpp:22:0:
                 from sketch/SdFat.cpp:20:
 #ifdef MINI-RAMBO
In file included from sketch/SdFat.cpp:20:0:
sketch/SdFat.cpp: In member function 'uint8_t Sd2Card::cardCommand(uint8_t, uint32_t)':
sketch/SdFat.cpp:3202:23: warning: narrowing conversion of '(int)(cmd | 64u)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
   uint8_t d[6] = {cmd | 0X40, pa[3], pa[2], pa[1], pa[0]};
                 from sketch/gcode.cpp:24:
 #ifdef MINI-RAMBO
In file included from sketch/gcode.cpp:24:0:
                 from sketch/motion.cpp:24:
 #ifdef MINI-RAMBO
In file included from sketch/motion.cpp:24:0:
                 from sketch/ui.cpp:20:
 #ifdef MINI-RAMBO
In file included from sketch/ui.cpp:20:0:
In file included from sketch/ui.cpp:23:0:
sketch/uimenu.h:681:0: warning: "UI_MENU_ADV_CNT" redefined
 #define UI_MENU_ADV_CNT 1
sketch/uimenu.h:678:0: note: this is the location of the previous definition
 #define UI_MENU_ADV_CNT 0
sketch/uimenu.h:682:0: warning: "UI_MENU_ADVANCE" redefined
 #define UI_MENU_ADVANCE ,&ui_menu_cext_advancel
sketch/uimenu.h:679:0: note: this is the location of the previous definition
uimenu.h:780: error: 'ui_menu_conf_delta' was not declared in this scope
 #define UI_MENU_SIMPLE {UI_MENU_ADDCONDBACK  &ui_menu_main1,SD_PRINTFILE_ENTRY &ui_menu_main6,UI_MENU_FAN_COND &ui_menu_conf_delta}
sketch/ui.h:381:93: note: in definition of macro 'UI_MENU'
 #define UI_MENU(name,items,itemsCnt) const UIMenuEntry * const name ## _entries[] PROGMEM = items;const UIMenu name PROGMEM = {2,0,itemsCnt,name ## _entries};
sketch/uimenu.h:781:24: note: in expansion of macro 'UI_MENU_SIMPLE'
 UI_MENU(ui_menu_simple,UI_MENU_SIMPLE,3+UI_MENU_BACKCNT+UI_MENU_FAN_CNT+SD_PRINTFILE_ENTRY_CNT)
sketch/ui.cpp:843:75: warning: '__progmem__' attribute ignored [-Wattributes]
 void UIDisplay::createChar(uint8_t location,const uint8_t PROGMEM charmap[])
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
What am I doing wrong? Is there another place I should be changing the code to prevent my hotend from smashing into the glass?
Thank You.
Re: Upgrade from v2 to v3 , problems with homing and code compilation.
Posted: Sun Oct 23, 2016 8:55 pm
by Qdeathstar
I think you may have accidently typed in an extra key somewhere when looking for the spot to edit.
Posted: Sun Oct 23, 2016 10:31 pm
by gdgonzo
Hey Qdeathstar , I actually re-downloaded a zip from the git repo ; I had assumed I did that as well, but I get the same error. I can reproduce it every time. If I change any of the axis home dir's, it will no longer compile with that error.
Posted: Sun Oct 23, 2016 10:40 pm
Did you clear the eeprom using the special sketch in arduino?
Posted: Sun Oct 23, 2016 10:42 pm
Also the y axis IS opposite between the v2 and V3. You fix that in firmware or you could swap the pins on the connector. Firmware is easiest.
Posted: Sun Oct 23, 2016 11:54 pm
by gdgonzo
Mhackney, Yes, I did invert the Y axis in the firmware. Before I inverted it I tried it out and it would crash in to the Y tower. After inverting the Y axis, all towers work as they should. However, the unit thinks that homing itself means crashing into the hotplate. This printer was working before these upgrades.
My assumption was that this needed to be inverted as well:
( as shown )
#define X_HOME_DIR 0
#define Y_HOME_DIR 0
and not just
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
But as I stated, when I change the HOME_DIR to 0 , it will not compile anymore, change it to 1 it compiles but home down down instead of up :p . Also thank you for responding :)
Posted: Mon Oct 24, 2016 4:46 am
by Eric
I think you've made a false assumption.
The expected settings of ?_HOME_DIR are either 1 or -1, NOT 0. You've understandably confused it with a true/false setting, which in this case it is not.
1 means home upwards and use the MAX endstop switches.
-1 means home downward and use the MIN endstop switches.
I wouldn't mess with this setting, as it's not going to fix your problem, whatever it is.
Posted: Mon Oct 24, 2016 9:15 am
@gdgonzo, did you clear the EEPROM before installing the V3 firmware? That's a requirement and all sorts of odd things happen if you don't.
Posted: Mon Oct 24, 2016 10:02 pm
by gdgonzo
@mhackney, yes I did clear the EEPROM ; it was actually the first thing I did before I uploaded the new firmware.
Posted: Wed Oct 26, 2016 5:52 pm
by gdgonzo
So, I went in and started fiddling again now that I have some time. I cleared away my EEPROM, I recompiled the script. Having changed only the Y axis. I cleared my EEPROM again , and while I was about to recompile and upload again I got a popup as to a library that needed updating, I upgraded it and recompiled and now everything is working as it should. What fixed it? ¯\_(ツ)_/¯
Thank you all for helping , now off to calibrate :D
Posted: Fri Oct 28, 2016 10:10 am
by Dr. Pepper
Hello, I recently also upgraded my V2 to the new hot end. I cleared the EEPROM and then uploaded the new firmware with "5" selected for V3. Mistake! My Y-axis was inverted . I then cleared the EEPROM and uploaded firmware with "2" selected for V2. This time it seems to work fine, but when I run the calibration script it goes through the routine flawlessley but sets my X and Y tower distance-to-bed slightly tight, center of bed perfect, but Z tower quite loose. This happens repeatably every time, no matter what position I put the end stop screws on the skates. What I'm wondering now is if I should have selected "5" for the V3 and made other adjustments in the firmware or if there is something I need to tweak in the calibration g-code? Thanks!
Posted: Fri Oct 28, 2016 11:12 am
by Turpinator
Dr. Pepper wrote:Hello, I recently also upgraded my V2 to the new hot end. I cleared the EEPROM and then uploaded the new firmware with "5" selected for V3. Mistake! My Y-axis was inverted . I then cleared the EEPROM and uploaded firmware with "2" selected for V2. This time it seems to work fine, but when I run the calibration script it goes through the routine flawlessley but sets my X and Y tower distance-to-bed slightly tight, center of bed perfect, but Z tower quite loose. This happens repeatably every time, no matter what position I put the end stop screws on the skates. What I'm wondering now is if I should have selected "5" for the V3 and made other adjustments in the firmware or if there is something I need to tweak in the calibration g-code? Thanks!
According to gene, yes, just set it to 5 and invert the Y tower.
geneb wrote:Ah, there's the issue. If you're using the HE280 hot end, you've got to tell the firmware it's running on a V3. You'll need to invert one of the motor axes as well - Y I think, but I'm not sure. Load the firmware up, hit home and be ready to turn off the power. Which ever one moves the wrong way is the one you need to invert. :)
I however, have yet to get mine working, but I believe it is due to an issue with the accelerometer not communicating with the board, rather than a config/firmware setting.
Posted: Sat Oct 29, 2016 1:45 pm
by Dr. Pepper
Ok, I've cleared my EEPROM and reloaded firmware with V3 printer "5" selected and inverted the Y-axis in firmware and it all seems to work -- EXCEPT i'm still getting the same plane issue when using the probe to calibrate. It is high at the Z tower (too high to adhere to the print surface) and too low at the X and Y towers (so low it pinches off the flow of filament. I upgraded to avoid the tedious manual calibration, but it looks like I'm stuck doing that. I've seen other posts about this problem, but I've not yet found if there is a solution. Thanks for any help.
Posted: Sat Oct 29, 2016 3:56 pm
by morgandc
Not that I have seen, I have the same issue... That is on my list you look into, buy been working on other stuff so far.
Posted: Sat Oct 29, 2016 4:17 pm
I am STILL working on it! Spent 3 hrs today already. It's the darnedest thing because all of us having this issue are seeing the tilt from X (low) to between Y-Z (high). It is a leveling issue as best I can tell because delta radius seems to be pretty good and max Z height is good at the center.
I completely took my bed apart today. Checked all the mounts. Paid careful attention that they were all tensioned properly, the bed protruding the same amount all around and that any "give" or flex is consistent all around. I even stress tested the black plastic disk and it seems nice and rigid and there were no molding flashes or any issues I could find.
I have spent at least 20 hrs trying to understand this issue and doing careful tests. I'm completely baffled but I have several more drastic things to try.
This is a 1/4" aluminum crescent that will be a very rigid mount right at the base of the towers. It attaches through the two vent slots nearest the inside. It has a 1/16" recess to locate it right against the perimeter. There of these bad boys will make a rock solid mount to test agains.
M theory is that either the end stops (switch, carriage screw, etc) or bed is moving somehow. I've gone through everything and now down to making changes to test against.
Posted: Sat Oct 29, 2016 4:28 pm
I should say that the rendering is upside down - the crescents need to be on top of the base plate since the tower mounts would interfere.
Posted: Sat Oct 29, 2016 4:31 pm
Like this!
Posted: Sat Oct 29, 2016 6:44 pm
by morgandc
Interesting that a v2 with HE280 has the same issue. I s under the impression that the bed mounting system was different between the versions?
Posted: Sat Oct 29, 2016 6:50 pm
Wow, I missed that! Yes it is. Odd. I actually did rotate my HE280 120° to see if the problem followed the accelerometer position and it did not. That is very VERY strange that the V2 has the same issue in the same place.
Posted: Sat Oct 29, 2016 8:05 pm
by Dr. Pepper
I'm beginning to wonder if it is some type of electrical interference to the accelerometer caused by the power supply (which happens to be biased towards the Z and Y towers and furthest from teh x tower)...
Posted: Sat Oct 29, 2016 8:13 pm
Hmm, interesting thought.
Posted: Wed Nov 02, 2016 11:22 pm
by Dr. Pepper
I have heard that owning a 3D printer is a love-hate affair. I'm currently in the latter state. I have disassembled and reassembled the hot bed snowflake, onyx, and glass -- ensuring everything is level and flat and secure. I have adjusted belt tension, ensured towers are perpendicular to the bed, ensured towers are not leaning, ensured towers are parallel, tightened all ball joint arms to the effector plate (I really thought I might have solved it with that one!), made sure all skates are not sloppy or loose, tightened all end stop switches, and tried the adjust end stop screws and recalibrate/adjust until tower endstop offsets are no more than 4 steps--and still no luck with the auto full calibration. I'm starting to wonder if I should have my V2 listed as V2 in the firmware versus V3 -- going to try that next. My latest results (I went and bought a set of automotive feeler gauges) after auto calibrate at 85C bed / 227C hot end (turned off just before autocalibrate): HR=143.283 Zmax=370.252 Zprobeht=-0.06 Xoff=33 Yoff=0 Zoff=7 with heights above bed then as follows: ctr =0.18 X=less than 0.04 Y=less than 0.04 and Z=0.18. I've also found that I get the same "leveling results" no matter what position I put the end stop screws at. So at least the software/firmware is repeatably giving me a bad solution no mater the start conditions! Time to go try the manual calibration! The good news in all of this is that I am able to get a good z-ht calibration at center using a g-code script so at least I can save some time there.
Posted: Fri Nov 04, 2016 12:08 pm
by Dale Eason
Hi Dr Pepper,
I get about the same results with my upgraded V2. That is the horizontal radius seems to be off. The probe is lower at the edges than the center after calibration. Test prints are printed just a little too high to cause good adhesion. The X tower side is smashed into the bed too much and the Y tower side is too far from the bed.
Parameters after calibration are
Horizontal radius: 143.776
Z Max length: 362.285
The tower offsets are dependent on the stop screw positions. I manually positioned them so that they do not differ by more than 2 steps.
They are x: 5 y: 0 Z: 7 steps
I wonder why my Max Z is about 10 mm shorter than yours. I have the end stop screws almost all the way in to where they stop. I'm using the ball cap arms and carriages.
I'm very frustrated as well. So far the auto calibration has done me any good.
I have also been playing with changes to the firmware code. I'm a software engineer so I understand the code pretty well.
Dale Eason
Posted: Sat Nov 05, 2016 2:50 pm
by Dale Eason
I have more information on what I think may be an issue. That happens for commands that probe the center of the bed like the G68 (Horizontal Radius calibration) and the G30 (Z Height Calibration).
A Probe Is what the software does when it tries to determine the distance to the bed. It will move the nozzle 25 mm from the bed and then lower the nozzle until it hits the bed. I call that a tap. A probe usually consists of one tap. For the current software it will probe the bed twice each with one tap. The number of taps is configurable in the configure.h file as Z_PROBE_REPETITIONS. The default is set to one.
It compares the distance returned (the average of the taps) by each probe command and if they are different by more than .1 mm it will try the two probe sequence again. It will continue doing this until the difference is less than .1 or you turn off the machine. On my machine the difference is always greater than .1 on the bed center probe.
I changed the Z_PROBE_REPETITIONS to be 10 and found that fixed issue sort of. Now the average value of all the taps for each center probing are very close. However I wanted to see what each tap value was so I modified the code in printer.cpp to output the distance values for each tap. That returned some interesting and puzzling results. It shows that only when probing the bed center the very first tap computes a much shorter distance than subsequent taps. Here is a filtered log of those taps. Each tap for a particular probe is displayed one a line for that probe event. I ran two calibrations. The first was with the default Max Z height of 375. The second was with the max Z height computed by the first.
The large tap difference is highlighted in Red. Notice that it only happens on the first probe of the bed center. Not the second probe.
FIRST CALIBRATION RUN MAX Z Height 375
G69 TOWER OFFSET CALCS
X PROBE 1<- 1049.00 1048.00 1046.00 1046.00 1046.00 1046.00 1046.00 1046.00 1046.00 1047.00Z-probe:6.72
X PROBE 2<- 1044.00 1046.00 1046.00 1046.00 1047.00 1047.00 1047.00 1045.00 1045.00 1045.00Z-probe:6.73
Y PROBE 1<- 1060.00 1057.00 1055.00 1055.00 1054.00 1055.00 1055.00 1056.00 1056.00 1056.00Z-probe:6.60
Y PROBE 2<- 1056.00 1055.00 1055.00 1056.00 1055.00 1055.00 1056.00 1055.00 1055.00 1055.00Z-probe:6.61
Z PROBE 1<- 1041.00 1040.00 1040.00 1041.00 1041.00 1040.00 1041.00 1042.00 1042.00 1042.00Z-probe:6.79
Z PROBE 2<- 1040.00 1042.00 1041.00 1043.00 1042.00 1042.00 1042.00 1043.00 1044.00 1044.00Z-probe:6.77
G68 Horizontal Radius Calc
CENTER PROBE 1<- 1012.00 1006.00 1001.00 1001.00 1001.00 1001.00 1000.00 1001.00 1000.00 1000.00Z-probe:7.27
CENTER PROBE 2<- 1000.00 1002.00 1002.00 1001.00 1002.00 1001.00 1001.00 1001.00 1002.00 1001.00Z-probe:7.28
Z PROBE 1<- 1083.00 1083.00 1082.00 1082.00 1083.00 1083.00 1082.00 1082.00 1083.00 1083.00Z-probe:6.27
Z PROBE 2<- 1081.00 1083.00 1083.00 1083.00 1082.00 1083.00 1083.00 1083.00 1083.00 1083.00Z-probe:6.27
G30 MAX Z HEIGHT CALC
CENTER PROBE 1<- 1013.00 1007.00 1004.00 1001.00 1002.00 1002.00 1002.00 1002.00 1002.00 1002.00Z-probe:7.25
CENTER PROBE 2<- 1002.00 1002.00 1003.00 1002.00 1003.00 1002.00 1002.00 1002.00 1003.00 1003.00Z-probe:7.27
SECOND CALIBRATION RUN WITH COMPUTED MAZ Z HEIGHT OF 362
G69 Tower OFFSET calcs [0.046]
X TOWER PROBE 1<- 34.00 27.00 26.00 26.00 26.00 27.00 28.00 27.00 27.00 26.00Z-probe:19.46
X TOWER PROBE 2<- 29.00 26.00 26.00 26.00 27.00 26.00 26.00 27.00 27.00 27.00Z-probe:19.47
Y TOWER PROBE 1<- 38.00 37.00 36.00 37.00 37.00 37.00 38.00 38.00 37.00 38.00Z-probe:19.33
Y TOWER PROBE 2<- 37.00 38.00 38.00 38.00 38.00 38.00 38.00 38.00 37.00 39.00Z-probe:19.33
Z TOWER PROBE 1<- 26.00 25.00 25.00 24.00 25.00 24.00 25.00 25.00 25.00 25.00Z-probe:19.49
Z TOWER PROBE 2<- 27.00 26.00 25.00 25.00 25.00 26.00 25.00 25.00 25.00 25.00Z-probe:19.48
G68 Horizontal Radius calc [40.743]
CENTER PROBE 1<- -5.00 -12.00 -17.00 -18.00 -18.00 -17.00 -18.00 -18.00 -17.00 -17.00Z-probe:20.00
CENTER PROBE 2<- -16.00 -18.00 -18.00 -17.00 -17.00 -17.00 -18.00 -18.00 -17.00 -17.00Z-probe:20.02
Z TOWER PROBE 1<- 66.00 64.00 64.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00Z-probe:19.01
Z TOWER PROBE 2<- 62.00 62.00 62.00 62.00 62.00 63.00 63.00 63.00 63.00 62.00Z-probe:19.02
G30 Z Height calc. [66.931]
CENTER PROBE 1<- 1013.00 1008.00 1004.00 1001.00 1002.00 1003.00 1002.00 1002.00 1002.00 1003.00Z-probe:7.25
CENTER PROBE 2<- 1000.00 1003.00 1002.00 1002.00 1002.00 1002.00 1002.00 1003.00 1002.00 1002.00Z-probe:7.28
If any of you want to try my code modification for yourself here is printer.cpp. Be sure to save your original so you can restore it as desired.
    This file is part of Repetier-Firmware.
    Repetier-Firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    Repetier-Firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#include "Repetier.h"
#if USE_ADVANCE
uint8_t Printer::minExtruderSpeed;            ///< Timer delay for start extruder speed
uint8_t Printer::maxExtruderSpeed;            ///< Timer delay for end extruder speed
volatile int Printer::extruderStepsNeeded; ///< This many extruder steps are still needed, <0 = reverse steps needed.
//uint8_t Printer::extruderAccelerateDelay;     ///< delay between 2 speec increases
#endif
uint8_t Printer::unitIsInches = 0; ///< 0 = Units are mm, 1 = units are inches.
//Stepper Movement Variables
float Printer::axisStepsPerMM[E_AXIS_ARRAY] = {XAXIS_STEPS_PER_MM,YAXIS_STEPS_PER_MM,ZAXIS_STEPS_PER_MM,1}; ///< Number of steps per mm needed.
float Printer::invAxisStepsPerMM[E_AXIS_ARRAY]; ///< Inverse of axisStepsPerMM for faster conversion
float Printer::maxFeedrate[E_AXIS_ARRAY] = {MAX_FEEDRATE_X, MAX_FEEDRATE_Y, MAX_FEEDRATE_Z}; ///< Maximum allowed feedrate.
float Printer::homingFeedrate[Z_AXIS_ARRAY] = {HOMING_FEEDRATE_X, HOMING_FEEDRATE_Y, HOMING_FEEDRATE_Z};
#if RAMP_ACCELERATION
//  float max_start_speed_units_per_second[E_AXIS_ARRAY] = MAX_START_SPEED_UNITS_PER_SECOND; ///< Speed we can use, without acceleration.
float Printer::maxAccelerationMMPerSquareSecond[E_AXIS_ARRAY] = {MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X,MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y,MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z}; ///< X, Y, Z and E max acceleration in mm/s^2 for printing moves or retracts
float Printer::maxTravelAccelerationMMPerSquareSecond[E_AXIS_ARRAY] = {MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X,MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y,MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z}; ///< X, Y, Z max acceleration in mm/s^2 for travel moves
/** Acceleration in steps/s^3 in printing mode.*/
unsigned long Printer::maxPrintAccelerationStepsPerSquareSecond[E_AXIS_ARRAY];
/** Acceleration in steps/s^2 in movement mode.*/
unsigned long Printer::maxTravelAccelerationStepsPerSquareSecond[E_AXIS_ARRAY];
#endif
#if NONLINEAR_SYSTEM
long Printer::currentDeltaPositionSteps[E_TOWER_ARRAY];
uint8_t lastMoveID = 0; // Last move ID
#endif
signed char Printer::zBabystepsMissing = 0;
uint8_t Printer::relativeCoordinateMode = false;  ///< Determines absolute (false) or relative Coordinates (true).
uint8_t Printer::relativeExtruderCoordinateMode = false;  ///< Determines Absolute or Relative E Codes while in Absolute Coordinates mode. E is always relative in Relative Coordinates mode.
long Printer::currentPositionSteps[E_AXIS_ARRAY];
float Printer::currentPosition[Z_AXIS_ARRAY];
float Printer::lastCmdPos[Z_AXIS_ARRAY];
long Printer::destinationSteps[E_AXIS_ARRAY];
float Printer::coordinateOffset[Z_AXIS_ARRAY] = {0,0,0};
uint8_t Printer::flag0 = 0;
uint8_t Printer::flag1 = 0;
uint8_t Printer::flag2 = 0;
uint8_t Printer::debugLevel = 6; ///< Bitfield defining debug output. 1 = echo, 2 = info, 4 = error, 8 = dry run., 16 = Only communication, 32 = No moves
uint8_t Printer::stepsPerTimerCall = 1;
uint8_t Printer::menuMode = 0;
float Printer::extrudeMultiplyError = 0;
float Printer::extrusionFactor = 1.0;
#if FEATURE_AUTOLEVEL
float Printer::autolevelTransformation[9]; ///< Transformation matrix
#endif
uint32_t Printer::interval;           ///< Last step duration in ticks.
uint32_t Printer::timer;              ///< used for acceleration/deceleration timing
uint32_t Printer::stepNumber;         ///< Step number in current move.
#if USE_ADVANCE
#if ENABLE_QUADRATIC_ADVANCE
int32_t Printer::advanceExecuted;             ///< Executed advance steps
#endif
int Printer::advanceStepsSet;
#endif
int32_t Printer::maxDeltaPositionSteps;
floatLong Printer::deltaDiagonalStepsSquaredA;
floatLong Printer::deltaDiagonalStepsSquaredB;
floatLong Printer::deltaDiagonalStepsSquaredC;
float Printer::deltaMaxRadiusSquared;
float Printer::radius0;
int32_t Printer::deltaFloorSafetyMarginSteps = 0;
int32_t Printer::deltaAPosXSteps;
int32_t Printer::deltaAPosYSteps;
int32_t Printer::deltaBPosXSteps;
int32_t Printer::deltaBPosYSteps;
int32_t Printer::deltaCPosXSteps;
int32_t Printer::deltaCPosYSteps;
int32_t Printer::realDeltaPositionSteps[TOWER_ARRAY];
int16_t Printer::travelMovesPerSecond;
int16_t Printer::printMovesPerSecond;
#endif
#if FEATURE_Z_PROBE || MAX_HARDWARE_ENDSTOP_Z || NONLINEAR_SYSTEM
int32_t Printer::stepsRemainingAtZHit;
#endif
#if DRIVE_SYSTEM == DELTA
int32_t Printer::stepsRemainingAtXHit;
int32_t Printer::stepsRemainingAtYHit;
#endif
#if SOFTWARE_LEVELING
int32_t Printer::levelingP1[3];
int32_t Printer::levelingP2[3];
int32_t Printer::levelingP3[3];
#endif
float Printer::minimumSpeed;               ///< lowest allowed speed to keep integration error small
float Printer::minimumZSpeed;
int32_t Printer::xMaxSteps;                   ///< For software endstops, limit of move in positive direction.
int32_t Printer::yMaxSteps;                   ///< For software endstops, limit of move in positive direction.
int32_t Printer::zMaxSteps;                   ///< For software endstops, limit of move in positive direction.
int32_t Printer::xMinSteps;                   ///< For software endstops, limit of move in negative direction.
int32_t Printer::yMinSteps;                   ///< For software endstops, limit of move in negative direction.
int32_t Printer::zMinSteps;                   ///< For software endstops, limit of move in negative direction.
float Printer::xLength;
float Printer::xMin;
float Printer::yLength;
float Printer::yMin;
float Printer::zLength;
float Printer::zMin;
float Printer::feedrate;                   ///< Last requested feedrate.
int Printer::feedrateMultiply;             ///< Multiplier for feedrate in percent (factor 1 = 100)
unsigned int Printer::extrudeMultiply;     ///< Flow multiplier in percdent (factor 1 = 100)
float Printer::maxJerk;                    ///< Maximum allowed jerk in mm/s
#if DRIVE_SYSTEM!=DELTA
float Printer::maxZJerk;                   ///< Maximum allowed jerk in z direction in mm/s
#endif
float Printer::offsetX;                     ///< X-offset for different extruder positions.
float Printer::offsetY;                     ///< Y-offset for different extruder positions.
speed_t Printer::vMaxReached;         ///< Maximumu reached speed
uint32_t Printer::msecondsPrinting;            ///< Milliseconds of printing time (means time with heated extruder)
float Printer::filamentPrinted;            ///< mm of filament printed since counting started
uint8_t Printer::wasLastHalfstepping;         ///< Indicates if last move had halfstepping enabled
#if ENABLE_BACKLASH_COMPENSATION
float Printer::backlashX;
float Printer::backlashY;
float Printer::backlashZ;
uint8_t Printer::backlashDir;
#endif
#ifdef DEBUG_STEPCOUNT
int32_t Printer::totalStepsRemaining;
#endif
float Printer::memoryX;
float Printer::memoryY;
float Printer::memoryZ;
float Printer::memoryE;
float Printer::memoryF = -1;
#if GANTRY
int8_t Printer::motorX;
int8_t Printer::motorYorZ;
#endif
#ifdef DEBUG_SEGMENT_LENGTH
float Printer::maxRealSegmentLength = 0;
#endif
#ifdef DEBUG_REAL_JERK
float Printer::maxRealJerk = 0;
#endif
#ifdef DEBUG_PRINT
int debugWaitLoop = 0;
#endif
fast8_t Printer::wizardStackPos;
wizardVar Printer::wizardStack[WIZARD_STACK_SIZE];
#if !NONLINEAR_SYSTEM
void Printer::constrainDestinationCoords()
    if(isNoDestinationCheck()) return;
#if min_software_endstop_x
    if (destinationSteps[X_AXIS] < xMinSteps) Printer::destinationSteps[X_AXIS] = Printer::xMinSteps;
#endif
#if min_software_endstop_y
    if (destinationSteps[Y_AXIS] < yMinSteps) Printer::destinationSteps[Y_AXIS] = Printer::yMinSteps;
#endif
#if min_software_endstop_z
    if (destinationSteps[Z_AXIS] < zMinSteps && !isZProbingActive()) Printer::destinationSteps[Z_AXIS] = Printer::zMinSteps;
#endif
#if max_software_endstop_x
    if (destinationSteps[X_AXIS] > Printer::xMaxSteps) Printer::destinationSteps[X_AXIS] = Printer::xMaxSteps;
#endif
#if max_software_endstop_y
    if (destinationSteps[Y_AXIS] > Printer::yMaxSteps) Printer::destinationSteps[Y_AXIS] = Printer::yMaxSteps;
#endif
#if max_software_endstop_z
    if (destinationSteps[Z_AXIS] > Printer::zMaxSteps && !isZProbingActive()) Printer::destinationSteps[Z_AXIS] = Printer::zMaxSteps;
#endif
#endif
bool Printer::isPositionAllowed(float x,float y,float z)
    if(isNoDestinationCheck())  return true;
    bool allowed = true;
    allowed &= (z >= -100) && (z <= zLength + 0.05 + ENDSTOP_Z_BACK_ON_HOME);
    allowed &= (x * x + y * y <= deltaMaxRadiusSquared);
#endif // DRIVE_SYSTEM
    if(!allowed)
        Printer::updateCurrentPosition(true);
        Commands::printCurrentPosition(PSTR("isPositionAllowed "));
    return allowed;
void Printer::updateDerivedParameter()
    travelMovesPerSecond = EEPROM::deltaSegmentsPerSecondMove();
    printMovesPerSecond = EEPROM::deltaSegmentsPerSecondPrint();
    axisStepsPerMM[X_AXIS] = axisStepsPerMM[Y_AXIS] = axisStepsPerMM[Z_AXIS];
    maxAccelerationMMPerSquareSecond[X_AXIS] = maxAccelerationMMPerSquareSecond[Y_AXIS] = maxAccelerationMMPerSquareSecond[Z_AXIS];
    homingFeedrate[X_AXIS] = homingFeedrate[Y_AXIS] = homingFeedrate[Z_AXIS];
    maxFeedrate[X_AXIS] = maxFeedrate[Y_AXIS] = maxFeedrate[Z_AXIS];
    maxTravelAccelerationMMPerSquareSecond[X_AXIS] = maxTravelAccelerationMMPerSquareSecond[Y_AXIS] = maxTravelAccelerationMMPerSquareSecond[Z_AXIS];
    zMaxSteps = axisStepsPerMM[Z_AXIS] * (zLength);
    towerAMinSteps = axisStepsPerMM[A_TOWER] * xMin;
    towerBMinSteps = axisStepsPerMM[B_TOWER] * yMin;
    towerCMinSteps = axisStepsPerMM[C_TOWER] * zMin;
    //radius0 = EEPROM::deltaHorizontalRadius();
    float radiusA = radius0 + EEPROM::deltaRadiusCorrectionA();
    float radiusB = radius0 + EEPROM::deltaRadiusCorrectionB();
    float radiusC = radius0 + EEPROM::deltaRadiusCorrectionC();
    deltaAPosXSteps = floor(radiusA * cos(EEPROM::deltaAlphaA() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaAPosYSteps = floor(radiusA * sin(EEPROM::deltaAlphaA() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaBPosXSteps = floor(radiusB * cos(EEPROM::deltaAlphaB() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaBPosYSteps = floor(radiusB * sin(EEPROM::deltaAlphaB() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaCPosXSteps = floor(radiusC * cos(EEPROM::deltaAlphaC() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaCPosYSteps = floor(radiusC * sin(EEPROM::deltaAlphaC() * M_PI / 180.0f) * axisStepsPerMM[Z_AXIS] + 0.5f);
    deltaDiagonalStepsSquaredA.l = static_cast<uint32_t>((EEPROM::deltaDiagonalCorrectionA() + EEPROM::deltaDiagonalRodLength())*axisStepsPerMM[Z_AXIS]);
    deltaDiagonalStepsSquaredB.l = static_cast<uint32_t>((EEPROM::deltaDiagonalCorrectionB() + EEPROM::deltaDiagonalRodLength())*axisStepsPerMM[Z_AXIS]);
    deltaDiagonalStepsSquaredC.l = static_cast<uint32_t>((EEPROM::deltaDiagonalCorrectionC() + EEPROM::deltaDiagonalRodLength())*axisStepsPerMM[Z_AXIS]);
    if(deltaDiagonalStepsSquaredA.l > 65534 || 2 * radius0*axisStepsPerMM[Z_AXIS] > 65534)
        setLargeMachine(true);
#ifdef SUPPORT_64_BIT_MATH
        deltaDiagonalStepsSquaredA.L = RMath::sqr(static_cast<uint64_t>(deltaDiagonalStepsSquaredA.l));
        deltaDiagonalStepsSquaredB.L = RMath::sqr(static_cast<uint64_t>(deltaDiagonalStepsSquaredB.l));
        deltaDiagonalStepsSquaredC.L = RMath::sqr(static_cast<uint64_t>(deltaDiagonalStepsSquaredC.l));
#else
        deltaDiagonalStepsSquaredA.f = RMath::sqr(static_cast<float>(deltaDiagonalStepsSquaredA.l));
        deltaDiagonalStepsSquaredB.f = RMath::sqr(static_cast<float>(deltaDiagonalStepsSquaredB.l));
        deltaDiagonalStepsSquaredC.f = RMath::sqr(static_cast<float>(deltaDiagonalStepsSquaredC.l));
#endif
    else
        setLargeMachine(false);
        deltaDiagonalStepsSquaredA.l = RMath::sqr(deltaDiagonalStepsSquaredA.l);
        deltaDiagonalStepsSquaredB.l = RMath::sqr(deltaDiagonalStepsSquaredB.l);
        deltaDiagonalStepsSquaredC.l = RMath::sqr(deltaDiagonalStepsSquaredC.l);
    deltaMaxRadiusSquared = RMath::sqr(EEPROM::deltaMaxRadius());
    long cart[Z_AXIS_ARRAY], delta[TOWER_ARRAY];
    cart[X_AXIS] = cart[Y_AXIS] = 0;
    cart[Z_AXIS] = zMaxSteps;
    transformCartesianStepsToDeltaSteps(cart, delta);
    maxDeltaPositionSteps = delta[0];
    xMaxSteps = yMaxSteps = zMaxSteps;
    xMinSteps = yMinSteps = zMinSteps = 0;
    deltaFloorSafetyMarginSteps = DELTA_FLOOR_SAFETY_MARGIN_MM * axisStepsPerMM[Z_AXIS];
#elif DRIVE_SYSTEM == TUGA
    deltaDiagonalStepsSquared.l = uint32_t(EEPROM::deltaDiagonalRodLength() * axisStepsPerMM[X_AXIS]);
    if(deltaDiagonalStepsSquared.l > 65534)
        deltaDiagonalStepsSquared.f = float(deltaDiagonalStepsSquared.l) * float(deltaDiagonalStepsSquared.l);
    else
        deltaDiagonalStepsSquared.l = deltaDiagonalStepsSquared.l * deltaDiagonalStepsSquared.l;
    deltaBPosXSteps = static_cast<int32_t>(EEPROM::deltaDiagonalRodLength() * axisStepsPerMM[X_AXIS]);
    xMaxSteps = static_cast<int32_t>(axisStepsPerMM[X_AXIS] * (xMin + xLength));
    yMaxSteps = static_cast<int32_t>(axisStepsPerMM[Y_AXIS] * yLength);
    zMaxSteps = static_cast<int32_t>(axisStepsPerMM[Z_AXIS] * (zMin + zLength));
    xMinSteps = static_cast<int32_t>(axisStepsPerMM[X_AXIS] * xMin);
    yMinSteps = 0;
    zMinSteps = static_cast<int32_t>(axisStepsPerMM[Z_AXIS] * zMin);
#else
    yMaxSteps = static_cast<int32_t>(axisStepsPerMM[Y_AXIS] * (yMin + yLength));
    yMinSteps = static_cast<int32_t>(axisStepsPerMM[Y_AXIS] * yMin);
    // For which directions do we need backlash compensation
    backlashDir &= XYZ_DIRPOS;
    if(backlashX != 0) backlashDir |= 8;
    if(backlashY != 0) backlashDir |= 16;
    if(backlashZ != 0) backlashDir |= 32;
#endif
#endif
        invAxisStepsPerMM[i] = 1.0f/axisStepsPerMM[i];
#ifdef RAMP_ACCELERATION
        maxPrintAccelerationStepsPerSquareSecond[i] = maxAccelerationMMPerSquareSecond[i] * axisStepsPerMM[i];
        maxTravelAccelerationStepsPerSquareSecond[i] = maxTravelAccelerationMMPerSquareSecond[i] * axisStepsPerMM[i];
#endif
    float accel = RMath::max(maxAccelerationMMPerSquareSecond[X_AXIS], maxTravelAccelerationMMPerSquareSecond[X_AXIS]);
    minimumSpeed = accel * sqrt(2.0f / (axisStepsPerMM[X_AXIS]*accel));
    accel = RMath::max(maxAccelerationMMPerSquareSecond[Z_AXIS], maxTravelAccelerationMMPerSquareSecond[Z_AXIS]);
    minimumZSpeed = accel * sqrt(2.0f / (axisStepsPerMM[Z_AXIS] * accel));
#if DISTORTION_CORRECTION
    distortion.updateDerived();
#endif // DISTORTION_CORRECTION
    Printer::updateAdvanceFlags();
  \brief Stop heater and stepper motors. Disable power,if possible.
void Printer::kill(uint8_t only_steppers)
    if(areAllSteppersDisabled() && only_steppers) return;
    if(Printer::isAllKilled()) return;
    setAllSteppersDiabled();
    disableXStepper();
    disableYStepper();
    disableZStepper();
    Extruder::disableAllExtruderMotors();
#if FAN_BOARD_PIN>-1
    pwm_pos[NUM_EXTRUDER + 1] = 0;
#endif // FAN_BOARD_PIN
    if(!only_steppers)
        for(uint8_t i = 0; i < NUM_TEMPERATURE_LOOPS; i++)
            Extruder::setTemperatureForExtruder(0, i);
        Extruder::setHeatedBedTemperature(0);
        UI_STATUS_UPD(UI_TEXT_KILLED);
#if defined(PS_ON_PIN) && PS_ON_PIN>-1
        //pinMode(PS_ON_PIN,INPUT);
        SET_OUTPUT(PS_ON_PIN); //GND
        WRITE(PS_ON_PIN, (POWER_INVERTING ? LOW : HIGH));
        Printer::setPowerOn(false);
#endif
        Printer::setAllKilled(true);
    else UI_STATUS_UPD(UI_TEXT_STEPPER_DISABLED);
void Printer::updateAdvanceFlags()
    Printer::setAdvanceActivated(false);
#if USE_ADVANCE
    for(uint8_t i = 0; i < NUM_EXTRUDER; i++)
        if(extruder[i].advanceL != 0)
            Printer::setAdvanceActivated(true);
        if(extruder[i].advanceK != 0) Printer::setAdvanceActivated(true);
#endif
#endif
// This is for untransformed move to coordinates in printers absolute cartesian space
uint8_t Printer::moveTo(float x,float y,float z,float e,float f)
    if(x != IGNORE_COORDINATE)
        destinationSteps[X_AXIS] = (x + Printer::offsetX) * axisStepsPerMM[X_AXIS];
    if(y != IGNORE_COORDINATE)
        destinationSteps[Y_AXIS] = (y + Printer::offsetY) * axisStepsPerMM[Y_AXIS];
    if(z != IGNORE_COORDINATE)
        destinationSteps[Z_AXIS] = z * axisStepsPerMM[Z_AXIS];
    if(e != IGNORE_COORDINATE)
        destinationSteps[E_AXIS] = e * axisStepsPerMM[E_AXIS];
    if(f != IGNORE_COORDINATE)
        feedrate = f;
    // Disable software endstop or we get wrong distances when length < real length
    if (!PrintLine::queueDeltaMove(ALWAYS_CHECK_ENDSTOPS, true, false))
        Com::printWarningFLN(PSTR("moveTo / queueDeltaMove returns error"));
        return 0;
#else
    PrintLine::queueCartesianMove(ALWAYS_CHECK_ENDSTOPS, true);
#endif
    updateCurrentPosition(false);
    return 1;
// Move to transformed cartesian coordinates, mapping real (model) space to printer space
uint8_t Printer::moveToReal(float x, float y, float z, float e, float f)
    if(x == IGNORE_COORDINATE)
        x = currentPosition[X_AXIS];
    else
        currentPosition[X_AXIS] = x;
    if(y == IGNORE_COORDINATE)
        y = currentPosition[Y_AXIS];
    else
        currentPosition[Y_AXIS] = y;
    if(z == IGNORE_COORDINATE)
        z = currentPosition[Z_AXIS];
    else
        currentPosition[Z_AXIS] = z;
    if(isAutolevelActive())
        transformToPrinter(x + Printer::offsetX, y + Printer::offsetY, z, x, y, z);
    else
#endif // FEATURE_AUTOLEVEL
        x += Printer::offsetX;
        y += Printer::offsetY;
    // There was conflicting use of IGNOR_COORDINATE
    destinationSteps[X_AXIS] = static_cast<int32_t>(floor(x * axisStepsPerMM[X_AXIS] + 0.5f));
    destinationSteps[Y_AXIS] = static_cast<int32_t>(floor(y * axisStepsPerMM[Y_AXIS] + 0.5f));
    destinationSteps[Z_AXIS] = static_cast<int32_t>(floor(z * axisStepsPerMM[Z_AXIS] + 0.5f));
    if(e != IGNORE_COORDINATE && !Printer::debugDryrun()
#if MIN_EXTRUDER_TEMP > 30
            && (Extruder::current->tempControl.currentTemperatureC > MIN_EXTRUDER_TEMP || Printer::isColdExtrusionAllowed())
#endif
        feedrate = f;
    if (!PrintLine::queueDeltaMove(ALWAYS_CHECK_ENDSTOPS, true, true))
        Com::printWarningFLN(PSTR("moveToReal / queueDeltaMove returns error"));
        SHOWM(x);
        SHOWM(y);
        SHOWM(z);
        return 0;
#else
#endif
    return 1;
void Printer::setOrigin(float xOff, float yOff, float zOff)
    coordinateOffset[X_AXIS] = xOff;
    coordinateOffset[Y_AXIS] = yOff;
    coordinateOffset[Z_AXIS] = zOff;
/** Computes currentPosition from currentPositionSteps including correction for offset. */
void Printer::updateCurrentPosition(bool copyLastCmd)
    currentPosition[X_AXIS] = static_cast<float>(currentPositionSteps[X_AXIS]) * invAxisStepsPerMM[X_AXIS];
    currentPosition[Y_AXIS] = static_cast<float>(currentPositionSteps[Y_AXIS]) * invAxisStepsPerMM[Y_AXIS];
    currentPosition[Z_AXIS] = static_cast<float>(currentPositionSteps[Z_AXIS]) * invAxisStepsPerMM[Z_AXIS];
        transformFromPrinter(currentPosition[X_AXIS], currentPosition[Y_AXIS], currentPosition[Z_AXIS],
                             currentPosition[X_AXIS], currentPosition[Y_AXIS], currentPosition[Z_AXIS]);
    currentPosition[X_AXIS] -= Printer::offsetX;
    currentPosition[Y_AXIS] -= Printer::offsetY;
    if(copyLastCmd)
        lastCmdPos[X_AXIS] = currentPosition[X_AXIS];
        lastCmdPos[Y_AXIS] = currentPosition[Y_AXIS];
        lastCmdPos[Z_AXIS] = currentPosition[Z_AXIS];
  \brief Sets the destination coordinates to values stored in com.
  For the computation of the destination, the following facts are considered:
  - Are units inches or mm.
  - Reltive or absolute positioning with special case only extruder relative.
  - Offset in x and y direction for multiple extruder support.
uint8_t Printer::setDestinationStepsFromGCode(GCode *com)
    register int32_t p;
    float x, y, z;
#if FEATURE_RETRACTION
    if(com->hasNoXYZ() && com->hasE() && isAutoretract()) { // convert into autoretract
        if(relativeCoordinateMode || relativeExtruderCoordinateMode) {
            Extruder::current->retract(com->E < 0,false);
        } else {
            p = convertToMM(com->E * axisStepsPerMM[E_AXIS]); // current position
            Extruder::current->retract(com->E < p,false);
        return 0; // Fake no move so nothing gets added
#endif
    if(!relativeCoordinateMode)
        if(com->hasX()) lastCmdPos[X_AXIS] = currentPosition[X_AXIS] = convertToMM(com->X) - coordinateOffset[X_AXIS];
        if(com->hasY()) lastCmdPos[Y_AXIS] = currentPosition[Y_AXIS] = convertToMM(com->Y) - coordinateOffset[Y_AXIS];
        if(com->hasZ()) lastCmdPos[Z_AXIS] = currentPosition[Z_AXIS] = convertToMM(com->Z) - coordinateOffset[Z_AXIS];
    else
        if(com->hasX()) currentPosition[X_AXIS] = (lastCmdPos[X_AXIS] += convertToMM(com->X));
        if(com->hasY()) currentPosition[Y_AXIS] = (lastCmdPos[Y_AXIS] += convertToMM(com->Y));
        if(com->hasZ()) currentPosition[Z_AXIS] = (lastCmdPos[Z_AXIS] += convertToMM(com->Z));
        transformToPrinter(lastCmdPos[X_AXIS] + Printer::offsetX, lastCmdPos[Y_AXIS] + Printer::offsetY, lastCmdPos[Z_AXIS], x, y, z);
    else
        x = lastCmdPos[X_AXIS] + Printer::offsetX;
        y = lastCmdPos[Y_AXIS] + Printer::offsetY;
        z = lastCmdPos[Z_AXIS];
    if(com->hasE() && !Printer::debugDryrun())
            if(
#if MIN_EXTRUDER_TEMP > 20
                (Extruder::current->tempControl.currentTemperatureC < MIN_EXTRUDER_TEMP && !Printer::isColdExtrusionAllowed()) ||
#endif
                fabs(com->E) * extrusionFactor > EXTRUDE_MAXLENGTH)
                p = 0;
            destinationSteps[E_AXIS] = currentPositionSteps[E_AXIS] + p;
        else
            if(
#endif
                fabs(p - currentPositionSteps[E_AXIS]) * extrusionFactor > EXTRUDE_MAXLENGTH * axisStepsPerMM[E_AXIS])
                currentPositionSteps[E_AXIS] = p;
            destinationSteps[E_AXIS] = p;
    else Printer::destinationSteps[E_AXIS] = Printer::currentPositionSteps[E_AXIS];
    if(com->hasF())
        if(unitIsInches)
            feedrate = com->F * 0.0042333f * (float)feedrateMultiply;  // Factor is 25.5/60/100
        else
            feedrate = com->F * (float)feedrateMultiply * 0.00016666666f;
    if(!Printer::isPositionAllowed(lastCmdPos[X_AXIS], lastCmdPos[Y_AXIS], lastCmdPos[Z_AXIS]))
        currentPositionSteps[E_AXIS] = destinationSteps[E_AXIS];
        return false; // ignore move
    return !com->hasNoXYZ() || (com->hasE() && destinationSteps[E_AXIS] != currentPositionSteps[E_AXIS]); // ignore unproductive moves
void Printer::setup()
    HAL::stopWatchdog();
#if FEATURE_CONTROLLER == CONTROLLER_VIKI
    HAL::delayMilliseconds(100);
#endif // FEATURE_CONTROLLER
    //HAL::delayMilliseconds(500);  // add a delay at startup to give hardware time for initalization
    HAL::hwSetup();
#ifdef ANALYZER
// Channel->pin assignments
#if ANALYZER_CH0>=0
    SET_OUTPUT(ANALYZER_CH0);
#endif
#if ANALYZER_CH1>=0
    SET_OUTPUT(ANALYZER_CH1);
#endif
#if ANALYZER_CH2>=0
    SET_OUTPUT(ANALYZER_CH2);
#endif
#if ANALYZER_CH3>=0
    SET_OUTPUT(ANALYZER_CH3);
#endif
#if ANALYZER_CH4>=0
    SET_OUTPUT(ANALYZER_CH4);
#endif
#if ANALYZER_CH5>=0
    SET_OUTPUT(ANALYZER_CH5);
#endif
#if ANALYZER_CH6>=0
    SET_OUTPUT(ANALYZER_CH6);
#endif
#if ANALYZER_CH7>=0
    SET_OUTPUT(ANALYZER_CH7);
#endif
#endif
#if defined(ENABLE_POWER_ON_STARTUP) && ENABLE_POWER_ON_STARTUP && (PS_ON_PIN>-1)
    WRITE(PS_ON_PIN, (POWER_INVERTING ? HIGH : LOW));
    Printer::setPowerOn(true);
#else
#if PS_ON_PIN>-1
#else
#endif
#endif
#if SDSUPPORT
    //power to SD reader
#if SDPOWER > -1
    SET_OUTPUT(SDPOWER);
    WRITE(SDPOWER,HIGH);
#endif
#if defined(SDCARDDETECT) && SDCARDDETECT>-1
    SET_INPUT(SDCARDDETECT);
    PULLUP(SDCARDDETECT,HIGH);
#endif
#endif
    //Initialize Step Pins
    SET_OUTPUT(X_STEP_PIN);
    SET_OUTPUT(Y_STEP_PIN);
    SET_OUTPUT(Z_STEP_PIN);
    //Initialize Dir Pins
#if X_DIR_PIN>-1
    SET_OUTPUT(X_DIR_PIN);
#endif
#if Y_DIR_PIN>-1
    SET_OUTPUT(Y_DIR_PIN);
#endif
#if Z_DIR_PIN>-1
    SET_OUTPUT(Z_DIR_PIN);
#endif
    //Steppers default to disabled.
#if X_ENABLE_PIN > -1
    SET_OUTPUT(X_ENABLE_PIN);
    WRITE(X_ENABLE_PIN,!X_ENABLE_ON);
#endif
#if Y_ENABLE_PIN > -1
    SET_OUTPUT(Y_ENABLE_PIN);
    WRITE(Y_ENABLE_PIN,!Y_ENABLE_ON);
#endif
#if Z_ENABLE_PIN > -1
    SET_OUTPUT(Z_ENABLE_PIN);
    WRITE(Z_ENABLE_PIN,!Z_ENABLE_ON);
#endif
#if FEATURE_TWO_XSTEPPER
    SET_OUTPUT(X2_STEP_PIN);
    SET_OUTPUT(X2_DIR_PIN);
#if X2_ENABLE_PIN > -1
    SET_OUTPUT(X2_ENABLE_PIN);
    WRITE(X2_ENABLE_PIN,!X_ENABLE_ON);
#endif
#endif
#if FEATURE_TWO_YSTEPPER
    SET_OUTPUT(Y2_STEP_PIN);
    SET_OUTPUT(Y2_DIR_PIN);
#if Y2_ENABLE_PIN > -1
    SET_OUTPUT(Y2_ENABLE_PIN);
    WRITE(Y2_ENABLE_PIN,!Y_ENABLE_ON);
#endif
#endif
#if FEATURE_TWO_ZSTEPPER
    SET_OUTPUT(Z2_STEP_PIN);
    SET_OUTPUT(Z2_DIR_PIN);
    SET_OUTPUT(Z2_ENABLE_PIN);
    WRITE(Z2_ENABLE_PIN,!Z_ENABLE_ON);
#endif
#endif
    //endstop pullups
#if MIN_HARDWARE_ENDSTOP_X
#if X_MIN_PIN>-1
    SET_INPUT(X_MIN_PIN);
#if ENDSTOP_PULLUP_X_MIN
    PULLUP(X_MIN_PIN,HIGH);
#endif
#else
#error You have defined hardware x min endstop without pin assignment. Set pin number for X_MIN_PIN
#endif
#endif
#if MIN_HARDWARE_ENDSTOP_Y
#if Y_MIN_PIN>-1
    SET_INPUT(Y_MIN_PIN);
#if ENDSTOP_PULLUP_Y_MIN
    PULLUP(Y_MIN_PIN,HIGH);
#endif
#else
#error You have defined hardware y min endstop without pin assignment. Set pin number for Y_MIN_PIN
#endif
#endif
#if MIN_HARDWARE_ENDSTOP_Z
#if Z_MIN_PIN>-1
    SET_INPUT(Z_MIN_PIN);
#if ENDSTOP_PULLUP_Z_MIN
    PULLUP(Z_MIN_PIN,HIGH);
#endif
#else
#error You have defined hardware z min endstop without pin assignment. Set pin number for Z_MIN_PIN
#endif
#endif
#if MAX_HARDWARE_ENDSTOP_X
#if X_MAX_PIN>-1
    SET_INPUT(X_MAX_PIN);
#if ENDSTOP_PULLUP_X_MAX
    PULLUP(X_MAX_PIN,HIGH);
#endif
#else
#error You have defined hardware x max endstop without pin assignment. Set pin number for X_MAX_PIN
#endif
#endif
#if MAX_HARDWARE_ENDSTOP_Y
#if Y_MAX_PIN>-1
    SET_INPUT(Y_MAX_PIN);
#if ENDSTOP_PULLUP_Y_MAX
    PULLUP(Y_MAX_PIN,HIGH);
#endif
#else
#error You have defined hardware y max endstop without pin assignment. Set pin number for Y_MAX_PIN
#endif
#endif
#if MAX_HARDWARE_ENDSTOP_Z
#if Z_MAX_PIN>-1
    SET_INPUT(Z_MAX_PIN);
#if ENDSTOP_PULLUP_Z_MAX
    PULLUP(Z_MAX_PIN,HIGH);
#endif
#else
#error You have defined hardware z max endstop without pin assignment. Set pin number for Z_MAX_PIN
#endif
#endif
#if FEATURE_Z_PROBE && Z_PROBE_PIN>-1
    SET_INPUT(Z_PROBE_PIN);
#if Z_PROBE_PULLUP
    PULLUP(Z_PROBE_PIN,HIGH);
#endif
#endif // FEATURE_FEATURE_Z_PROBE
#if FAN_PIN>-1 && FEATURE_FAN_CONTROL
    SET_OUTPUT(FAN_PIN);
    WRITE(FAN_PIN,LOW);
#endif
    SET_OUTPUT(FAN_BOARD_PIN);
    WRITE(FAN_BOARD_PIN,LOW);
#endif
#if defined(EXT0_HEATER_PIN) && EXT0_HEATER_PIN>-1
    SET_OUTPUT(EXT0_HEATER_PIN);
    WRITE(EXT0_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT1_HEATER_PIN) && EXT1_HEATER_PIN>-1 && NUM_EXTRUDER>1
    SET_OUTPUT(EXT1_HEATER_PIN);
    WRITE(EXT1_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT2_HEATER_PIN) && EXT2_HEATER_PIN>-1 && NUM_EXTRUDER>2
    SET_OUTPUT(EXT2_HEATER_PIN);
    WRITE(EXT2_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT3_HEATER_PIN) && EXT3_HEATER_PIN>-1 && NUM_EXTRUDER>3
    SET_OUTPUT(EXT3_HEATER_PIN);
    WRITE(EXT3_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT4_HEATER_PIN) && EXT4_HEATER_PIN>-1 && NUM_EXTRUDER>4
    SET_OUTPUT(EXT4_HEATER_PIN);
    WRITE(EXT4_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT5_HEATER_PIN) && EXT5_HEATER_PIN>-1 && NUM_EXTRUDER>5
    SET_OUTPUT(EXT5_HEATER_PIN);
    WRITE(EXT5_HEATER_PIN,HEATER_PINS_INVERTED);
#endif
#if defined(EXT0_EXTRUDER_COOLER_PIN) && EXT0_EXTRUDER_COOLER_PIN>-1
    SET_OUTPUT(EXT0_EXTRUDER_COOLER_PIN);
    WRITE(EXT0_EXTRUDER_COOLER_PIN,LOW);
#endif
#if defined(EXT1_EXTRUDER_COOLER_PIN) && EXT1_EXTRUDER_COOLER_PIN>-1 && NUM_EXTRUDER>1
    SET_OUTPUT(EXT1_EXTRUDER_COOLER_PIN);
    WRITE(EXT1_EXTRUDER_COOLER_PIN,LOW);
#endif
#if defined(EXT2_EXTRUDER_COOLER_PIN) && EXT2_EXTRUDER_COOLER_PIN>-1 && NUM_EXTRUDER>2
    SET_OUTPUT(EXT2_EXTRUDER_COOLER_PIN);
    WRITE(EXT2_EXTRUDER_COOLER_PIN,LOW);
#endif
#if defined(EXT3_EXTRUDER_COOLER_PIN) && EXT3_EXTRUDER_COOLER_PIN>-1 && NUM_EXTRUDER>3
    SET_OUTPUT(EXT3_EXTRUDER_COOLER_PIN);
    WRITE(EXT3_EXTRUDER_COOLER_PIN,LOW);
#endif
#if defined(EXT4_EXTRUDER_COOLER_PIN) && EXT4_EXTRUDER_COOLER_PIN>-1 && NUM_EXTRUDER>4
    SET_OUTPUT(EXT4_EXTRUDER_COOLER_PIN);
    WRITE(EXT4_EXTRUDER_COOLER_PIN,LOW);
#endif
#if defined(EXT5_EXTRUDER_COOLER_PIN) && EXT5_EXTRUDER_COOLER_PIN>-1 && NUM_EXTRUDER>5
    SET_OUTPUT(EXT5_EXTRUDER_COOLER_PIN);
    WRITE(EXT5_EXTRUDER_COOLER_PIN,LOW);
#endif
#if CASE_LIGHTS_PIN >= 0
    SET_OUTPUT(CASE_LIGHTS_PIN);
    WRITE(CASE_LIGHTS_PIN, CASE_LIGHT_DEFAULT_ON);
#endif // CASE_LIGHTS_PIN
#if GANTRY
    Printer::motorX = 0;
    Printer::motorYorZ = 0;
#endif
#if STEPPER_CURRENT_CONTROL != CURRENT_CONTROL_MANUAL
    motorCurrentControlInit(); // Set current if it is firmware controlled
#endif
    microstepInit();
    resetTransformationMatrix(true);
    feedrate = 50; ///< Current feedrate in mm/s.
    feedrateMultiply = 100;
    extrudeMultiply = 100;
    lastCmdPos[X_AXIS] = lastCmdPos[Y_AXIS] = lastCmdPos[Z_AXIS] = 0;
#if USE_ADVANCE
    advanceExecuted = 0;
#endif
    advanceStepsSet = 0;
#endif
    for(uint8_t i = 0; i < NUM_EXTRUDER + 3; i++) pwm_pos[i] = 0;
    maxJerk = MAX_JERK;
#if DRIVE_SYSTEM != DELTA
    maxZJerk = MAX_ZJERK;
#endif
    offsetX = offsetY = 0;
    interval = 5000;
    msecondsPrinting = 0;
    filamentPrinted = 0;
    flag0 = PRINTER_FLAG0_STEPPER_DISABLED;
    xLength = X_MAX_LENGTH;
    yLength = Y_MAX_LENGTH;
    zLength = Z_MAX_LENGTH;
    xMin = X_MIN_POS;
    yMin = Y_MIN_POS;
    zMin = Z_MIN_POS;
    radius0 = ROD_RADIUS;
#endif
    wasLastHalfstepping = 0;
    backlashX = X_BACKLASH;
    backlashY = Y_BACKLASH;
    backlashZ = Z_BACKLASH;
    backlashDir = 0;
#endif
#if USE_ADVANCE
    extruderStepsNeeded = 0;
#endif
    EEPROM::initBaudrate();
    HAL::serialSetBaudrate(baudrate);
    Com::printFLN(Com::tStart);
    UI_INITIALIZE;
    HAL::showStartReason();
    Extruder::initExtruder();
    // sets autoleveling in eeprom init
    EEPROM::init(); // Read settings from eeprom if wanted
        currentPositionSteps[i] = 0;
//setAutolevelActive(false); // fixme delete me
    //Commands::printCurrentPosition(PSTR("Printer::setup 0 "));
    distortion.init();
    updateDerivedParameter();
    Commands::checkFreeMemory();
    Commands::writeLowestFreeRAM();
    HAL::setupTimer();
    transformCartesianStepsToDeltaSteps(Printer::currentPositionSteps, Printer::currentDeltaPositionSteps);
#if DELTA_HOME_ON_POWER
    homeAxis(true,true,true);
#endif
    setAutoretract(EEPROM_BYTE(AUTORETRACT_ENABLED));
    Commands::printCurrentPosition(PSTR("Printer::setup "));
    Extruder::selectExtruderById(0);
#if SDSUPPORT
    sd.initsd();
#endif
#if FEATURE_WATCHDOG
    HAL::startWatchdog();
#endif // FEATURE_WATCHDOG
void Printer::defaultLoopActions()
    Commands::checkForPeriodicalActions(true);  //check heater every n milliseconds
    UI_MEDIUM; // do check encoder
    millis_t curtime = HAL::timeInMilliseconds();
    if(PrintLine::hasLines() || isMenuMode(MENU_MODE_SD_PAUSED))
        previousMillisCmd = curtime;
    else
        curtime -= previousMillisCmd;
        if(maxInactiveTime != 0 && curtime >  maxInactiveTime )
            Printer::kill(false);
        else
            Printer::setAllKilled(false); // prevent repeated kills
        if(stepperInactiveTime != 0 && curtime >  stepperInactiveTime )
            Printer::kill(true);
#if SDCARDDETECT>-1 && SDSUPPORT
    sd.automount();
#endif
    DEBUG_MEMORY;
void Printer::MemoryPosition()
    Commands::waitUntilEndOfAllMoves();
    realPosition(memoryX, memoryY, memoryZ);
    memoryE = currentPositionSteps[E_AXIS] * invAxisStepsPerMM[E_AXIS];
    memoryF = feedrate;
void Printer::GoToMemoryPosition(bool x, bool y, bool z, bool e, float feed)
    if(memoryF < 0) return; // Not stored before call, so we ignor eit
    bool all = !(x || y || z);
    moveToReal((all || x ? (lastCmdPos[X_AXIS] = memoryX) : IGNORE_COORDINATE)
               ,(all || y ?(lastCmdPos[Y_AXIS] = memoryY) : IGNORE_COORDINATE)
               ,(all || z ? (lastCmdPos[Z_AXIS] = memoryZ) : IGNORE_COORDINATE)
               ,(e ? memoryE : IGNORE_COORDINATE),
               feed);
    feedrate = memoryF;
void Printer::deltaMoveToTopEndstops(float feedrate)
    for (uint8_t i=0; i<3; i++)
        Printer::currentPositionSteps[i] = 0;
    transformCartesianStepsToDeltaSteps(currentPositionSteps, currentDeltaPositionSteps);
    PrintLine::moveRelativeDistanceInSteps(0,0,zMaxSteps*1.5,0,feedrate, true, true);
    offsetX = 0;
    offsetY = 0;
void Printer::homeXAxis()
    destinationSteps[X_AXIS] = 0;
    if (!PrintLine::queueDeltaMove(true,false,false))
        Com::printWarningFLN(PSTR("homeXAxis / queueDeltaMove returns error"));
void Printer::homeYAxis()
    Printer::destinationSteps[Y_AXIS] = 0;
        Com::printWarningFLN(PSTR("homeYAxis / queueDeltaMove returns error"));
void Printer::homeZAxis() // Delta z homing
    SHOT("homeZAxis ");
    deltaMoveToTopEndstops(Printer::homingFeedrate[Z_AXIS]);
    PrintLine::moveRelativeDistanceInSteps(0, 0, 2 * axisStepsPerMM[Z_AXIS] * -ENDSTOP_Z_BACK_MOVE, 0, Printer::homingFeedrate[Z_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR, true, false);
    deltaMoveToTopEndstops(Printer::homingFeedrate[Z_AXIS] / ENDSTOP_Z_RETEST_REDUCTION_FACTOR);
#if defined(ENDSTOP_Z_BACK_ON_HOME)
    if(ENDSTOP_Z_BACK_ON_HOME > 0)
        PrintLine::moveRelativeDistanceInSteps(0, 0, axisStepsPerMM[Z_AXIS] * -ENDSTOP_Z_BACK_ON_HOME * Z_HOME_DIR,0,homingFeedrate[Z_AXIS], true, false);
#endif
    // Correct different endstop heights
    // These can be adjusted by two methods. You can use offsets stored by determining the center
    // or you can use the xyzMinSteps from G100 calibration. Both have the same effect but only one
    // should be measuredas both have the same effect.
    long dx = -xMinSteps - EEPROM::deltaTowerXOffsetSteps();
    long dy = -yMinSteps - EEPROM::deltaTowerYOffsetSteps();
    long dz = -zMinSteps - EEPROM::deltaTowerZOffsetSteps();
    long dm = RMath::min(dx, dy, dz);
    //Com::printFLN(Com::tTower1,dx);
    //Com::printFLN(Com::tTower2,dy);
    //Com::printFLN(Com::tTower3,dz);
    dx -= dm; // now all dxyz are positive
    dy -= dm;
    dz -= dm;
    currentPositionSteps[X_AXIS] = 0;
    currentPositionSteps[Y_AXIS] = 0;
    currentPositionSteps[Z_AXIS] = zMaxSteps;
    transformCartesianStepsToDeltaSteps(currentPositionSteps,currentDeltaPositionSteps);
    currentDeltaPositionSteps[A_TOWER] -= dx;
    currentDeltaPositionSteps[B_TOWER] -= dy;
    currentDeltaPositionSteps[C_TOWER] -= dz;
    PrintLine::moveRelativeDistanceInSteps(0,0,dm,0,homingFeedrate[Z_AXIS],true,false);
    currentPositionSteps[Z_AXIS] = zMaxSteps; // Extruder is now exactly in the delta center
    coordinateOffset[X_AXIS] = 0;
    coordinateOffset[Y_AXIS] = 0;
    coordinateOffset[Z_AXIS] = 0;
    realDeltaPositionSteps[A_TOWER] = currentDeltaPositionSteps[A_TOWER];
    realDeltaPositionSteps[B_TOWER] = currentDeltaPositionSteps[B_TOWER];
    realDeltaPositionSteps[C_TOWER] = currentDeltaPositionSteps[C_TOWER];
    //maxDeltaPositionSteps = currentDeltaPositionSteps[X_AXIS];
        maxDeltaPositionSteps += axisStepsPerMM[Z_AXIS]*ENDSTOP_Z_BACK_ON_HOME;
#endif
    Extruder::selectExtruderById(Extruder::current->id);
// This home axis is for delta
void Printer::homeAxis(bool xaxis,bool yaxis,bool zaxis) // Delta homing code
    SHOT("homeAxis ");
    bool autoLevel = isAutolevelActive();
    long steps;
    setHomed(true);
    bool homeallaxis = (xaxis && yaxis && zaxis) || (!xaxis && !yaxis && !zaxis);
    if (!(X_MAX_PIN > -1 && Y_MAX_PIN > -1 && Z_MAX_PIN > -1
            && MAX_HARDWARE_ENDSTOP_X && MAX_HARDWARE_ENDSTOP_Y && MAX_HARDWARE_ENDSTOP_Z))
        Com::printErrorFLN(PSTR("Hardware setup inconsistent. Delta cannot home wihtout max endstops."));
    // The delta has to have home capability to zero and set position,
    // so the redundant check is only an opportunity to
    // gratuitously fail due to incorrect settings.
    // The following movements would be meaningless unless it was zeroed for example.
    UI_STATUS_UPD(UI_TEXT_HOME_DELTA);
    // Homing Z axis means that you must home X and Y
    if (homeallaxis || zaxis)
        homeZAxis();
    else
        if (xaxis) Printer::destinationSteps[X_AXIS] = 0;
        if (yaxis) Printer::destinationSteps[Y_AXIS] = 0;
            Com::printWarningFLN(PSTR("homeAxis / queueDeltaMove returns error"));
    moveToReal(0,0,Printer::zLength,IGNORE_COORDINATE,homingFeedrate[Z_AXIS]); // Move to designed coordinates including translation
    UI_CLEAR_STATUS
    Commands::printCurrentPosition(PSTR("homeAxis "));
    setAutolevelActive(autoLevel);
#else
#if DRIVE_SYSTEM==TUGA  // Tuga printer homing
    long steps;
    if ((MIN_HARDWARE_ENDSTOP_X && X_MIN_PIN > -1 && X_HOME_DIR==-1 && MIN_HARDWARE_ENDSTOP_Y && Y_MIN_PIN > -1 && Y_HOME_DIR==-1) ||
            (MAX_HARDWARE_ENDSTOP_X && X_MAX_PIN > -1 && X_HOME_DIR==1 && MAX_HARDWARE_ENDSTOP_Y && Y_MAX_PIN > -1 && Y_HOME_DIR==1))
        long offX = 0,offY = 0;
#if NUM_EXTRUDER>1
        for(uint8_t i=0; i<NUM_EXTRUDER; i++)
#if X_HOME_DIR < 0
            offX = RMath::max(offX,extruder[i].xOffset);
            offY = RMath::max(offY,extruder[i].yOffset);
#else
            offX = RMath::min(offX,extruder[i].xOffset);
            offY = RMath::min(offY,extruder[i].yOffset);
#endif
        // Reposition extruder that way, that all extruders can be selected at home pos.
#endif
        UI_STATUS_UPD(UI_TEXT_HOME_X);
        steps = (Printer::xMaxSteps-Printer::xMinSteps) * X_HOME_DIR;
        currentPositionSteps[X_AXIS] = -steps;
        PrintLine::moveRelativeDistanceInSteps(2*steps,0,0,0,homingFeedrate[X_AXIS],true,true);
        currentPositionSteps[X_AXIS] = (X_HOME_DIR == -1) ? xMinSteps-offX : xMaxSteps+offX;
        currentPositionSteps[Y_AXIS] = 0; //(Y_HOME_DIR == -1) ? yMinSteps-offY : yMaxSteps+offY;
        //PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*-ENDSTOP_X_BACK_MOVE * X_HOME_DIR,axisStepsPerMM[Y_AXIS]*-ENDSTOP_X_BACK_MOVE * Y_HOME_DIR,0,0,homingFeedrate[X_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,false);
        // PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*2*ENDSTOP_X_BACK_MOVE * X_HOME_DIR,axisStepsPerMM[Y_AXIS]*2*ENDSTOP_X_BACK_MOVE * Y_HOME_DIR,0,0,homingFeedrate[X_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,true);
        PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*-ENDSTOP_X_BACK_MOVE * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,false);
        PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*2*ENDSTOP_X_BACK_MOVE * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,true);
#if defined(ENDSTOP_X_BACK_ON_HOME)
        if(ENDSTOP_X_BACK_ON_HOME > 0)
            PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*-ENDSTOP_X_BACK_ON_HOME * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS],true,false);
        // PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS]*-ENDSTOP_X_BACK_ON_HOME * X_HOME_DIR,axisStepsPerMM[Y_AXIS]*-ENDSTOP_Y_BACK_ON_HOME * Y_HOME_DIR,0,0,homingFeedrate[X_AXIS],true,false);
#endif
#if NUM_EXTRUDER>1
        PrintLine::moveRelativeDistanceInSteps((Extruder::current->xOffset-offX) * X_HOME_DIR,(Extruder::current->yOffset-offY) * Y_HOME_DIR,0,0,homingFeedrate[X_AXIS],true,false);
#endif
    // Dummy function x and y homing must occur together
#else // cartesian printer
    long steps;
    if ((MIN_HARDWARE_ENDSTOP_X && X_MIN_PIN > -1 && X_HOME_DIR==-1) || (MAX_HARDWARE_ENDSTOP_X && X_MAX_PIN > -1 && X_HOME_DIR==1))
        long offX = 0;
#if NUM_EXTRUDER>1
#if X_HOME_DIR < 0
#else
#endif
#endif
        currentPositionSteps[X_AXIS] = (X_HOME_DIR == -1) ? xMinSteps-offX : xMaxSteps + offX;
        PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS] * -ENDSTOP_X_BACK_MOVE * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS] / ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,false);
        PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS] * 2 * ENDSTOP_X_BACK_MOVE * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS] / ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,true);
            PrintLine::moveRelativeDistanceInSteps(axisStepsPerMM[X_AXIS] * -ENDSTOP_X_BACK_ON_HOME * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS],true,false);
#endif
#if NUM_EXTRUDER>1
        PrintLine::moveRelativeDistanceInSteps((Extruder::current->xOffset-offX) * X_HOME_DIR,0,0,0,homingFeedrate[X_AXIS],true,false);
#endif
    long steps;
    if ((MIN_HARDWARE_ENDSTOP_Y && Y_MIN_PIN > -1 && Y_HOME_DIR==-1) || (MAX_HARDWARE_ENDSTOP_Y && Y_MAX_PIN > -1 && Y_HOME_DIR==1))
        long offY = 0;
#if NUM_EXTRUDER>1
#if Y_HOME_DIR<0
#else
#endif
#endif
        UI_STATUS_UPD(UI_TEXT_HOME_Y);
        steps = (yMaxSteps-Printer::yMinSteps) * Y_HOME_DIR;
        currentPositionSteps[Y_AXIS] = -steps;
        PrintLine::moveRelativeDistanceInSteps(0,2*steps,0,0,homingFeedrate[Y_AXIS],true,true);
        currentPositionSteps[Y_AXIS] = (Y_HOME_DIR == -1) ? yMinSteps-offY : yMaxSteps+offY;
        PrintLine::moveRelativeDistanceInSteps(0,axisStepsPerMM[Y_AXIS]*-ENDSTOP_Y_BACK_MOVE * Y_HOME_DIR,0,0,homingFeedrate[Y_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,false);
        PrintLine::moveRelativeDistanceInSteps(0,axisStepsPerMM[Y_AXIS]*2*ENDSTOP_Y_BACK_MOVE * Y_HOME_DIR,0,0,homingFeedrate[Y_AXIS]/ENDSTOP_X_RETEST_REDUCTION_FACTOR,true,true);
#if defined(ENDSTOP_Y_BACK_ON_HOME)
        if(ENDSTOP_Y_BACK_ON_HOME > 0)
            PrintLine::moveRelativeDistanceInSteps(0,axisStepsPerMM[Y_AXIS]*-ENDSTOP_Y_BACK_ON_HOME * Y_HOME_DIR,0,0,homingFeedrate[Y_AXIS],true,false);
#endif
#if NUM_EXTRUDER>1
        PrintLine::moveRelativeDistanceInSteps(0,(Extruder::current->yOffset-offY) * Y_HOME_DIR,0,0,homingFeedrate[Y_AXIS],true,false);
#endif
#endif
void Printer::homeZAxis() // cartesian homing
    long steps;
    if ((MIN_HARDWARE_ENDSTOP_Z && Z_MIN_PIN > -1 && Z_HOME_DIR==-1) || (MAX_HARDWARE_ENDSTOP_Z && Z_MAX_PIN > -1 && Z_HOME_DIR==1))
        UI_STATUS_UPD(UI_TEXT_HOME_Z);
        steps = (zMaxSteps - zMinSteps) * Z_HOME_DIR;
        currentPositionSteps[Z_AXIS] = -steps;
        PrintLine::moveRelativeDistanceInSteps(0,0,2*steps,0,homingFeedrate[Z_AXIS],true,true);
        currentPositionSteps[Z_AXIS] = (Z_HOME_DIR == -1) ? zMinSteps : zMaxSteps;
        PrintLine::moveRelativeDistanceInSteps(0,0,axisStepsPerMM[Z_AXIS]*-ENDSTOP_Z_BACK_MOVE * Z_HOME_DIR,0,homingFeedrate[Z_AXIS]/ENDSTOP_Z_RETEST_REDUCTION_FACTOR,true,false);
        PrintLine::moveRelativeDistanceInSteps(0,0,axisStepsPerMM[Z_AXIS]*2*ENDSTOP_Z_BACK_MOVE * Z_HOME_DIR,0,homingFeedrate[Z_AXIS]/ENDSTOP_Z_RETEST_REDUCTION_FACTOR,true,true);
            PrintLine::moveRelativeDistanceInSteps(0,0,axisStepsPerMM[Z_AXIS]*-ENDSTOP_Z_BACK_ON_HOME * Z_HOME_DIR,0,homingFeedrate[Z_AXIS],true,false);
#endif
        currentDeltaPositionSteps[C_TOWER] = currentPositionSteps[Z_AXIS];
#endif
void Printer::homeAxis(bool xaxis,bool yaxis,bool zaxis) // home non-delta printer
    float startX,startY,startZ;
    realPosition(startX,startY,startZ);
    setHomed(true);
#if !defined(HOMING_ORDER)
#define HOMING_ORDER HOME_ORDER_XYZ
#endif
#if HOMING_ORDER==HOME_ORDER_XYZ
    if(xaxis) homeXAxis();
    if(yaxis) homeYAxis();
    if(zaxis) homeZAxis();
#elif HOMING_ORDER==HOME_ORDER_XZY
#elif HOMING_ORDER==HOME_ORDER_YXZ
#elif HOMING_ORDER==HOME_ORDER_YZX
#elif HOMING_ORDER==HOME_ORDER_ZXY
#elif HOMING_ORDER==HOME_ORDER_ZYX
#endif
    if(xaxis)
        if(X_HOME_DIR < 0) startX = Printer::xMin;
        else startX = Printer::xMin+Printer::xLength;
    if(yaxis)
        if(Y_HOME_DIR < 0) startY = Printer::yMin;
        else startY = Printer::yMin+Printer::yLength;
    if(zaxis)
        if(Z_HOME_DIR < 0) startZ = Printer::zMin;
        else startZ = Printer::zMin+Printer::zLength;
    moveToReal(startX, startY, startZ, IGNORE_COORDINATE, homingFeedrate[X_AXIS]);
    UI_CLEAR_STATUS
#endif  // Not delta printer
void Printer::zBabystep()
    bool dir = zBabystepsMissing > 0;
    if(dir) zBabystepsMissing--;
    else zBabystepsMissing++;
#if DRIVE_SYSTEM == 3
    Printer::enableXStepper();
    Printer::enableYStepper();
#endif
    Printer::enableZStepper();
    Printer::unsetAllSteppersDisabled();
    bool xDir = Printer::getXDirection();
    bool yDir = Printer::getYDirection();
#endif
    bool zDir = Printer::getZDirection();
    Printer::setXDirection(dir);
    Printer::setYDirection(dir);
#endif
    Printer::setZDirection(dir);
#if defined(DIRECTION_DELAY) && DIRECTION_DELAY > 0
    HAL::delayMicroseconds(DIRECTION_DELAY);
#else
    HAL::delayMicroseconds(1);
#endif
    WRITE(X_STEP_PIN,HIGH);
    WRITE(X2_STEP_PIN,HIGH);
#endif
    WRITE(Y_STEP_PIN,HIGH);
    WRITE(Y2_STEP_PIN,HIGH);
#endif
#endif
    WRITE(Z_STEP_PIN,HIGH);
    WRITE(Z2_STEP_PIN,HIGH);
#endif
    HAL::delayMicroseconds(STEPPER_HIGH_DELAY + 2);
    Printer::endXYZSteps();
    Printer::setXDirection(xDir);
    Printer::setYDirection(yDir);
#endif
    Printer::setZDirection(zDir);
#endif
    //HAL::delayMicroseconds(STEPPER_HIGH_DELAY + 1);
void Printer::setAutolevelActive(bool on)
    if(on == isAutolevelActive()) return;
    flag0 = (on ? flag0 | PRINTER_FLAG0_AUTOLEVEL_ACTIVE : flag0 & ~PRINTER_FLAG0_AUTOLEVEL_ACTIVE);
    if(on)
        Com::printInfoFLN(Com::tAutolevelEnabled);
    else
        Com::printInfoFLN(Com::tAutolevelDisabled);
#endif // FEATURE_AUTOLEVEL    if(isAutolevelActive()==on) return;
float Printer::runZMaxProbe()
    long startZ = realDeltaPositionSteps[Z_AXIS] = currentDeltaPositionSteps[Z_AXIS]; // update real
#endif
    long probeDepth = 2*(Printer::zMaxSteps-Printer::zMinSteps);
    stepsRemainingAtZHit = -1;
    setZProbingActive(true);
    PrintLine::moveRelativeDistanceInSteps(0,0,probeDepth,0,EEPROM::zProbeSpeed(),true,true);
    if(stepsRemainingAtZHit < 0)
        Com::printErrorFLN(Com::tZProbeFailed);
        return -1;
    setZProbingActive(false);
    currentPositionSteps[Z_AXIS] -= stepsRemainingAtZHit;
    probeDepth -= (realDeltaPositionSteps[Z_AXIS] - startZ);
#else
    probeDepth -= stepsRemainingAtZHit;
#endif
    float distance = (float)probeDepth * invAxisStepsPerMM[Z_AXIS];
    Com::printF(Com::tZProbeMax,distance);
    Com::printF(Com::tSpaceXColon,realXPosition());
    Com::printFLN(Com::tSpaceYColon,realYPosition());
    PrintLine::moveRelativeDistanceInSteps(0,0,-probeDepth,0,EEPROM::zProbeSpeed(),true,true);
    return distance;
#endif
void accelerometer_status();
#if FEATURE_Z_PROBE
float Printer::runZProbe(bool first,bool last,uint8_t repeat,bool runStartScript)
    float oldOffX = Printer::offsetX;
    float oldOffY = Printer::offsetY;
    float vals[repeat];
    if(first)
        if(runStartScript)
            GCode::executeFString(Com::tZProbeStartScript);
        if(currentPosition[Z_AXIS] > EEPROM::zProbeBedDistance()) {
            moveTo(IGNORE_COORDINATE,IGNORE_COORDINATE,EEPROM::zProbeBedDistance(),IGNORE_COORDINATE,homingFeedrate[Z_AXIS]);
        Printer::offsetX = -EEPROM::zProbeXOffset();
        Printer::offsetY = -EEPROM::zProbeYOffset();
        PrintLine::moveRelativeDistanceInSteps((Printer::offsetX - oldOffX) * Printer::axisStepsPerMM[X_AXIS],
                                               (Printer::offsetY - oldOffY) * Printer::axisStepsPerMM[Y_AXIS],
                                               0, 0, EEPROM::zProbeXYSpeed(), true, ALWAYS_CHECK_ENDSTOPS);
    int32_t sum = 0, probeDepth;
    int32_t shortMove = static_cast<int32_t>((float)Z_PROBE_SWITCHING_DISTANCE * axisStepsPerMM[Z_AXIS]); // distance to go up for repeated moves
    int32_t lastCorrection = currentPositionSteps[Z_AXIS]; // starting position
#endif
    int32_t updateZ = 0;
    for(int8_t r = 0; r < repeat; r++)
        probeDepth = 2 * (Printer::zMaxSteps - Printer::zMinSteps); // probe should always hit within this distance
        stepsRemainingAtZHit = -1; // Marker that we did not hit z probe
        int32_t offx = axisStepsPerMM[X_AXIS] * EEPROM::zProbeXOffset();
        int32_t offy = axisStepsPerMM[Y_AXIS] * EEPROM::zProbeYOffset();
        //PrintLine::moveRelativeDistanceInSteps(-offx,-offy,0,0,EEPROM::zProbeXYSpeed(),true,true);
        waitForZProbeStart();
        accelerometer_status(); //Clear Interrupt.
        Com::printF(Com::tZProbeState); Com::print(Printer::isZProbeHit() ? 'H' : 'L'); Com::println();
        for(int i=0;i<10;i++)
          if( ! Printer::isZProbeHit() ) break;
          Com::printFLN(PSTR("delay 100ms."));
          delay(100);
        Com::printFLN(PSTR("zprobing..."));
        PrintLine::moveRelativeDistanceInSteps(0, 0, -probeDepth, 0, EEPROM::zProbeSpeed(), true, true);
            return -1;
        Com::printFLN(PSTR("Steps remaining: "), stepsRemainingAtZHit);
        stepsRemainingAtZHit = realDeltaPositionSteps[C_TOWER] - currentDeltaPositionSteps[C_TOWER]; // nonlinear moves may split z so stepsRemainingAtZHit is only what is left from last segment not total move. This corrects the problem.
#endif
        currentDeltaPositionSteps[A_TOWER] += stepsRemainingAtZHit; // Update difference
        currentDeltaPositionSteps[B_TOWER] += stepsRemainingAtZHit;
        currentDeltaPositionSteps[C_TOWER] += stepsRemainingAtZHit;
#endif
        currentPositionSteps[Z_AXIS] += stepsRemainingAtZHit; // now current position is correct
      /*  if(r == 0 && first)  // Modify start z position on first probe hit to speed the ZProbe process
            int32_t newLastCorrection = currentPositionSteps[Z_AXIS] + (int32_t)((float)EEPROM::zProbeBedDistance() * axisStepsPerMM[Z_AXIS]);
            if(newLastCorrection < lastCorrection) // don't want to go all the way up again, fix discrepancy and retest
                updateZ = lastCorrection - newLastCorrection;
                lastCorrection = newLastCorrection;
                first = false;
                PrintLine::moveRelativeDistanceInSteps(0, 0, lastCorrection - currentPositionSteps[Z_AXIS], 0, EEPROM::zProbeSpeed(), true, false);
                r--;
        vals[r] = currentPositionSteps[Z_AXIS];
        sum += lastCorrection - currentPositionSteps[Z_AXIS];
        if(r + 1 < repeat) // go only shortes possible move up for repetitions
            PrintLine::moveRelativeDistanceInSteps(0, 0, shortMove, 0, EEPROM::zProbeSpeed(), true, false);
    for (int i = 0; i < repeat; ++i){
              Com::printF(PSTR("  "), vals[i]);
    float distance = static_cast<float>(sum) * invAxisStepsPerMM[Z_AXIS] / static_cast<float>(repeat) + EEPROM::zProbeHeight();
    float zCorr = distortion.correct(currentPositionSteps[X_AXIS] + EEPROM::zProbeXOffset() * axisStepsPerMM[X_AXIS],currentPositionSteps[Y_AXIS]
                                     + EEPROM::zProbeYOffset() * axisStepsPerMM[Y_AXIS],0) * invAxisStepsPerMM[Z_AXIS];
    distance += zCorr;
#endif
    Com::printF(Com::tZProbe, distance);
    Com::printF(Com::tZProbeSteps,(distance * 80) - (Z_PROBE_BED_DISTANCE * 80));
    Com::printF(Com::tSpaceXColon, realXPosition());
    Com::printF(Com::tSpaceYColon, realYPosition());
    Com::printFLN(PSTR(" zCorr:"), zCorr);
#else
    Com::printFLN(Com::tSpaceYColon, realYPosition());
#endif
    // Go back to start position
    //PrintLine::moveRelativeDistanceInSteps(offx,offy,0,0,EEPROM::zProbeXYSpeed(),true,true);
    if(last)
        GCode::executeFString(Com::tZProbeEndScript);
        if(Extruder::current)
            Printer::offsetX = -Extruder::current->xOffset * Printer::invAxisStepsPerMM[X_AXIS];
            Printer::offsetY = -Extruder::current->yOffset * Printer::invAxisStepsPerMM[Y_AXIS];
                                               (Printer::offsetY - oldOffY) * Printer::axisStepsPerMM[Y_AXIS], 0, 0, EEPROM::zProbeXYSpeed(), true, ALWAYS_CHECK_ENDSTOPS);
    return distance;
void Printer::waitForZProbeStart()
#if Z_PROBE_WAIT_BEFORE_TEST
    if(isZProbeHit()) return;
#if UI_DISPLAY_TYPE != NO_DISPLAY
    uid.setStatusP(Com::tHitZProbe);
    uid.refreshPage();
#endif
#ifdef DEBUG_PRINT
    debugWaitLoop = 3;
#endif
    while(!isZProbeHit())
        defaultLoopActions();
#ifdef DEBUG_PRINT
    debugWaitLoop = 4;
#endif
    HAL::delayMilliseconds(30);
    while(isZProbeHit())
    UI_CLEAR_STATUS;
#endif
#endif
void Printer::transformToPrinter(float x,float y,float z,float &transX,float &transY,float &transZ)
#if FEATURE_AXISCOMP
    // Axis compensation:
    x = x + y * EEPROM::axisCompTanXY() + z * EEPROM::axisCompTanXZ();
    y = y + z * EEPROM::axisCompTanYZ();
#endif
    transX = x * autolevelTransformation[0] + y * autolevelTransformation[3] + z * autolevelTransformation[6];
    transY = x * autolevelTransformation[1] + y * autolevelTransformation[4] + z * autolevelTransformation[7];
    transZ = x * autolevelTransformation[2] + y * autolevelTransformation[5] + z * autolevelTransformation[8];
void Printer::transformFromPrinter(float x,float y,float z,float &transX,float &transY,float &transZ)
    transX = x * autolevelTransformation[0] + y * autolevelTransformation[1] + z * autolevelTransformation[2];
    transY = x * autolevelTransformation[3] + y * autolevelTransformation[4] + z * autolevelTransformation[5];
    transZ = x * autolevelTransformation[6] + y * autolevelTransformation[7] + z * autolevelTransformation[8];
    transY = transY - transZ * EEPROM::axisCompTanYZ();
    transX = transX - transY * EEPROM::axisCompTanXY() - transZ * EEPROM::axisCompTanXZ();
#endif
void Printer::resetTransformationMatrix(bool silent)
    autolevelTransformation[0] = autolevelTransformation[4] = autolevelTransformation[8] = 1;
    autolevelTransformation[1] = autolevelTransformation[2] = autolevelTransformation[3] =
                                     autolevelTransformation[5] = autolevelTransformation[6] = autolevelTransformation[7] = 0;
    if(!silent)
        Com::printInfoFLN(Com::tAutolevelReset);
void Printer::buildTransformationMatrix(float h1,float h2,float h3)
    float ax = EEPROM::zProbeX2()-EEPROM::zProbeX1();
    float ay = EEPROM::zProbeY2()-EEPROM::zProbeY1();
    float az = h1-h2;
    float bx = EEPROM::zProbeX3()-EEPROM::zProbeX1();
    float by = EEPROM::zProbeY3()-EEPROM::zProbeY1();
    float bz = h1-h3;
    // First z direction
    autolevelTransformation[6] = ay * bz - az * by;
    autolevelTransformation[7] = az * bx - ax * bz;
    autolevelTransformation[8] = ax * by - ay * bx;
    float len = sqrt(autolevelTransformation[6] * autolevelTransformation[6] + autolevelTransformation[7] * autolevelTransformation[7] + autolevelTransformation[8] * autolevelTransformation[8]);
    if(autolevelTransformation[8] < 0) len = -len;
    autolevelTransformation[6] /= len;
    autolevelTransformation[7] /= len;
    autolevelTransformation[8] /= len;
    autolevelTransformation[3] = 0;
    autolevelTransformation[4] = autolevelTransformation[8];
    autolevelTransformation[5] = -autolevelTransformation[7];
    // cross(y,z)
    autolevelTransformation[0] = autolevelTransformation[4] * autolevelTransformation[8] - autolevelTransformation[5] * autolevelTransformation[7];
    autolevelTransformation[1] = autolevelTransformation[5] * autolevelTransformation[6] - autolevelTransformation[3] * autolevelTransformation[8];
    autolevelTransformation[2] = autolevelTransformation[3] * autolevelTransformation[7] - autolevelTransformation[4] * autolevelTransformation[6];
    len = sqrt(autolevelTransformation[0] * autolevelTransformation[0] + autolevelTransformation[2] * autolevelTransformation[2]);
    autolevelTransformation[0] /= len;
    autolevelTransformation[2] /= len;
    len = sqrt(autolevelTransformation[4] * autolevelTransformation[4] + autolevelTransformation[5] * autolevelTransformation[5]);
    autolevelTransformation[4] /= len;
    autolevelTransformation[5] /= len;
    Com::printArrayFLN(Com::tTransformationMatrix,autolevelTransformation, 9, 6);
#endif
void Printer::setCaseLight(bool on) {
#if CASE_LIGHTS_PIN > -1
    WRITE(CASE_LIGHTS_PIN,on);
    reportCaseLightStatus();
#endif
void Printer::reportCaseLightStatus() {
    if(READ(CASE_LIGHTS_PIN))
        Com::printInfoFLN(PSTR("Case lights on"));
    else
        Com::printInfoFLN(PSTR("Case lights off"));
#else
    Com::printInfoFLN(PSTR("No case lights"));
#endif
#define START_EXTRUDER_CONFIG(i)     Com::printF(Com::tConfig);Com::printF(Com::tExtrDot,i+1);Com::print(':');
void Printer::showConfiguration() {
    Com::config(PSTR("Baudrate:"),baudrate);
    Com::config(PSTR("InputBuffer:"),SERIAL_BUFFER_SIZE - 1);
    Com::config(PSTR("NumExtruder:"),NUM_EXTRUDER);
    Com::config(PSTR("MixingExtruder:"),MIXING_EXTRUDER);
    Com::config(PSTR("HeatedBed:"),HAVE_HEATED_BED);
    Com::config(PSTR("SDCard:"),SDSUPPORT);
    Com::config(PSTR("Fan:"),FAN_PIN > -1 && FEATURE_FAN_CONTROL);
    Com::config(PSTR("LCD:"),FEATURE_CONTROLLER != NO_CONTROLLER);
    Com::config(PSTR("SoftwarePowerSwitch:"),PS_ON_PIN > -1);
    Com::config(PSTR("XHomeDir:"),X_HOME_DIR);
    Com::config(PSTR("YHomeDir:"),Y_HOME_DIR);
    Com::config(PSTR("ZHomeDir:"),Z_HOME_DIR);
    Com::config(PSTR("SupportG10G11:"),FEATURE_RETRACTION);
    Com::config(PSTR("SupportLocalFilamentchange:"),FEATURE_RETRACTION);
    Com::config(PSTR("CaseLights:"),CASE_LIGHTS_PIN > -1);
    Com::config(PSTR("ZProbe:"),FEATURE_Z_PROBE);
    Com::config(PSTR("Autolevel:"),FEATURE_AUTOLEVEL);
    Com::config(PSTR("EEPROM:"),EEPROM_MODE != 0);
    Com::config(PSTR("PrintlineCache:"), PRINTLINE_CACHE_SIZE);
    Com::config(PSTR("JerkXY:"),maxJerk);
    Com::config(PSTR("JerkZ:"),maxZJerk);
#endif
    Com::config(PSTR("RetractionLength:"),EEPROM_FLOAT(RETRACTION_LENGTH));
    Com::config(PSTR("RetractionLongLength:"),EEPROM_FLOAT(RETRACTION_LONG_LENGTH));
    Com::config(PSTR("RetractionSpeed:"),EEPROM_FLOAT(RETRACTION_SPEED));
    Com::config(PSTR("RetractionZLift:"),EEPROM_FLOAT(RETRACTION_Z_LIFT));
    Com::config(PSTR("RetractionUndoExtraLength:"),EEPROM_FLOAT(RETRACTION_UNDO_EXTRA_LENGTH));
    Com::config(PSTR("RetractionUndoExtraLongLength:"),EEPROM_FLOAT(RETRACTION_UNDO_EXTRA_LONG_LENGTH));
    Com::config(PSTR("RetractionUndoSpeed:"),EEPROM_FLOAT(RETRACTION_UNDO_SPEED));
#endif // FEATURE_RETRACTION
    Com::config(PSTR("XMin:"),xMin);
    Com::config(PSTR("YMin:"),yMin);
    Com::config(PSTR("ZMin:"),zMin);
    Com::config(PSTR("XMax:"),xMin + xLength);
    Com::config(PSTR("YMax:"),yMin + yLength);
    Com::config(PSTR("ZMax:"),zMin + zLength);
    Com::config(PSTR("XSize:"), xLength);
    Com::config(PSTR("YSize:"), yLength);
    Com::config(PSTR("ZSize:"), zLength);
    Com::config(PSTR("XPrintAccel:"), maxAccelerationMMPerSquareSecond[X_AXIS]);
    Com::config(PSTR("YPrintAccel:"), maxAccelerationMMPerSquareSecond[Y_AXIS]);
    Com::config(PSTR("ZPrintAccel:"), maxAccelerationMMPerSquareSecond[Z_AXIS]);
    Com::config(PSTR("XTravelAccel:"), maxTravelAccelerationMMPerSquareSecond[X_AXIS]);
    Com::config(PSTR("YTravelAccel:"), maxTravelAccelerationMMPerSquareSecond[Y_AXIS]);
    Com::config(PSTR("ZTravelAccel:"), maxTravelAccelerationMMPerSquareSecond[Z_AXIS]);
    Com::config(PSTR("PrinterType:Delta"));
#else
    Com::config(PSTR("PrinterType:Cartesian"));
    Com::config(PSTR("MaxBedTemp:"), HEATED_BED_MAX_TEMP);
    for(fast8_t i = 0; i < NUM_EXTRUDER; i++) {
        Com::printFLN(PSTR("Jerk:"),extruder[i].maxStartFeedrate);
        Com::printFLN(PSTR("MaxSpeed:"),extruder[i].maxFeedrate);
        Com::printFLN(PSTR("Acceleration:"),extruder[i].maxAcceleration);
        Com::printFLN(PSTR("Diameter:"),extruder[i].diameter);
        Com::printFLN(PSTR("MaxTemp:"),MAXTEMP);
Distortion Printer::distortion;
void Printer::measureDistortion(void)
    distortion.measure();
Distortion::Distortion()
void Distortion::init() {
    updateDerived();
#if !DISTORTION_PERMANENT
    resetCorrection();
#endif
#if EEPROM_MODE != 0
    enabled = EEPROM::isZCorrectionEnabled();
    Com::printFLN(PSTR("zDistortionCorrection:"),(int)enabled);
#else
    enabled = false;
#endif
void Distortion::updateDerived()
    step = (2 * Printer::axisStepsPerMM[Z_AXIS] * DISTORTION_CORRECTION_R) / (DISTORTION_CORRECTION_POINTS - 1.0f);
    radiusCorrectionSteps = DISTORTION_CORRECTION_R * Printer::axisStepsPerMM[Z_AXIS];
    zStart = DISTORTION_START_DEGRADE * Printer::axisStepsPerMM[Z_AXIS];
    zEnd = DISTORTION_END_HEIGHT * Printer::axisStepsPerMM[Z_AXIS];
void Distortion::enable(bool permanent)
    enabled = true;
#if DISTORTION_PERMANENT
    if(permanent)
        EEPROM::setZCorrectionEnabled(enabled);
#endif
    Com::printFLN(Com::tZCorrectionEnabled);
void Distortion::disable(bool permanent)
    enabled = false;
    if(permanent)
#endif
    Com::printFLN(Com::tZCorrectionDisabled);
void Distortion::reportStatus() {
    Com::printFLN(enabled ? Com::tZCorrectionEnabled : Com::tZCorrectionDisabled);
void Distortion::resetCorrection(void)
    for(int i = 0; i < DISTORTION_CORRECTION_POINTS * DISTORTION_CORRECTION_POINTS; i++)
        setMatrix(0, i);
int Distortion::matrixIndex(fast8_t x, fast8_t y) const
    return static_cast<int>(y) * DISTORTION_CORRECTION_POINTS + x;
int32_t Distortion::getMatrix(int index) const
    return EEPROM::getZCorrection(index);
#else
    return matrix[index];
#endif
void Distortion::setMatrix(int32_t val, int index)
    EEPROM::setZCorrection(val, index);
#else
    matrix[index] = val;
#endif
bool Distortion::isCorner(fast8_t i, fast8_t j) const
    return (i == 0 || i == DISTORTION_CORRECTION_POINTS - 1)
           && (j == 0 || j == DISTORTION_CORRECTION_POINTS - 1);
 Extrapolates the changes from p1 to p2 to p3 whcih has the same distance as p1-p2.
inline int32_t Distortion::extrapolatePoint(fast8_t x1, fast8_t y1, fast8_t x2, fast8_t y2) const
    return 2 * getMatrix(matrixIndex(x2,y2)) - getMatrix(matrixIndex(x1,y1));
void Distortion::extrapolateCorner(fast8_t x, fast8_t y, fast8_t dx, fast8_t dy)
    setMatrix((extrapolatePoint(x + 2 * dx, y, x + dx, y) + extrapolatePoint(x, y + 2 * dy, x, y + dy)) / 2.0,
              matrixIndex(x,y));
void Distortion::extrapolateCorners()
    const fast8_t m = DISTORTION_CORRECTION_POINTS - 1;
    extrapolateCorner(0, 0, 1, 1);
    extrapolateCorner(0, m, 1,-1);
    extrapolateCorner(m, 0,-1, 1);
    extrapolateCorner(m, m,-1,-1);
void Distortion::measure(void)
    fast8_t ix, iy;
    float z = EEPROM::zProbeBedDistance() + EEPROM::zProbeHeight();
    disable(false);
    //Com::printFLN(PSTR("radiusCorr:"), radiusCorrectionSteps);
    //Com::printFLN(PSTR("steps:"), step);
    for (iy = DISTORTION_CORRECTION_POINTS - 1; iy >= 0; iy--)
        for (ix = 0; ix < DISTORTION_CORRECTION_POINTS; ix++)
#if (DRIVE_SYSTEM == DELTA) && DISTORTION_EXTRAPOLATE_CORNERS
            if (isCorner(ix, iy)) continue;
#endif
            float mtx = Printer::invAxisStepsPerMM[X_AXIS] * (ix * step - radiusCorrectionSteps);
            float mty = Printer::invAxisStepsPerMM[Y_AXIS] * (iy * step - radiusCorrectionSteps);
            //Com::printF(PSTR("mx "),mtx);
            //Com::printF(PSTR("my "),mty);
            //Com::printF(PSTR("ix "),(int)ix);
            //Com::printFLN(PSTR("iy "),(int)iy);
            Printer::moveToReal(mtx, mty, z, IGNORE_COORDINATE, EEPROM::zProbeXYSpeed());
            setMatrix(floor(0.5f + Printer::axisStepsPerMM[Z_AXIS] * (z -
                        Printer::runZProbe(ix == 0 && iy == DISTORTION_CORRECTION_POINTS - 1, ix == DISTORTION_CORRECTION_POINTS - 1 && iy == 0, Z_PROBE_REPETITIONS))),
                      matrixIndex(ix,iy));
    extrapolateCorners();
#endif
    // make average center
    float sum = 0;
    for(int k = 0;k < DISTORTION_CORRECTION_POINTS * DISTORTION_CORRECTION_POINTS; k++)
        sum += getMatrix(k);
    sum /= static_cast<float>(DISTORTION_CORRECTION_POINTS * DISTORTION_CORRECTION_POINTS);
        setMatrix(getMatrix(k) - sum, k);
    Printer::zLength -= sum * Printer::invAxisStepsPerMM[Z_AXIS];
#if EEPROM_MODE
    EEPROM::storeDataIntoEEPROM();
#endif
// print matrix
    Com::printInfoFLN(PSTR("Distortion correction matrix:"));
    for (iy = DISTORTION_CORRECTION_POINTS - 1; iy >=0 ; iy--)
        for(ix = 0; ix < DISTORTION_CORRECTION_POINTS; ix++)
            Com::printF(ix ? PSTR(", ") : PSTR(""), getMatrix(matrixIndex(ix,iy)));
        Com::println();
    enable(true);
    Printer::homeAxis(false, false, true);
int32_t Distortion::correct(int32_t x, int32_t y, int32_t z) const
    if (!enabled || z > zEnd || Printer::isZProbingActive()) return 0.0f;
    if(false && z == 0) {
  Com::printF(PSTR("correcting ("), x); Com::printF(PSTR(","), y);
    x += radiusCorrectionSteps;
    y += radiusCorrectionSteps;
    int32_t fxFloor = (x - (x < 0 ? step - 1 : 0)) / step; // special case floor for negative integers!
    int32_t fyFloor = (y - (y < 0 ? step -1 : 0)) / step;
// indexes to the matrix
    if (fxFloor < 0)
        fxFloor = 0;
    else if (fxFloor > DISTORTION_CORRECTION_POINTS - 2)
        fxFloor = DISTORTION_CORRECTION_POINTS - 2;
    if (fyFloor < 0)
        fyFloor = 0;
    else if (fyFloor > DISTORTION_CORRECTION_POINTS - 2)
        fyFloor = DISTORTION_CORRECTION_POINTS - 2;
// position between cells of matrix, range=0 to 1 - outside of the matrix the value will be outside this range and the value will be extrapolated
    int32_t fx = x - fxFloor * step; // Grid normalized coordinates
    int32_t fy = y - fyFloor * step;
    int32_t idx11 = matrixIndex(fxFloor, fyFloor);
    int32_t m11 = getMatrix(idx11), m12 = getMatrix(idx11 + 1);
    int32_t m21 = getMatrix(idx11 + DISTORTION_CORRECTION_POINTS);
    int32_t m22 = getMatrix(idx11 + DISTORTION_CORRECTION_POINTS + 1);
    int32_t zx1 = m11 + ((m21 - m11) * fx) / step;
    int32_t zx2 = m21 + ((m22 - m21) * fx) / step;
    int32_t correction_z = zx1 + ((zx2 - zx1) * fy) / step;
      Com::printF(PSTR(") by "), correction_z);
      Com::printF(PSTR(" ix= "), fxFloor); Com::printF(PSTR(" fx= "), fx);
      Com::printF(PSTR(" iy= "), fyFloor); Com::printFLN(PSTR(" fy= "), fy);
    if (z > zStart && z > 0)
        correction_z *= (zEnd - z) / (zEnd - zStart);
   /* if(correction_z > 20 || correction_z < -20) {
            Com::printFLN(PSTR("Corr. error too big:"),correction_z);
        Com::printF(PSTR("fxf"),(int)fxFloor);
        Com::printF(PSTR(" fyf"),(int)fyFloor);
        Com::printF(PSTR(" fx"),fx);
        Com::printF(PSTR(" fy"),fy);
        Com::printF(PSTR(" x"),x);
        Com::printFLN(PSTR(" y"),y);
        Com::printF(PSTR(" m11:"),m11);
        Com::printF(PSTR(" m12:"),m12);
        Com::printF(PSTR(" m21:"),m21);
        Com::printF(PSTR(" m22:"),m22);
        Com::printFLN(PSTR(" step:"),step);
        correction_z = 0;
    return correction_z;
Change the Z_PROBE_REPETITIONS to 10 in configuration.h under the printer type you are using. For me I'm using Rostock MaxV3 (type 5).
To use after compiling and uploading to the printer open a terminal in Matter control. Then issue G30, G68, and G69 commands. Look in the output for lines like
<-Steps remaining: 57155
<- -4.00 -10.00 -14.00 -16.00 -16.00 -16.00 -16.00 -15.00 -15.00 -16.00Z-probe:19.97 Step Variation from Probe to bed Distance:-2.20 X:0.00 Y:0.00
Each of the values before the "Z-probe:" are the values from each tap.
I don't exactly know what to make of all of this except wonder why that first probe of the center bed is different than all others.
I tried adding delays from the last command before the probe to let any problems caused by movement (noise or ?) settle out but that did not change it.
Re: Upgrade from v2 to v3 , problems with homing and code compilation.
Posted: Sun Nov 06, 2016 11:03 am
by Dr. Pepper
Dale, you might on to something here! Notice how the first tap is large, then the next less, then it is fine. Could it be the center of the bed flexing downwards with the first hit and then the system compensates for the location a bit each time? I wonder what would happen if we slow down the velocity of the HE280 as it descends to reduce the impact force slightly?
