rostock max V3 calibration problem
Posted: Fri Oct 28, 2016 4:36 pm
by flynn
Hello, i try to found what's the problem but i don't found how can i solve that problem
when i run the Gcode to calibrate on matter control, the hot end go down and hit against the X axis and if i don't stop that i think it's going to break it!
I had already clear the EEPROM, and reload the firmware, but nothing change
please help me it's my first 3D printer and i'm a beginner :/
https://www.youtube.com/watch?v=jw-dqodgBjk
Re: rostock max V3 calibration problem
Posted: Fri Oct 28, 2016 5:53 pm
Make sure the connection to the HE280's PCB is tight and that you've got the wiring to the RAMBo connected properly.
Posted: Mon Oct 31, 2016 3:30 pm
and don't post the same question in 2 different forums!
Posted: Mon Oct 31, 2016 3:37 pm
by bvandiepenbos
mhackney wrote:and don't post the same question in 2 different forums!
?really?
aren't we a little grumpy today? ...is geneb rubbing off on you?
Posted: Mon Oct 31, 2016 3:43 pm
LOL, yes and yes. I just spent 6 hrs driving from Boston to Rochester, NY so I'm a little tired. But the fact remains, double posting is uncool!
Posted: Mon Oct 31, 2016 4:38 pm
by flynn
where a double post? on my presentation? isn't a double post,
well, everything is okay, i was just an assembly's problem of "Ends stop"
my bad, i'm French and i look only the vid' on the tutorial, after reading the tutorial, i removed the small levers, and now everything works
thanks for your reply
Posted: Mon Oct 31, 2016 5:00 pm
I was referring to this one:
http://forum.seemecnc.com/viewtopic.php ... 002#p98002
but it seems it is a different topic but you used the same subject for both posts, making it confusing. No worries, sorry to add confusion. Geneb is rubbing off on my...
Posted: Tue Nov 01, 2016 6:33 am
by flynn
oh sorry it's a bad handling, i
I thought my post was not had not published
it's why I published twice
sorry not voluntary : /
