macOS Sierra 10.12.1 can't connect, can't see prefs file?
Posted: Tue Nov 01, 2016 9:09 pm
I'm not entirely sure this is the cause, but I am very suspicious.
I updated my laptop's OS to the latest Sierra 10.12.1. The next time I started MatterControl, I noticed that the print area was square instead of the Rostock Max v2 circular area I'm used to seeing. Then later I couldn't connect to my printer, which is very bad. I tried setting the USB port in the printer config to the USB that was showing up with and through the config editor, but still couldn't connect.
This comment has me worried
https://www.virtualhere.com/comment/2663
and the "default config file" part of
ls /dev/*usb*This comment has me worried
./MatterControlMac
objc[1994]: Class VCWeakObjectHolder is implemented in both /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/ViceroyTrace.framework/Versions/A/ViceroyTrace (0xa4993090) and /System/Library/PrivateFrameworks/AVConference.framework/Versions/A/AVConference (0xa49a8e04). One of the two will be used. Which one is undefined.
104 ms 1
5 ms 2
0 ms 3
3 ms 4
Fontconfig error: Cannot load default config file
Cookies:
Cookies:
Cookies:
Cookies:
Waiting for a connection on port 52727...
Unable to open public port (UPnP)
Error: System.NotSupportedException: Specified method is not supported.
at Mono.Nat.Pmp.PmpNatDevice.BeginGetSpecificMapping (Protocol protocol, Int32 port, System.AsyncCallback callback, System.Object asyncState) <0xd42e8e8 + 0x0001f> in <filename unknown>:0
at Mono.Nat.AbstractNatDevice.GetSpecificMapping (Protocol protocol, Int32 port) <0xd42e8a0 + 0x00032> in <filename unknown>:0
at MatterHackers.MatterControl.Plugins.CloudServices.CloudServicesListener.DeviceFound (System.Object sender, Mono.Nat.DeviceEventArgs args) <0xd42e160 + 0x001ff> in <filename unknown>:0
