- The LCD screen works perfectly fine
- The Speaker works fine
- The reset button does not work (at all)
- The control knob button press works, but I cannot scroll through the lists
- The LCD screen cycles through a continuous resetting process (Displays startup screen, then displays the home screen)
Note: I found that the person who built the printer had one end of the 10 pin connector to the LCD on backwards, so I just flipped it around on the Rambo Board. Before flipping it, the screen would not cycle through the startup and home, but every time I tried to scroll through the menu, the machine would home and reset.
Note 2: In the configuration.h file, I have the LCD type defined as "13"
Note 3: IT IS NOT OFF BY ONE PIN. I have checked this. multiple times. repeatedly.
 Any help is appreciated!
