Automatic Nozzle Brush for V3
timskloss
Post by timskloss »
My daughter does not like to pick off the ooze from the nozzle just before our new Rostock Max V3 begins to print. So I saw an opportunity and sketched up a part to hold a small wire brush to automatically clean the nozzle when starting a print.
I put the thing here: http://www.thingiverse.com/thing:1904416
The g-code to add to your slicer is listed in the description of the thing. The only drawback is that you need to remove the brush after starting a large diameter print. For most smaller prints it can just stay in place.
For such a simple thing, it works quite well and has really cut down on stray filaments interfering with the first layer.
Re: Automatic Nozzle Brush for V3
The link is broken.
timskloss
Post by timskloss »
Thanks for the tip. It is my first time to publish a thing and I forgot to hit the 'publish' button. It should work now.
Be careful with your GCode to wipe the nozzle! I've read more than one horror story of someone getting a little over eager on "brush depth" and shorting out their heater or LCD :)
timskloss
Post by timskloss »
Jimustanguitar wrote:Be careful with your GCode to wipe the nozzle! I've read more than one horror story of someone getting a little over eager on "brush depth" and shorting out their heater or LCD :)
Oh yes, I see you could short out the heater leads with the metal brush bristles if you lowered the nozzle too much!
Maybe make yourself a little brush out of a block of PTFE.
Post by Xenocrates »
geneb wrote:Maybe make yourself a little brush out of a block of PTFE.
I was thinking more a refractory ceramic fiber would be a good idea (I should try this on one of the Taz's. That way it's not my printer if it breaks something). Although it would mean that anything but a steel hotend might be abraded faster, and the fibers might detach or do unfun things over time.
DeltaCon
Post by DeltaCon »
Nice idea. Will have to adapt to V2 bed when I get my printer working again...
