Trouble with V3 Z offset using old and new firmware
Posted: Sun Nov 27, 2016 10:27 pm
I am having trouble calibrating the bed on my V3. I have tried both the 'old' V3 probing gcode file from SeeMe and the new development firmware. In both cases I am getting a Z0 that is about 0.15 mm above the bed. This measurement is consistent at +/- 100 mm in x/y so the bed is pretty flat. I always clean the nozzle and run the calibration with cold bed and extruder.
I discovered the offset after a lot of frustrating work trying to get ABS to stick to the bed--the nozzle was just to high.
Currently I am using a Z offset of -0.07 mm and it seems to give a decent first layer, but I want to fix this problem in the printer so Z0 is really at 0.00 mm. Here are the EEPROM settings after running the new development firmware:
What is the 'correct' way to adjust so I don't have to worry about it when slicing?
Thanks in advance!
<-EPR:2 79 900000 Max. inactive time [ms,0=off]
<-EPR:2 83 600000 Stop stepper after inactivity [ms,0=off]
<-EPR:3 11 80.0000 Steps per mm
<-EPR:3 23 250.000 Max. feedrate [mm/s]
<-EPR:3 35 80.000 Homing feedrate [mm/s]
<-EPR:3 39 32.000 Max. jerk [mm/s]
<-EPR:3 133 0.000 X home pos [mm]
<-EPR:3 137 0.000 Y home pos [mm]
<-EPR:3 141 0.000 Z home pos [mm]
<-EPR:3 145 250.000 X max length [mm]
<-EPR:3 149 250.000 Y max length [mm]
<-EPR:3 153 402.388 Z max length [mm]
<-EPR:3 59 1850.000 Acceleration [mm/s^2]
<-EPR:3 71 3000.000 Travel acceleration [mm/s^2]
<-EPR:3 881 291.060 Diagonal rod length [mm]
<-EPR:3 885 143.901 Horizontal rod radius at 0,0 [mm]
<-EPR:3 925 200.000 Max printable radius [mm]
<-EPR:1 891 80 Segments/s for travel
<-EPR:1 889 200 Segments/s for printing
<-EPR:1 893 65 Tower X endstop offset [steps]
<-EPR:1 895 0 Tower Y endstop offset [steps]
<-EPR:1 897 87 Tower Z endstop offset [steps]
<-EPR:3 901 210.000 Alpha A(210):
<-EPR:3 905 330.000 Alpha B(330):
<-EPR:3 909 90.000 Alpha C(90):
<-EPR:3 913 0.000 Delta Radius A(0):
<-EPR:3 917 0.000 Delta Radius B(0):
<-EPR:3 921 0.000 Delta Radius C(0):
<-EPR:3 933 0.000 Corr. diagonal A [mm]
<-EPR:3 937 0.000 Corr. diagonal B [mm]
<-EPR:3 941 0.000 Corr. diagonal C [mm]
<-EPR:3 808 -0.200 Z-probe height [mm]
<-EPR:3 929 20.000 Max. z-probe - bed dist. [mm]
<-EPR:3 812 90.000 Z-probe speed [mm/s]
<-EPR:3 840 50.000 Z-probe x-y-speed [mm/s]
<-EPR:3 800 0.000 Z-probe offset x [mm]
<-EPR:3 804 0.000 Z-probe offset y [mm]
<-EPR:3 816 -123.565 Z-probe X1
<-EPR:3 820 -71.340 Z-probe Y1
<-EPR:3 824 123.565 Z-probe X2
<-EPR:3 828 -71.340 Z-probe Y2
<-EPR:3 832 0.000 Z-probe X3
<-EPR:3 836 142.680 Z-probe Y3
<-EPR:0 880 1 Autolevel active (1/0)
Thanks in advance!
