axle works it way loose...
Posted: Mon Nov 28, 2016 7:05 pm
by edwardjanderson
Hello - I have a Rostock Max V2- When I have prints that run for several hours I find that 2 of the 3 axles on the hot end creep out until the clip falls off. Is there any way to adjust the axle to prevent this?
Thanks
Re: axle works it way loose...
Posted: Tue Nov 29, 2016 8:04 am
by Mac The Knife
I would try some light oil, like 3 in 1 oil, on the axles. If they're lubricated, the clips will be able to keep them in place.
Do you have the aluminum U-joints, or the Acetal ones?
Posted: Tue Nov 29, 2016 8:50 am
If the axles are working out, he's not only got the metal u-joints, but a binding problem as well.
I _strongly_ recommend that anyone with the original u-joint arms replace them with the new ball & socket design (and the new injection molded carriages).
Posted: Wed Nov 30, 2016 9:26 pm
by edwardjanderson
yes- I have the aluminum U-joints. I will lubricate them and look into the ball and socket design...
Thanks
Posted: Thu Dec 01, 2016 4:34 am
by DeltaCon
geneb wrote:I _strongly_ recommend that anyone with the original u-joint arms replace them with the new ball & socket design (and the new injection molded carriages).
Yes, Christmas is around the corner, I am looking into that!
Posted: Wed Dec 21, 2016 5:38 pm
by gajtguy
Thanks guys for the forum and the suggestion to oil the axles. I have had the same issue as Edward and this solved it.
Now on to take a gander at those upgrades. Unlike Clark Griswold, I'm buying 3D printer parts with my xmas bonus, not putting in a swimming pool. Video
