Temp question
Temp question
I am trying to use PETG but my printer will not go above 245c, how can I make it go higher?
							Rostock Max V2 - Unnamed as of yet...
Robo 3D R1
One of the two printers can be found streaming at the link below just about every day.
https://www.youtube.com/watch?v=wky8RuNW9TY
						Robo 3D R1
Re: Temp question
If you are using the stock hot end, it isn't recommended to go higher than 245 because of the risk of melting the PEEK section of the hotend.  If you are running an all metal hotend, you have to edit the firmware and reload it into the printer to get anything higher.   There are two locations, if I remember correctly, that you have to edit the firmware.
Re: Temp question
