Heater decoupling at the same spot on a print
Posted: Mon Dec 19, 2016 7:44 pm
				I've been trying to print this planter as a Christmas gift: http://www.thingiverse.com/thing:1236962
With my current settings, its showing up as about a 22 hour print. Every time I print it, I get to around the 10 hour mark and then the printer shuts down. The error shows that the printer thinks the heater has become decoupled.
Looking at the temp log in Octoprint, I see the hot end temp dropped to 0, then came back on, then dropped to 0 again. After sitting at 0, the "set" temperature turned off as a safety measure:
[img]http://i.imgur.com/38gi46V.jpg[/img]
I completely disassembled the hot end, verified continuity on the fuse, wiggled it a bunch to ensure it wasn't loose, checked resistance on the thermocouple, etc. It still dies about the same time. I tried re-slicing the model, in case something weird happened in the original slice, but it didn't make any difference.
What's weird to me is that if it was a loose connection, it shouldn't be dying at the same point on the print repeatedly. Other stuff I can print just fine, but you can see here, my 3 attempts at printing this all failed at about the same place:
[img]http://i.imgur.com/umwuolc.jpg[/img]
Any clue as to what me causing this failure?
