Rostock Max v3 initial startup Thermistor problems?
Posted: Wed Dec 21, 2016 7:21 pm
				Hi,
Been searching a lot of the forums before posting and it seems other people have similar errors to mine but most of these errors are occurring for folks after they've printed a few prints.
I just turned my printer on for the first time, and am up to Step 6: Calibrating, but I'm having errors from what I think are the thermistor(s).
When I start the printer up, NOZ: def and BED: def show up after flashing at 5.1 and 23 respectively.
I'm pretty sure the BED thermistor is reading accurately, but when I hit "preheat" in the controls of MatterControl nothing happens. When should the LED on the bed be on? From when I turn on the printer or after I activate it in MatterControl?
Then, the hot end thermistor is clearly not reading correctly. When I hit "preheat" in the controls of MatterControl, the "Target" box goes from 0 to 215 C, so at least something seems to be happening, but the hot end doesn't heat up. I've already broken two thermistors, so I'm pretty terrified to mess with the thermistor anymore on the hot end. I checked the solder and it looks pretty good. I also made sure neither of the two wires are touching anywhere. Is it possible to have soldered it backwards (power and ground)?
Possibly relevant information: Both thermistor temperatures are fluctuating +/- one tenth of a degree, so that gives me hope that they are working? Also, I am in southern california and the temperature in the room the printer is in is DEFINITELY greater than 18 C. When I turn the "Fan" on in MatterControl the 3 side fans all turn on and the pink LED on the Hot End lights up. Also all of the commands in the "movement" category work fine. MatterControl keeps telling me the printer is set into dry run mode until restart.
Obviously I'm completely inexperienced in all of this, but any help would be greatly appreciated. I'm hoping I can at least fix the bed issues and maybe purchase a pre-assembled hot end if mine is too messed up.
Thank you!
-Matthew
Thank you!
-Matthew
