Crydom D2425 relay
Posted: Sat Dec 24, 2016 10:59 am
				I have three extra Crydom D2425 solid-state relays for sale, $15 each shipped in the US. They appear to be new-old-stock, or very, very lightly used. Include terminal screws, but no original packaging, documentation or cover plate.
I and others use an SSR like these to allow the Rambo to control AC-powered bed heaters. They have an input range of 3-32 volts DC (easily covers the Rambo's 12V output), and are rated to switch up to 240VAC at 25amps. I personally use mine to switch three paralleled 120VAC / 100W PTC heaters. To use these relays, you will need an enclosure (to cover the exposed connections), a fuse or circuit breaker, a switch, a power indicator (or switch with light in it), and associated wires and connectors.
Example pix:
[img]http://i.ebayimg.com/00/s/NTAwWDQ2MA==/ ... 7/$_35.JPG[/img]
Example pix:
